Old 04-03-2013, 06:45 PM   #8071
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,555
A little diversion
Well, for the first time in almost 15k miles, my '08 left me by the side of the road.... with my cell phone charging on my desk at home. D'oh.
Turns out the fuel quick-disconnect, uh, quickly disconnected (mid-wheelie, which felt particularly odd).
Took a bit of tinkering to find the problem, but it was easily solved.
Suck, Squeeze, Bang, Blow
New Rider Training in the San Francisco Bay Area at Motorcycle University". Learn to Ride...Better!
Roadracer_Al is offline   Reply With Quote
Old 04-03-2013, 06:58 PM   #8072
slidefighter
Gather it up, keep on...
slidefighter's Avatar
Oddometer: 328
I’ve gotten a lot of quality info off this website, so I figure it’s about time I made a bit of a payback. I’m not very familiar with my 690 (yet) but I did recently finish building an airplane from a kit. Not important, except that it exposed me to a lot of useful aircraft products, hardware, electrical, and structural resources that some of you may not know about. Use at your own discretion, but the following are in common usage and are “common knowledge” among the homebuilt aircraft crowd. A couple of them have been mentioned by others here before. Aircraft hardware is typically very high quality as almost all of it has to meet either AN (Army/Navy), MS (Military Standard), or NAS (National Aerospace) standards.
If you shop for any of this stuff, you will see those terms over and over; there is a bewildering array of (particularly) AN hardware out there. Those of you working over your fuel systems will likely find AN fuel hardware very useful. The only thing to be aware of with almost all aircraft hardware is that it is to U.S. SAE fittings standards, meaning NOT metric, so you might have to carry a couple of extra combination wrenches in your tool kit if you use it. On the other hand, AN hardware seldom fails.
Here are my major sources (sometimes finding things on their sites is not easy---it’s ALL there though, keep digging or just call them):
Aircraft Spruce (www.aircraftspruce.com): Bearings, bolts, bushings, clamps, connectors, fittings, flanges, grommets, machine screws, nuts, washers, tools, sheet aluminum, etc. WAY too much to list. This is the most common resource in the homebuilt aircraft world. I have these guys on speed dial! They have warehouses on both U.S. coasts and ship internationally all the time.
Wicks Aircraft Supply (http://www.wicksaircraft.com/index.html): Wicks is virtually identical to Aircraft Spruce. I’ve bought from them countless times. Sometimes prices on one will be lower than the other, for a particular item. Also, sometimes one will have something in stock that the other doesn’t. Just check with them both.
SteinAir (http://www.steinair.com): These guys are my favorite source for everything electrical and related. Don’t be put off by their obvious airplane orientation. They have all sorts of things you might want for your 690 electrical system: Cable and zip ties, connectors, fuze blocks, grommets and bushings, heat shrink, spiral wrap, lights, switches, terminals, tools, wire, chafe protection, etc.
Here are some other products you can find on the above sites I think would be of specific benefit to motorcyclists:
A wide variety of 3M products (fire barrier, anti-chafe, protective tapes, the list is endless)
Anti-sieze: Champion Spark Plug anti-sieze
Boelube: Amazing lubricant for screws; I just use their little tube---looks like chapstick; amazing
Kroil: Nothing breaks loose rusted threads like this stuff
Mouse Milk: Great thread lubricant, but I also use it when connecting exhaust joints. Will penetrate right into the joint. Some aircraft exhaust systems have swivel joints in them; keeps them from locking up
Corrosion X: Nothing rusts with Corrosion X on it
ProSeal/890: This stuff is a little hard to work with but it’s magic and has a lot of uses. Comes with different curing times, but it all works the same. Seals almost any joint and is fuel resistant. Most aircraft fuel tanks are metal on metal, just riveted together these days. They can be permanently, internally sealed by applying ProSeal along the joints and around vents, fuel pickups, etc. It cures with a slight residual flexibility unlike JB Weld. I’ve used it in lots of applications, even to seal my windshield to its aluminum frame.
Kresto/Stoko Hand Cleaner: Best hand cleaner around. We use it where I work and it is the only thing we have that will take Proseal off your hands. amazing stuff. Like most of the other brands, just clean your hands dry and then add water and wash off. By the way, any Proseal you get on your clothes, is there forever.
Hope some of this is helpful...
Regards,
Lee...
Slidefighter
"Never adopt an ideology that masks a lack of courage"
slidefighter is online now   Reply With Quote
Old 04-04-2013, 10:22 AM   #8073
ArcticRider
ArcticRider's Avatar
Oddometer: 170
Overheating
Hey Gents,
I am new to the 690 and riding in Arizona (ambient temp 80'ish). It's a 2008 with 15K miles and the high temp warning light goes on frequently and the gauge reaches 12 bars and flashes. This occurs at stop lights as well as during uphill rides. No error codes are thrown.
The surprising thing is that the fan never cycles on until I am at what KTM manual indicates as "critical temps"--several minutes after the red warning light goes from blinking red to solid red.
The thermostat switch was changed by the PO. The coolant is 15 months old but has only 500 miles logged.
Is RallyRaid the only manufacturer of the thermo-switch that kicks the fan on at a lower temp or can I find one locally?
Appreciate any suggestions.
ArcticRider screwed with this post 04-04-2013 at 10:38 AM
ArcticRider is offline   Reply With Quote
Old 04-04-2013, 10:23 AM   #8074
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,341
Originally Posted by dunefreak View Post
Do the valves on these bikes have a tendency to tighten up at all? I always do maintenance a little early and was wondering if I should check my valve clearances now (5k miles) or just wait until the recommended KTM interval at 6,000 miles. Thoughts?
Yes they do, and seeings how it's so simple to check em, why not do it a bit early.
Old 04-04-2013, 10:26 AM   #8075
wsmc831
wsmc831's Avatar
Oddometer: 704
Originally Posted by ArcticRider View Post
Hey Gents,
Is there a thermo-switch that kicks the fan on at a lower temp?
First, continuing to ride the bike when temps get that hot is just asking for a very expensive repair bill.
It's a simple system. Could be thermostat, switch, air in the lines...Get it looked at if you can't diagnose the system yourself, and don't let it get that hot if you want the bike to last past next week.
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is offline   Reply With Quote
Old 04-04-2013, 10:28 AM   #8076
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,341
Originally Posted by The Letter J View Post
On a different note: I ordered new bearings for my rear shock 2 weeks ago (lower is shot) and received an email that they are not in stock with KTM and have a due date near the end of May. Does anyone know of an interchange with KTM part # R15006 "REPAIR KIT BEARINGS" or a source that would likely have them in stock?
Surely you have a local bearing supply shop close by? I never buy OEM bearings when it comes time to replace them.
Old 04-04-2013, 10:32 AM   #8077
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,341
Hey Gents,
There's something wrong with your cooling system if you keep overheating like that. If the fan is kicking on it should never overheat regardless of what temp switch you have in there. I've ridden my bike in the middle of summer in 100+ temps crawling around rocks and never overheated it.
Old 04-04-2013, 10:46 AM   #8078
ArcticRider
Oddometer: 170
Yeah thanks...what I was asking is if this is common for the 690. The manual says 5-11 bars is typical for engine. Do any of you guys see your temp gauge reach 12 or have the temp light cycle on? Do your fans typically cycle below 12 bars?
You list thermostat and switch separately. I thought they were the same component. Where is the switch? Thanks
Old 04-04-2013, 10:51 AM   #8079
Ranies
Oddometer: 38
Hey Gents,
Mine overheated/showed 12 bars when I did 15 min reset procedure since I was inside house, never again.
That because dealer forgot to plug the fan connector after they had the engine out.
If you are going to change the fan switch Ive got a 88 degrees Suzuki LTZ 400 2006 switch, but have not fitted it yet. If you google you will see that many folks have this one.
Ranies is offline   Reply With Quote
Old 04-04-2013, 10:54 AM   #8080
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,442
The lower temp fan switch is about $45 from your local suzuki dealer and should be the one from a LTZ400 quad iirc. If your temperature gage is flashing then things are dangerously hot...unless you have a temperature sensor problem. If the fan is not coming on then one of two things is wrong:
1. The coolant isn't actually that hot and the temp senor for the gage is bad
2. The coolant is that hot, and the fan switch is no good..or someone forgot to plug the fan back in.
My gage was getting that hot because my bike blew the headgasket and was consuming vast quantities of coolant as a fuel additive.
Seth S
Seth S is online now   Reply With Quote
Old 04-04-2013, 10:59 AM   #8081
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,341
Never, and I've ridden mine in summer while the radiator had a leak. It would easily get down to half full and still never saw the temp warning light.
Old 04-04-2013, 11:03 AM   #8082
ArcticRider
Oddometer: 170
Right on Seth.
1. I know where the thermo switch is for the fan. Where is the sensor for the cluster?
2. All connections are plugged in.
Is the LTZ400 switch a direct fit replacement?
Old 04-04-2013, 11:13 AM   #8083
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,514
Right on Seth.
I would also add for consideration;
3. make sure the fins on your radiator are not plugged up with mud/ bugs etc..
The only time my 08 seemed to run consistently hot, I noticed mud in the fins. Don't use a pressure washer to blast them clean if you think you have a similar condition, you could damage the radiator.
Instead, be patient with a garden hose, and rinse the fins thoroughly until it seems the water is running through with little resistance.
Originally Posted by metaljockey View Post
None of us are exceptionally skilled riders (excepting when I'm drunk, then I'm fcking quick).
BK.RD.RNR is offline   Reply With Quote
Old 04-04-2013, 11:24 AM   #8084
Aaron from Texas
Aaron from Texas's Avatar
Oddometer: 489
Anyone have a stock seat taking up TOO MUCH ROOM in their garage?
I run a Renazco that the PO had on there. Was curious how the stocker would fair for in town jaunts and when I'm rarely seated offroad...
1987 Honda XL600R
ftwtexas.blogspot.com
Aaron from Texas is offline   Reply With Quote
Old 04-04-2013, 11:48 AM   #8085
motoged
motoged's Avatar
Oddometer: 907
Originally Posted by Kirk the Jerk View Post
Anyone have a stock seat taking up TOO MUCH ROOM in their garage?...
Kirk,
If you want to know how the stock seat feels, get a 3' length of 2X4, wrap it with barb-wire, and install it.... the Renazco will feel better at the end of the day
I DO have a stock muffler I will sell for slightly below dealer price
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Times are GMT -7.   It's 06:22 PM.
