Old 05-06-2013, 09:26 PM   #8521
lightfighter
where does this go?
Oddometer: 2,289
I think the clearance on those pelicans is comparable to any other hard bags you might buy...
lightfighter is offline   Reply With Quote
Old 05-06-2013, 10:40 PM   #8522
Oldbear
Don't want a pickle
Oddometer: 239
Originally Posted by kingby View Post
Just finished the break-in oil change on my 2012.
Anyone else run into this? I ordered the filters from the KTM dealer (I live in Newfoundland with no local dealer...I have to take a 16 hour ferry to get the the nearest dealer). The box for the short filter said 75038046100, but the number stamped on the filter itself was 75038046101. The number on the short filter I removed said 75038046100.
16 hours to the nearest dealer
I noticed the same thing while doing an oil change last year. The number on the box was 75038046100 but the short filter had 75038046101 stamped. On the oil filter service kit that I bought a few months later the short filter had the correct part number (75038046100).
The filters are exactly the same so no need to worry. Maybe they just printed the first batch with wrong number.
Oldbear is offline   Reply With Quote
Old 05-07-2013, 01:38 AM   #8523
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 2,214
Originally Posted by jmp5us View Post
what do you guys think about this rack? we fabbed this up custom made of 1/2 round bar.
Looks good! I used pelicans as well but smaller ones than yours. They are perfect size for over night trips. For longer tours (1-2weeks) I ditch the small top box for a Klim duffle bag.
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon is offline   Reply With Quote
Old 05-07-2013, 03:06 AM   #8524
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 189
Originally Posted by RoninMoto View Post
1. Motor/starter motor to frame, braided line
2. Battery to frame. (-) on battery
3. Regulator rectifier to frame. (2x green wires).
What I did was run a wire from regulator rectifier to battery - terminal. that way you know you will always have a good ground for charging.
You can either take the green wires and splice them to a #6 wire (i think that is what i used) and run it to the battery, or put a ring terminal on the #6 (both ends) and just make a jumper from the battery (-) where the RR connects to the frame. I did not worry about the frame to motor ground.
Another failure point is where the coil is bolted to frame - especially if you have the Rally Raid tanks and have the bracket to relocate it as this adds another earth failure point (the blind nuts). Had real problems with this and got tired of pulling tanks and doing roadside repairs. Ran a dedicated earth from battery terminal and have not had a problem in a year since.
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj screwed with this post 05-07-2013 at 03:11 AM
blakrj is offline   Reply With Quote
Old 05-07-2013, 04:28 AM   #8525
slidefighter
Gather it up, keep on...
slidefighter's Avatar
Oddometer: 368
Ronin: You mentioned #6 wire (U.S. size, I assume?) for the ground connection back to the battery from the ground on the coil. Did you really mean #6---I had forgotten just how big that is! No problem, I'm hooking it up tonight once I find the copper connectors I'm looking for, but #6 is really large---looks larger than the power wire to the starter, even!
Thanks for the suggestions on this, everyone.
Lee...
Slidefighter
"Never adopt an ideology that masks a lack of courage"
slidefighter is offline   Reply With Quote
Old 05-07-2013, 05:06 AM   #8526
kingby
Oddometer: 87
I know. We are pretty isolated here in Newfoundland. There are two ferries to leave the island (one is 16 hours and only runs in the summer and the other is 5 hours, but you have to drive 12 hours from St. John's to get to the ferry launch.) Of course you could take an 1.5 hour plane ride to Halifax, but not sure if I can fit the 690 in the overhead compartment.
We had two KTM dealers up until last year, but KTM Canada decided to pull both of the dealerships. I guess they weren't selling enough . (The entire island is only 500,000 people, so I am not sure what their expectation is )
Many of us KTM owners are pretty pissed that we have been left to fend on our own with no dealer/service support.
kingby is offline   Reply With Quote
Old 05-07-2013, 06:06 AM   #8527
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,604
Hi-Flo makes the KTM filters.. they are the same just not orange in color. You should just order a batch of them to have on hand for the future. an order of 5 pairs would set you up for quite a few miles of riding. The hi-Flo filter is usually half the price of the KTM branded one.
Another price comparison...those twin foam air filters we like to run:
KTM retail..orange color with KTM logo: $80
Generic Green foam with relevant logo: $50 to $60
parts Unlimited with black foam and no logo: whole sale about $6.
Seth S
Seth S is offline   Reply With Quote
Old 05-07-2013, 06:27 AM   #8528
NovaMoto
Oddometer: 133
The TPS values on the 11 are different from all other years. Your numbers are the same as mine +/- .1-2.
I havent been able to confirm the numbers anywhere. The 2010 manual doesn't have the proper settings for the 2011. I've asked KTM for the numbers but even my mechanic couldn't tell me what they should be. He said his scan/adjust tool just tells him when he has it right.
Originally Posted by Xico View Post
I'm having some problems with stalling with my bike.
Until now, I've checked
- All the fuel system from the pump to the injector
- Tried with another voltage regulator
But the problem continues.
Now I've conected the Tune ECU to see any problems.
Are these Throttle settings ok? I think I read somewhere of values of 0,5 or 0,7V... If they are not ok, how can I adjust them?
NovaMoto is offline   Reply With Quote
Old 05-07-2013, 06:43 AM   #8529
wiswoodsguy
Kmart shopper
wiswoodsguy's Avatar
Oddometer: 2,115
OH what a difference !!!!
Original owner farkled up my 690 with a 15/50 setup. While great for road use, it left wide open gaps that made off road riding rather cumbersome. A simple drop to a 14 was the key ingredient - really turned this bike around. Pulls really hard throughout, power wheelies like it should (I needed this for fun factor), and you can actually ride off road in 1st and 2nd, little buzzy at +60 but tolerable
Another great addition was the handle bar mounted Leo Vince timing retard switch.
My club was burning in some very tight single track for an upcoming event, trails that I should have used my 520 or 250 for - but used the 690 for testing purposes, just to see if larger CC bikes could tackle it. Plus I wanted to test out the new gearing combo. Mode 3 proved to be challenge for serious off road, even stalled a few times on some really difficult areas. Mode 1 was my saving grace, cuts the power ( for less than optimum grip areas), but really turned the 690 into a tractor. Never stalled once after that, powered up very difficult uphills, turned it into a great mountain goat. Only problem was, you have to cut the engine to change modes = minor
I was losing faith with this bike, almost thinking the 500 EXC route instead, but a few simple changes made me a believer. Think I'll keep it for a little while
wiswoodsguy is offline   Reply With Quote
Old 05-07-2013, 08:53 AM   #8530
kingby
Oddometer: 87
Thanks for the heads Up!
I can't find the Hi Flo set for the 2012 anywhere. Hi Flo website shows it in the catalog, but I can't find it for sale yet (I think it is a new release product as the 2012 short filter changed???).
Old 05-07-2013, 09:59 AM   #8531
jmp5us
MY DUDE!
Oddometer: 23
Originally Posted by Roadracer_Al View Post
Solid bar or tube?
I also used Pelicans, although mine are 1550s.
I have a KTM luggage rack, and I chose the Happy Trails mounting hardware. Mine are flush with the top of the seat, which makes packing additional gear on top easy. Yours look a bit low to me, and I worry that you might have ground-clearance issues.
i used solid bar, alot simpler to work with, and much stronger. I debated how high to mount the bags, but this seems to work fine so far. but only time will tell... i can always pull them off and with a few minutes with a drill move the angle of them, or raise them up
jmp5us is offline   Reply With Quote
Old 05-07-2013, 02:11 PM   #8532
kanur
cu new er
kanur's Avatar
Oddometer: 744
Hey wiswoodsguy, got any pics or more info on this. Sounds like a very useful mod.
Just cause I don't run my mouth don't mean I got nuth'n to say. Mike Cooley DBT
kanur is offline   Reply With Quote
Old 05-08-2013, 01:21 PM   #8533
wiswoodsguy
Kmart shopper
Oddometer: 2,115
the dreaded 690 tire saga
I know this has been beat to death in this thread, so here goes (Again)
I got 2000 miles out of my stock MT21's - pretty good most of you will say. They were great off road and decent on the road - just that they wore down quite quick, as most of you already know.
My question is< what size tire can I put on the 690 rim other than the stock ?? Ive been finding better deals on some 120's, but didnt know how it would effect the characteristics of the bike (handling, speedo, etc)
Looking at tires is about as much fun as shopping for window treatments with the wife. They all claim that they are great, but in the real world most of them suck for the purpose that you truly need them for.
A lot of you say to just buy cheaper tires, wear them out, replace - instead of buying a hefty tagged tire. Not sure which route I want to go.
So far my Choices are:
MT21 (again)
Scorpion
ED04 (120 size)
AC10 (120)
TC60 (120)
Any input ???
Old 05-08-2013, 01:49 PM   #8534
Hoots
Hoots's Avatar
Oddometer: 1,514
MT21 (again)
Scorpion
ED04 (120 size)
AC10 (120)
TC60 (120)
Any input ???
You haven't got the Dunlop 606 listed, and that's probably the best comparison to the MT21 - slightly longer lasting (IMO).
The ED04 and AC10 are both enduro tyres, whereas the MT21 and D606 are street legal knobbies - you'll get bugger-all mileage from an enduro tyre on a 690, especially if doing some transport legs on bitumen or hard gravel - they're also a bit skittish at speed.
The Pirelli 'Scorpion' is a whole group of tyres, from the dual-sport Scorpion Trail to enduro tyres like the Scorpion Extra-X - characteristics and mileage as expected for each type - the Scorpion Rally is well suited to the 690 - very similar to a TKC80, but cheaper.
I'm currently experimenting with a Pirelli MT43 trials tyre - had the pressure too high initially (20psi) and some excessive wear on central knobs - now running 11psi, and much better - excellent traction on all surfaces - better than anything else I've tried on loose steep rocky hills - nice ride characteristics, even at speed (ie hard charging long dirt roads) - wear will be the only issue - about 1,000km so far ...
PS: I'm not sure what a TC60 is ...
Hoots is offline   Reply With Quote
Old 05-08-2013, 01:51 PM   #8535
lm002e
Oddometer: 291
MT21 (again)
Scorpion
ED04 (120 size)
AC10 (120)
TC60 (120)
Any input ???
I REALLY like the Moto Z tractionator tires. DOT approved (if that matters) and available in 140 width read. I got 3700 miles out of the rear while doing the TAT last year. Decent price on them, too. YMMV
Luke
2004 BMW GS Adventure - sold - the greatest bike i've ever owned
2009 Suzuki DRZ-400S/SM - sold
2009 F800GS - the yella one
2010 KTM 530 XC-W Six Days
lm002e is offline   Reply With Quote
Times are GMT -7.   It's 12:52 PM.
