Old 05-12-2013, 10:13 PM   #8641
Canadian_Bacon
Oddometer: 201
Originally Posted by Christophe View Post
I have a 2011, I rode the first 1000 stock, then I switch to the akra exhaust and matched map and the foam air filter, and you're right, it makes a big difference in low end smoothness. I can ride it on the standard setting offroad when I am feeling more agressive, with no stalling issues, or back to the easy setting for slippery situations (I installed a switch on the handlebar). Love the bike, even if it threw me off once too often (finished that ride in an ambulance), but I am riding it again now.
Great glad to hear the mods make for a better beast offroad! Sorry to hear that you got injured though. But glad to hear that your riding again.
2010 KTM 690 Enduro r (Current)
LOADED 2008 KLR (Sold)
2000 Ducati Monster 750 (Sold)
Canadian_Bacon is offline   Reply With Quote
Old 05-13-2013, 06:24 AM   #8642
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,607
Pulled the engine out of the bike yesterday and pulled off the cylinder head. Now I just need to order some gaskets. The piston and valves had a little carbon buildup and sludge but no signs of pitting or detonation. The cylinder walls are scuff free and I can still see the factory cross hatching...all a good sign. I didn't see any signs of cracking along the cylinder walls so i am hoping the head gasket was the failure point. The head gasket being made of steel with a rubber upper and lower coating...was hard to find an intrusion point. I will probably through the head on a flat plate to be sure it is straight.
Luckily it was a nice day outside as I currently have no indoor space to work in. Hardest part about this job is keeping the chickens out of the tools
Seth S
Seth S is online now   Reply With Quote
Old 05-13-2013, 08:01 AM   #8643
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,277
How many miles does your engine have Seth?
How did the rocker arm bearings look? I heard those crap out after awhile.
If higher miles, are you going to re-ring and/or install a new piston?
Thanks for putting up wit hmy questions, my engine is now over 20K and after this season I'm probably going to tear into it and replace parts as needed. I'm sure with the airbox not sealing well my enginge sucked some dirt before I bought my bike and fixed the problem, thus wearing the rings at the least.
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is offline   Reply With Quote
Old 05-13-2013, 08:29 AM   #8644
Seth S
Seth S's Avatar
Oddometer: 4,607
My engine has about 10,000 miles on it and most of that has been trail riding or some form of racing. The engine has spent a fair amount of time tapped out in 6th gear. The rocker shafts looked clean and unmarred as did the rollers. I will look closer and can take some photos but I didn't see anything concerning when I pulled them out.
Seth S
Old 05-13-2013, 09:58 AM   #8645
MeinMotorrad
MeinMotorrad's Avatar
Oddometer: 1,495
Chickens
That's a Light Sussex in the last pic. Used to have these ourselves long ago.
MeinMotorrad is online now   Reply With Quote
Old 05-13-2013, 10:12 AM   #8646
Seth S
Seth S's Avatar
Oddometer: 4,607
Staying at my parents place due to a fall out on a house purchase. They currently have 36 chickens, 10 ducks, and 2 geese. They have several different kinds of chickens including a Bantam rooster and 2 Bantam hens. We get about 10 to 20 eggs a day from the chickens...we also get duck and goose eggs.
Seth S
Old 05-13-2013, 11:17 AM   #8647
motoged
motoged's Avatar
Oddometer: 908
Seth,
If the 690 needs a bit more pep, just give it a goose
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 05-13-2013, 11:33 AM   #8648
ramjet
ramjet's Avatar
Oddometer: 2,288
I just realized-that chicken probably knows more than I do now about tearing down bike motors. Sad. Really, sad.
"Moral courage is the most valuable and usually the most absent characteristic in men." Gen. George S. Patton
ramjet is offline   Reply With Quote
Old 05-13-2013, 11:45 AM   #8649
Seth S
Seth S's Avatar
Oddometer: 4,607
Originally Posted by motoged View Post
Seth,
Having been attacked by one of the geese and bitten by the damn thing a few dozen times I can say I understand where the phrase comes from.
Seth S
Old 05-13-2013, 11:49 AM   #8650
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,277
No need for photo's for my benefit, thanks for the reply.
I was just wondering what I might find when I tear mine apart.
I realize maintenance and use play a large part in how engines wear,
and each engine will undoubtedly wear differently.
Thanks again for your insite.
Assfault
Old 05-13-2013, 11:55 AM   #8651
Seth S
Seth S's Avatar
Oddometer: 4,607
Assfault
I think my headgasket failure was due to a failed water pump seal. I took the bike to Australia and raced it in the Safari Rally. I had a big crash on the 3rd day and could no longer ride but the bike was ok. Gave it to a friend to finish on as his stator had failed on his 530. On the last day he said the bike overheated and shut off. he filled the radiator with his camelback water and went another 40k before the temp spiked and the coolant light came on. ...the bike stalled and would not restart and he didnt want to kill it. That night when it came in on the recovery truck it started right up and ran fine.
Back in the USA I found the water pump seals were bad and replaced them. Flushed all the coolant from the inside of the engine and put in fresh oil. The bike ran well, came up to temp, had good power, and no smoke. Took the bike to a ride in Canada and made it about 40 or 50 miles before it started to smoke a bit in a slow woods section. Bike started consuming vast quantities of coolant. had to fill it with hose water at a house and made it to service where I was done. My theory is that the water pump seals failed in Australia and the bike got hot damaging the head gasket in the process. I replaced the seals and the head gasket could no longer seal the pressure and it then failed. I still need to have the head checked for flatness.
Seth S
Old 05-13-2013, 12:30 PM   #8652
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,740
Former 690 owner with a dumb question. What magic did KTM do in the later years to extend the service intervals? I had an 08 and I noticed the newer ones have longer intervals. Did they change anything or just juke the stats?
v8toilet is offline   Reply With Quote
Old 05-13-2013, 12:32 PM   #8653
Lexey63
AlcoDventurer
Lexey63's Avatar
Oddometer: 46
7200 km, 14 days, rrrrrggg rrrggg
http://zovff.ya.ru
Lexey63 is offline   Reply With Quote
Old 05-13-2013, 12:40 PM   #8654
Seth S
Seth S's Avatar
Oddometer: 4,607
They edited the owners manual
Seth S
Old 05-13-2013, 12:50 PM   #8655
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,122
rickypanecatyl is offline   Reply With Quote
Times are GMT -7.   It's 11:59 AM.
