Old 04-26-2013, 04:38 AM   #8461
fluff34567
fluff34567's Avatar
Oddometer: 1,055
Is there a clutch pack replacement walk through somewhere or anything special to look for such as half plates etc ?
sent using my fingers and voodoo magic.
fluff34567 is offline   Reply With Quote
Old 04-26-2013, 07:06 AM   #8462
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,454
Originally Posted by Fishfund View Post
What are the options for a bbk on this bike. I haven't heard anything of this.
Plus one on the trans Can trail. Looks like a riot.
Bbk?
Seth S
Seth S is online now   Reply With Quote
Old 04-26-2013, 07:32 AM   #8463
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 3,972
Big bore kit. ;)
Sent from outer space with my Thunderbolt with Tapatalk.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 04-26-2013, 08:00 AM   #8464
invisible monster
invisible monster's Avatar
Oddometer: 484
Originally Posted by dad2bike View Post
Big bore kit. ;)
I've never felt that my 690 needed more power...
invisible monster is offline   Reply With Quote
Old 04-26-2013, 08:30 AM   #8465
Seth S
Seth S's Avatar
Oddometer: 4,454
Now you are just talking crazy talk
Seth S
Old 04-26-2013, 08:32 AM   #8466
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 3,972
That opens up another line of curiosity...
Has anybody figured out what KTM did to make the 2012 & up a 690 vs 654? What's the difference between the motors?
There was some old posts about looking into it. Then nothing. I guess if it was just a new jug and piston assembly it would be worth it after some kind of top end failure repair.
Tom
My2Wheels
690 WIKI
Old 04-26-2013, 08:43 AM   #8467
Aaron from Texas
Aaron from Texas's Avatar
Oddometer: 489
It's a longer stroke. The only real difference in parts is the crank assembly. The piston is slightly different, but functionally the same.
Check out this thread on SMJ -> HERE
1987 Honda XL600R
ftwtexas.blogspot.com
Aaron from Texas is offline   Reply With Quote
Old 04-26-2013, 09:22 AM   #8468
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 3,972
Wow. Quite the project he is doing. Thanks!
Tom
My2Wheels
690 WIKI
Old 04-26-2013, 09:39 AM   #8469
invisible monster
Oddometer: 484
haha, it's funny, this is the one bike I've ever had that I'm happy with the amount of power.
Old 04-26-2013, 03:25 PM   #8470
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,527
Originally Posted by HAFFMT View Post
Currently my 2010 690 will not start. When I turn the key on I get the normal fuel pump noise, but when I hit the starter button nothing happens, engine does not turn over. No FI light flashing. I've checked all the fuses and checked most of the connectors.
No major modifications to the bike other than an Akro pipe.
Any assistance or direction on what I should be checking would be appreciated.
You may also want to check the position of the magnet on your kickstand for proper alignment with the safety switch if you have not removed it. I think this is one of the most common causes for your symptom.
Originally Posted by metaljockey View Post
None of us are exceptionally skilled riders (excepting when I'm drunk, then I'm fcking quick).
BK.RD.RNR is offline   Reply With Quote
Old 04-26-2013, 03:34 PM   #8471
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 1,854
+1, in fact threebearically speaking....I sold my last bike cos it had too much of the stuff, and the one before that just didn't have enough....but this one is just right
My EXC530 Adventure
2008 Beta Rev3 - Trials with lots of errors
Night Falcon is offline   Reply With Quote
Old 04-26-2013, 03:52 PM   #8472
soggysandwich
Oddometer: 204
that's EXACTLY what mine did two days ago,,,,,turns out the negative ground strap that goes to one of the bolts that fasten the STARTER to the case,,,,,,was corrode in the threads.......everything looked fine on the outside, but when removing the bolt, it was difficult to remove and highly corroded,,,,,,cleaned the threads with a wire brush,,,, greased up the bolt ,, blew out the hole with WD 40 and re-installed bolt/ground strap.
motor started on first push of button,,,,idles and runs better than ever
soggysandwich is offline   Reply With Quote
Old 04-26-2013, 09:32 PM   #8473
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,351
What is it with this bike and the shoddy grounding. Thought I had a dead battery last week and when I started messing with the bike I figured out my R/R wasn't working. Turned out it was the damn ground wire coming of the R/R. . At least I checked the bike over before I wasted money on a new battery.
Old 04-26-2013, 09:58 PM   #8474
Night Falcon
Adventure NZL
Oddometer: 1,854
mine did the same thing a while back. It turned out to be a wire to the aux starter relay (runs under the battery box) was worn through. Easy to fix, no worries since.
My EXC530 Adventure
Old 04-26-2013, 10:14 PM   #8475
Canadian_Bacon
Oddometer: 184
So where exactly is the best place to run the ground??
Canadian_Bacon is offline   Reply With Quote
Times are GMT -7.   It's 06:23 PM.
