Old 04-25-2013, 01:34 AM   #8431
Hoots
Hoots's Avatar
Oddometer: 1,374
Originally Posted by Noyah View Post
I'm in the middle of setting my bike up after installing Koubalink 1" (2.5 cm).
I started out raising the forks 2 cm but for me the bike got a bit unstable even at low speed (on soft gravel/mud)
Currently 1.4 cm raised and it seems better for me. Checked SAG and Rider SAG on the rear and it seems to be in spec.
Dialed in compression and rebound to 15 clicks while i try to find a good base setup forkwise.
Next step if i still dont like it will be 1 cm raised, and then 0.5 cm etc. After that i will remove the koubalink
690 enduro r -11
How tall are you Noyah and Canadian Bacon?
Hoots is offline   Reply With Quote
Old 04-25-2013, 01:52 AM   #8432
Harty
Bloody Good Bloke!
Harty's Avatar
Oddometer: 261
Originally Posted by Hoots View Post
I was on the cusp of buying a Scotts/Ohlin steering damper and kit from RR - had looked at GPR also - but had not considered the RalleMoto option ...
Has anyone used one and, if so, any opinions?
I'm in Australia, but curiously there is no free shipping here ...
I've been told by a few guys over here in the UK, that the RalleMoto is the better damper than the Scotts/Ohlins unit
I'll get me coat..............
Harty is offline   Reply With Quote
Old 04-25-2013, 02:15 AM   #8433
Hoots
Hoots's Avatar
Oddometer: 1,374
It looks quite innovative.
http://www.rallemoto.com/contents/en-us/d49.html
Old 04-25-2013, 03:11 AM   #8434
Noyah
poser
Noyah's Avatar
Oddometer: 400
1.78m 5'10 ish
KTM 690 Enduro R
--> My Movies <--
Noyah is offline   Reply With Quote
Old 04-25-2013, 03:28 AM   #8435
MarTind
Repaired and ready
MarTind's Avatar
Oddometer: 49
Possible solution
Just had a similar problem with my '09. Intermittent FI error (9 flash: Throttle Position not plausible) Similar deal- fiddle with harness and other bits would "seem to fix" the problem but it soon returned.
After replacing the Throttle Body and the Harness it turned out that the Voltage Regulator was putting out 18v. Replaced that and all fixed.
(New ones will put out <15v)
Let me know if this helps.
Originally Posted by shipwrek12001 View Post
anyone that may know
major electrical power failure tonight, left me 1 km from home, it started intermitently then failed... removed the sea checking for battery, master relay connections.. nothing obvious.. pulling up on the main hareness going under the air box made it come alive again.. then fail. but I could make the bike come on and off at will moving the harness...
bikes back in the garage for me to goof with it tomorrow... any ideas where to look...?
again total electrical failure... it started with setting a fuel pump code, then a complete power failure. found moving the harness will restore the power and start, drive... I did a fuel pump and a fmf slip-on on it a month ago. (ca-cycle)
probably simple to fix, shitty to find...
MarTind is offline   Reply With Quote
Old 04-25-2013, 04:09 AM   #8436
MarTind
Repaired and ready
MarTind's Avatar
Oddometer: 49
FI "9 Blinks"
9 Flashes also can mean "Throttle Position Not Plausible"
Check Regulator is putting out less than 15v. (anything more will "confuse" the ECU)
Originally Posted by snohobo View Post
I haven't been riding lately but last week I was getting the bike back together, putting on some new parts, etc...
The only engine related part I put on was a new Remus pipe. Other stuff was new tires, plastics, cogs, sprocket, chain...
I noticed that the bike would turn over, but not start. Battery was charged, fuel pump priming - but it just wouldnt catch.
I had the upgraded fuel injector in my spare parts bag - and thought that might be the problem - so i installed it. Sure enough - the bike would now start, and idle - but would refuse to run. I could get it going in 1st and 2nd - but the bike would backfire badly, and die when the rpms dropped to idle.
Then the FI light came on - 9 blinks which indicate - Input signal from pressure sensor of induction manifold too low/high ktm.
What the hell and where the hell is the pressure sensor of induction manifold?
In Colombia - i had another related issue where the bike wouldnt start - and I got the same FI light. I brought it to the dealer and they cleared the code and put in a new spark plug and that seemed to fix the problem - for about 15,000 miles.
Does anyone know anything about this code? I can only find 2 examples of it ever being mentioned on google - and both didnt have much info.
"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day."
Old 04-25-2013, 07:33 AM   #8437
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,441
Looks suspiciously like a reverse engineered Scotts unit. I have used the Scotts units for years on my bikes and they have always worked well.
Seth S
Seth S is offline   Reply With Quote
Old 04-25-2013, 08:47 AM   #8438
ktmmitch
Oddometer: 575
I agree Seth,I have used Scotts/Ohlins for many years now,and sold/serviced them.IMHO they do the job,simple to set-up & easy to service.
I have the new Ohlins unit here to test,but I will have to make a new triple clamp to fit it between the bar clamps,as it uses the steering stem nut to secure it,but by moving the bar clamp screws out by 5mm per side,the extra width with allow the PHDS to be used with the older Scotts damper,which up until now only the 450RR guys could.I really like the PHDS,but can use it on the OEM triples with scotts damper,so looking forward to trying it out.
Sorry for my absence from the ADV community the last few weeks,but it has been(is) really tough losing Wes(Beaney) on the Tuareg Rallye,it is a big miss around here,no-one to bounce my silly ideas off,guess I'll just have to rely on you guys now.
ktmmitch is offline   Reply With Quote
Old 04-25-2013, 08:50 AM   #8439
Baja Dad
Baja Dad's Avatar
Oddometer: 1,947
Glad to hear from you John!!
Bounce away!!
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 04-25-2013, 09:03 AM   #8440
Canadian_Bacon
Oddometer: 184
I'm 5'9 with roughly a 29" inseem.
1.78m 5'10 ish
Canadian_Bacon is offline   Reply With Quote
Old 04-25-2013, 09:12 AM   #8441
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,327
Anyone been able to track down a 2012+ service manual?
Old 04-25-2013, 09:17 AM   #8442
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 3,970
690 enduro r -11
My bike came with the 1-5/8" Link. That was way too much drop for me. I was hitting the ground too often.
I changed to the 1" drop link. I have a super heavy spring to carry my lard butt. 106nM. I'm running .58 springs in the front. I am about 5'8" with a 29" inseam. My Sag in back is about 140mm with me on. I too have the forks up about 20mm. I'm thinking of going up just a bit to 15mm. I have this slight feeling of looking down when sitting on the bike.
The suspension is working awesome. Near 400 miles of washboard Death Valley roads over the weekend. Smooth & plush.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 04-25-2013, 09:27 AM   #8443
palmstatecrawler
palmstatecrawler's Avatar
Oddometer: 477
Are there any problems with the rear tire rubbing with the kouba links? I have been considering getting one. Street riding is fine but offroad I would like to be able to reach the ground a little easier. 5'10"
'13 KTM 690 Enduro R w/ full akrapovic exhaust, Evo1 lid, uni filter, Renazco seat, hard parts windshield and footpad, scotts damper with BRP submount, hammerhead shifter, flatlands skidplate, lost dog centerstand, Touratech engine guards, r&g front and rear axle and exhaust sliders, piaa 1100's, Doubletake mirrors, G2cam system,
'07 Kawasaki KLX250, '86 Yamaha BW80
palmstatecrawler is offline   Reply With Quote
Old 04-25-2013, 09:50 AM   #8444
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 3,970
I could bottom and hit even with the stock link. With the 1" drop I still touch only on those really big landings . Having a big enough spring to handle the load is key. This was taught me by my suspension tuner.
I run a very aggressive rear tire. Pirelli XCMH 140/80.
I've got a used 1-5/8 link available if somebody wants to give it a try. Cheap.
Tom
My2Wheels
690 WIKI
Old 04-25-2013, 10:41 AM   #8445
kanur
cu new er
kanur's Avatar
Oddometer: 709
I just put the 1" link on my 09 Enduro R and have the forks pulled up 16 mm. Not a lot of time on it yet but I think this is going to work just fine for me.
Just cause I don't run my mouth don't mean I got nuth'n to say. Mike Cooley DBT
kanur is offline   Reply With Quote
Times are GMT -7.   It's 06:01 AM.
