Old 04-30-2013, 04:54 AM   #8506
sprouty115
sprouty115's Avatar
Oddometer: 1,479
Originally Posted by slidefighter View Post
Two questions:
1. Mine are spinning and there doesn't look to be any room in the nut well to get any JB Weld (or similar) in there to lock them down. Should I put the screw back in without the fairing as far as I can and then lever them out, fill the cavity with JB and then set them back in to cure?
2. Also, I can't find anything that screws into the smaller, middle screw hole in the picture. Was that something that was removed when my dealer did the canisterectomy, or something? Any idea what was there or what it is that I'm missing?
If it's a brand new bike I would take it to the dealer and tell them it's defective and let them sort it out before I pulled them out. Because once you do they're going to want nothing to do with it. If it's not new or they're unwilling to help, I'd contact KTM directly and see what they say.
Also that smaller, middle screw is empty on mine (2013) as well.
BTW, while you have the fender/cover off inspect two areas: the top of the tail light and both sides of the gas tank that it covers. Mine was rubbing and it was cutting a pair of notches in the tail light and there was significant abrasion on the tank on the left side of the gas tank. I needed to add some nylon washers between the cover and the nut to provide clearance in both areas.
sprouty115 is offline   Reply With Quote
Old 04-30-2013, 07:11 AM   #8507
DirtJack
DirtJack's Avatar
Oddometer: 1,569
Originally Posted by shipwrek12001 View Post
08 690
4 long and one short code.... already chged the fuel pump... w/ ca cycle pump...
failed last fall no codes, I'm sure someone has the video for that.. failed in my drive way a month or more ago setting the 4L1S code, chged the fuel pump... had a grnd failure a week ago, fixed that easily, then failed again yesterday 4L1S code again.... wtf........................
no sound from the fuel pump to be heard..........
In case you didn't see this response.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 04-30-2013, 05:23 PM   #8508
kingby
Oddometer: 87
Dumb things we do.
Keep in mind I am learning as I go here and am fairly new at bike maintenance.
I guess I wasn't reading the manual carefully enough and managed to incorrectly adjust the chain tension (don't ask... way too tight... I am an engineer who reads plans and dimensions all day and still managed to read the diagram wrong). Promptly went out for about 200 miles of riding over the next couple of days. Some dirt, some road.
Anyway, I just have this feeling that I didn't adjust the chain correctly, and of course do some reading online, re-read the manual and sure enough, I have the chain way too tight. I also read about the catastrophic potential of riding with a tight chain. So now I am a little worried.
I don't think I damaged anything, the transmission still is working fine, no leaks from countershaft seal (at least from what I can tell), sprockets and chain look no worse for the wear, no play in wheel bearings, so I think I am OK.
I have re-adjusted the chain using the method in the manual (push the chain up towards swing-arm from a point 30mm back from the chain slider with 5mm clearance to the swing arm itself). Now I am second guessing myself that it is too loose. My last bike was a Honda 450X a few years back and I recall the chain being tighter than this.
Do KTM chains operate a little looser than other bikes? What is everyone's thoughts on possible damage done to the bike due to my nice tight chain run, that just hasn't appeared yet?
kingby is offline   Reply With Quote
Old 04-30-2013, 05:48 PM   #8509
slidefighter
Gather it up, keep on...
slidefighter's Avatar
Oddometer: 336
Thanks for the info, guys. Unfortunately, my dealer is a 400 mile round trip away from here. I'll give them a call and see what they suggest though, that is a very good idea.
What a great bike!
Lee...
Slidefighter
"Never adopt an ideology that masks a lack of courage"
slidefighter is offline   Reply With Quote
Old 04-30-2013, 05:48 PM   #8510
sprouty115
sprouty115's Avatar
Oddometer: 1,479
Was the chain tight when the rear axle, swing arm pivot and front sprocket formed a straight line? If not, then absolutely no damage was done. If it was then it's a matter of "how tight". If there is no visible damage, no leaks, and nothing is bent (you should probably put a dial indicator on the front sprocket shaft), then you may be ok.
Old 04-30-2013, 06:20 PM   #8511
kingby
Oddometer: 87
Didn't specifically check at axle/pivot/sprocket alignment position before I backed off the tension, but I am pretty sure it was too tight. Instead of 5mm clearance from swing arm (as per manual), I had about 30mm play (as per my dumbass initial read of the manual).
I just went out and checked the countershaft/sprocket area. Definitely no play and no leaking. I don't have a dial indicator but spun the wheel/looking at the shaft and nothing appears bent to the eye. There were no abnormal vibrations when riding today (after loosening adjustment).
Hopefully I dodged the bullet. Suppose I'll just keep riding and see how it goes.
Update: Went out and checked again. By eye the CS spins straight as an arrow. Maybe I will pick up a dial indictor to double check. I assume this is a hardened piece of steel and and pretty tough to bend, with seals, sprockets and bearings giving out before the shaft. Also if it was bent, I would also assume the seal would surely be leaking (currently looks clean as a whistle). Some of the stories I have read show that the seal leaks if you look at it wrong.
kingby screwed with this post 04-30-2013 at 07:04 PM
Old 04-30-2013, 07:42 PM   #8512
sprouty115
sprouty115's Avatar
Oddometer: 1,479
Sounds like you didn't damage anything. I'd still borrow an indicator and then you can definitely not worry about it again.
Old 04-30-2013, 08:04 PM   #8513
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,586
Depends on the KTM, the PDS system that's on the race bikes requires a lot looser chain. The 690 has a standard linked suspension like most other bikes so there's no need to run it any looser then what you're used to.
Old 05-01-2013, 08:28 AM   #8514
kingby
Oddometer: 87
Before I go removing the CS sprocket to check the shaft with a dial indicator, will I need to replace the lock washer (the bent one), when I put it back together? Or can I just pound it as flat as I can and use a new area of that washer to bend against the nut?
Old 05-01-2013, 08:35 AM   #8515
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,586
You can reuse them a couple times.
Old 05-01-2013, 12:43 PM   #8516
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 847
Originally Posted by LukasM View Post
Is there anybody on this forum who has had frame damage or at least damaged the brake pedal mount while using the Rally Raid or Cleanspeed brake pedals on their 690?
The other way around ...
Because the oem pedal bends so easily, it is known the pedal tip punched through the cover once bended ... Keep your oem pedal and have things broken. Like Mitch said, it is your decision ...
Pauljr
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 05-01-2013, 12:51 PM   #8517
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 798
Pauljr
This is what happened to mine, though it looks like I saved the cover.
sdd04 is offline   Reply With Quote
Old 05-01-2013, 12:55 PM   #8518
motoged
motoged's Avatar
Oddometer: 908
Chain tension: One way to check tension is to stand to the right side of the bike, face the seat, place full weight of body on seat by leaning chest/gut on seat, so as to compress shock the most you can (grab the swing arm on left side of bike as you are putting body weight on seat and pull downwards to compress shock more) and check chain tension....it should have just a bit of slack.
That's my method for the pro-link as well as RFS smaller bore KTMs.
That as well as the method outlined in manual...
You will likely hear chain-slap when operating bike if tension is too loose.
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 05-01-2013, 01:06 PM   #8519
ScottDill
TANSTAAFL
ScottDill's Avatar
Oddometer: 4,339
Not sure about the bikes you mention, but on the 690, you just put it on the side stand and measure the tension. Basically you want it to almost, but not quite, be able to touch the swingarm.
ScottDill is offline   Reply With Quote
Old 05-01-2013, 02:52 PM   #8520
motoged
motoged's Avatar
Oddometer: 908
Yeah, we are all experts here.
Lotsa ways to manage your chain
Ged Schwartz
Kamloops , BC
Times are GMT -7.   It's 09:53 AM.
