Old 04-26-2013, 11:45 PM   #8476
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 1,864
Originally Posted by Canadian_Bacon View Post
So where exactly is the best place to run the ground??
I didnt change the gound (earth) location, just need to make sure it has a clean connection and the wire is intact.
My EXC530 Adventure
2008 Beta Rev3 - Trials with lots of errors
Night Falcon is offline   Reply With Quote
Old 04-26-2013, 11:59 PM   #8477
Canadian_Bacon
Oddometer: 185
Okay thx for the heads up.
Canadian_Bacon is offline   Reply With Quote
Old 04-27-2013, 11:53 AM   #8478
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,494
Busted the rear brake lever today, replacement suggestions?
CanadianX is offline   Reply With Quote
Old 04-27-2013, 12:18 PM   #8479
jgbnm
jgbnm's Avatar
Oddometer: 173
Clean speed engineering makes one that is really nice.
Sent from my Nexus 7 using Tapatalk 2
jgbnm is online now   Reply With Quote
Old 04-27-2013, 12:20 PM   #8480
MrHix
MrHix's Avatar
Oddometer: 384
I just put a Clean Speed Eng pedal on my '12. Nice & sturdy and a good fit. Looks similar to the RR, but less $$$.
http://www.cleanspeedeng.com/Brake%20Pedal.htm
Cheers,
MrHix
MrHix is offline   Reply With Quote
Old 04-27-2013, 02:45 PM   #8481
2degreesout
2degreesout's Avatar
Oddometer: 868
Does anybody use this KTM 690 tankbag:
http://www.ktmtwins.com/ktm-690-enduro-smc-tank-bag
It's taken years, but I've finally gotten my supply of brain cells down to a manageable size.
2degreesout is offline   Reply With Quote
Old 04-27-2013, 03:58 PM   #8482
Aaron from Texas
Aaron from Texas's Avatar
Oddometer: 489
I used it for a while every day, for tools and everything else. I've since built a tray where the airbox used to be and mounted a drybox for my tools and now wear a Kriega R25 for everything else... Just didn't like the tankbag on the bike ALL the time, but it works great for long trips, etc...
1987 Honda XL600R
ftwtexas.blogspot.com
Aaron from Texas is offline   Reply With Quote
Old 04-27-2013, 04:22 PM   #8483
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,391
This new headlight should fit the 690.
A bit pricey but looks very cool.
Can't find any other info besides the videos.
Enduro-Tech LED Hi/Low (4500/1800 lumen)
http://youtu.be/jWQkFKjN2LY
http://youtu.be/IlCYtaAadgY
Old 04-27-2013, 09:41 PM   #8484
Velociraptor
TrackBum
Oddometer: 1,097
Dead speedometer issue resolved
Similar to what Uller mentioned a few pages back.
Just in front of the top right tank bolt is a ground wire that bolts to the frame. I should have checked that early on but it looked OK. Anyway I traced a brown/purple wire from a speedo connection all the way back to that ground. I took the insulation off that ground and discovered there were three small wires and one bigger wire all crimped to the connector. No solder. Just crimped. One of those small wires was broken and another was almost broken. I soldered, waterproofed, and strengthened that connection and the speedometer works! So if your speedometer stops working, check that connection first. I wish I had!
BTW I took the sleeving off a good bit of the wiring loom from the fuse box all the way to the ignition and all those wires looked like new. It was a major pain re wrapping all that stuff.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 04-27-2013, 10:58 PM   #8485
lightfighter
where does this go?
Oddometer: 2,255
That light does look cool... I have thus far been unable to really do any nighttime riding with the baja designs light(which is now on a smart dimmer).
lightfighter is offline   Reply With Quote
Old 04-28-2013, 01:33 AM   #8486
Czechie
Czechie's Avatar
Oddometer: 75
690 Graphics to buy
Any tips for nice 690 graphics? more interested in any US on-line stores.
Thank you.
David
Czechie is offline   Reply With Quote
Old 04-28-2013, 05:32 AM   #8487
2degreesout
Oddometer: 868
That looks like a different bag...bigger,that looks like the bag I had on my 950.
Old 04-28-2013, 09:07 AM   #8488
poondangle
Slow
poondangle's Avatar
Oddometer: 1,319
Dumb question of the day
So I've got a '13 with 500 miles. Almost all of those miles off road. I had to ride the bike to a charity event this morning. This morning was almost all interstate. So I needed to pass a truck this morning...I opened up the throttle at 60ish. Immediately the revs come up to 7k plus, but not the power? I can't possibly need a clutch already? I tried in all gears, and it seemed to be a repeatable problem in every gear. Smooth roll on the gas, and no issue. Hammer the throttle, and for a small period of time, between 5k and 8k I'm just making noise? Any ideas?
poondangle is online now   Reply With Quote
Old 04-28-2013, 09:12 AM   #8489
ericGSsti
ericGSsti's Avatar
Oddometer: 538
That's the bigger back alright. I have that one for my 640 adv.
Good bag this one.
2003 KTM 525 EXC
2004 KTM 950 Adventure S. (GO!!!!!!!!!!!)
IBA membership no.35934
"In the spirit of adventure, open to all riders and carrying a message of friendship between all men"- Thierry Sabine 1977 founder of the Paris Dakar -
ericGSsti is offline   Reply With Quote
Old 04-28-2013, 09:58 AM   #8490
Oldbear
Don't want a pickle
Oddometer: 217
Have you checked your clutch fluid reservoir? The fluid level rises as the clutch wears so you could take a peek to see that it's not overfilled. The fluid level should be 4 mm below the top.
Oldbear is offline   Reply With Quote
Times are GMT -7.   It's 05:20 PM.
