Old 05-05-2013, 07:22 AM   #8551
slidefighter
Gather it up, keep on...
slidefighter's Avatar
Oddometer: 336
Got the new fan switch and bash plate installed, but still waiting on a number of other parts to come in (kick stand cutout, etc) and so I've got time to do a couple of other "bomb proofing" things. I've read there are something like 6 frame grounds on the 690. Does anyone have pictures of where they all are located or a frame diagram that shows all of them? I'd be happy to photograph all of them freshly scuffed in location IF I knew where they all were...
Thanks,
Lee...
Slidefighter
"Never adopt an ideology that masks a lack of courage"
slidefighter is offline   Reply With Quote
Old 05-05-2013, 09:07 AM   #8552
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,667
Thanks,
Lee...
1. Motor/starter motor to frame, braided line
2. Battery to frame. (-) on battery
3. Regulator rectifier to frame. (2x green wires).
What I did was run a wire from regulator rectifier to battery - terminal. that way you know you will always have a good ground for charging.
You can either take the green wires and splice them to a #6 wire (i think that is what i used) and run it to the battery, or put a ring terminal on the #6 (both ends) and just make a jumper from the battery (-) where the RR connects to the frame. I did not worry about the frame to motor ground.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 05-05-2013, 11:42 AM   #8553
slidefighter
Oddometer: 336
Thanks, Noah. Headed out to the shop right now! Great to see that you are back on the road, but not so sure Az is the best place to be! Good luck in all your future adventures and thanks for the info...
Lee...
Slidefighter
Old 05-05-2013, 06:18 PM   #8554
jmp5us
MY DUDE!
Oddometer: 23
what do you guys think about this rack? we fabbed this up custom made of 1/2 round bar.
First we made just the top rack. I am about to take a 10 day adventure on the tat and decided some side bags would be nice. I choose to use pelican 1500's. I wanted to order the rack from happy trails, but they were 2 month's back order, which they neglected to tell me when i ordered. So we finished this rack saturday, just in time for me to leave wednesday.
I am happy with it so far, kinda sucks its welded to the top rack, but in the short time we had it was the easiiest way to do this. so this will just be my traveling rack, i will fab up another top rack when i get back.
jmp5us is offline   Reply With Quote
Old 05-06-2013, 06:39 PM   #8555
kingby
Oddometer: 87
Just finished the break-in oil change on my 2012.
Anyone else run into this? I ordered the filters from the KTM dealer (I live in Newfoundland with no local dealer...I have to take a 16 hour ferry to get the the nearest dealer). The box for the short filter said 75038046100, but the number stamped on the filter itself was 75038046101. The number on the short filter I removed said 75038046100.
They look identical (open on both ends... unlike the closed on one end for the 2011 and below filters).
I did some online searching, but couldn't find anything other than a post (from this thread) from Muffinman indicating he removed a 75038046101 from his bike and installed a 75038046100 http://www.advrider.com/forums/showp...postcount=6890
Any advice here?
kingby is offline   Reply With Quote
Old 05-06-2013, 08:59 PM   #8556
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,581
Solid bar or tube?
I also used Pelicans, although mine are 1550s.
I have a KTM luggage rack, and I chose the Happy Trails mounting hardware. Mine are flush with the top of the seat, which makes packing additional gear on top easy. Yours look a bit low to me, and I worry that you might have ground-clearance issues.
Suck, Squeeze, Bang, Blow
Roadracer_Al is offline   Reply With Quote
Old 05-06-2013, 10:26 PM   #8557
lightfighter
where does this go?
Oddometer: 2,265
I think the clearance on those pelicans is comparable to any other hard bags you might buy...
lightfighter is offline   Reply With Quote
Old 05-06-2013, 11:40 PM   #8558
Oldbear
Don't want a pickle
Oddometer: 221
16 hours to the nearest dealer
I noticed the same thing while doing an oil change last year. The number on the box was 75038046100 but the short filter had 75038046101 stamped. On the oil filter service kit that I bought a few months later the short filter had the correct part number (75038046100).
The filters are exactly the same so no need to worry. Maybe they just printed the first batch with wrong number.
Oldbear is offline   Reply With Quote
Old 05-07-2013, 02:38 AM   #8559
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 1,990
Looks good! I used pelicans as well but smaller ones than yours. They are perfect size for over night trips. For longer tours (1-2weeks) I ditch the small top box for a Klim duffle bag.
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon is offline   Reply With Quote
Old 05-07-2013, 04:06 AM   #8560
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 187
Another failure point is where the coil is bolted to frame - especially if you have the Rally Raid tanks and have the bracket to relocate it as this adds another earth failure point (the blind nuts). Had real problems with this and got tired of pulling tanks and doing roadside repairs. Ran a dedicated earth from battery terminal and have not had a problem in a year since.
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj screwed with this post 05-07-2013 at 04:11 AM
blakrj is offline   Reply With Quote
Old 05-07-2013, 05:28 AM   #8561
slidefighter
Oddometer: 336
Ronin: You mentioned #6 wire (U.S. size, I assume?) for the ground connection back to the battery from the ground on the coil. Did you really mean #6---I had forgotten just how big that is! No problem, I'm hooking it up tonight once I find the copper connectors I'm looking for, but #6 is really large---looks larger than the power wire to the starter, even!
Thanks for the suggestions on this, everyone.
Lee...
Slidefighter
Old 05-07-2013, 06:06 AM   #8562
kingby
Oddometer: 87
I know. We are pretty isolated here in Newfoundland. There are two ferries to leave the island (one is 16 hours and only runs in the summer and the other is 5 hours, but you have to drive 12 hours from St. John's to get to the ferry launch.) Of course you could take an 1.5 hour plane ride to Halifax, but not sure if I can fit the 690 in the overhead compartment.
We had two KTM dealers up until last year, but KTM Canada decided to pull both of the dealerships. I guess they weren't selling enough . (The entire island is only 500,000 people, so I am not sure what their expectation is )
Many of us KTM owners are pretty pissed that we have been left to fend on our own with no dealer/service support.
Old 05-07-2013, 07:06 AM   #8563
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,465
Hi-Flo makes the KTM filters.. they are the same just not orange in color. You should just order a batch of them to have on hand for the future. an order of 5 pairs would set you up for quite a few miles of riding. The hi-Flo filter is usually half the price of the KTM branded one.
Another price comparison...those twin foam air filters we like to run:
KTM retail..orange color with KTM logo: $80
Generic Green foam with relevant logo: $50 to $60
parts Unlimited with black foam and no logo: whole sale about $6.
Seth S
Seth S is offline   Reply With Quote
Old 05-07-2013, 07:27 AM   #8564
NovaMoto
Oddometer: 133
The TPS values on the 11 are different from all other years. Your numbers are the same as mine +/- .1-2.
I havent been able to confirm the numbers anywhere. The 2010 manual doesn't have the proper settings for the 2011. I've asked KTM for the numbers but even my mechanic couldn't tell me what they should be. He said his scan/adjust tool just tells him when he has it right.
Originally Posted by Xico View Post
I'm having some problems with stalling with my bike.
Until now, I've checked
- All the fuel system from the pump to the injector
- Tried with another voltage regulator
But the problem continues.
Now I've conected the Tune ECU to see any problems.
Are these Throttle settings ok? I think I read somewhere of values of 0,5 or 0,7V... If they are not ok, how can I adjust them?
NovaMoto is online now   Reply With Quote
Old 05-07-2013, 07:43 AM   #8565
wiswoodsguy
Oddometer: 1,954
OH what a difference !!!!
Original owner farkled up my 690 with a 15/50 setup. While great for road use, it left wide open gaps that made off road riding rather cumbersome. A simple drop to a 14 was the key ingredient - really turned this bike around. Pulls really hard throughout, power wheelies like it should (I needed this for fun factor), and you can actually ride off road in 1st and 2nd, little buzzy at +60 but tolerable
Another great addition was the handle bar mounted Leo Vince timing retard switch.
My club was burning in some very tight single track for an upcoming event, trails that I should have used my 520 or 250 for - but used the 690 for testing purposes, just to see if larger CC bikes could tackle it. Plus I wanted to test out the new gearing combo. Mode 3 proved to be challenge for serious off road, even stalled a few times on some really difficult areas. Mode 1 was my saving grace, cuts the power ( for less than optimum grip areas), but really turned the 690 into a tractor. Never stalled once after that, powered up very difficult uphills, turned it into a great mountain goat. Only problem was, you have to cut the engine to change modes = minor
I was losing faith with this bike, almost thinking the 500 EXC route instead, but a few simple changes made me a believer. Think I'll keep it for a little while
wiswoodsguy is offline   Reply With Quote
Times are GMT -7.   It's 08:28 AM.
