Old 09-12-2011, 11:47 AM   #76
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 1,065
Originally Posted by Bill the Bong View Post
I revisted the rear sag, as that was the only variable which effectively changed. I found that to get in the 70 - 80 mm prescribed sag range, static sag was only about 6mm. Almost 75% of the shock's pre-load is used.
I've found that ~33% rider sag has worked well for me on all of my bikes regardless of total travel. I had Javier work my R shock to get 285mm travel so 95-100mm is where I started. I weigh ~230lbs with a 90nm spring set to 100mm rider sag, I ended up with 20mm free sag. I think that I'd prefer to bump up to the 95nm and it should be spot on for my weight. Forks still have stock .52kg/mm springs and are borderline too soft, but too close to justify a change... I think I just need a little stiffer valving and they should be good.
The Letter J is online now   Reply With Quote
Old 09-12-2011, 12:38 PM   #77
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
Originally Posted by Velociraptor View Post
My 2009 690r started cutting out along the highway today and finally just outright quit on me. My first KTM troubleshoot along the roadside. Probably not fuel related at fuel pump was priming, a good shot of fuel came out near the injector, and the injector was giving a good spray. Had a spare injector so threw it on and made no difference. Checked a lot of electrical stuff and found no obvious fault. Eventually bike started running again so made it about 40 easy miles before it started trying to die again but would catch and keep running until it eventually died again on city streets. Pulled stuff off again, got it going, rode 2 ft and died again. Pulled stuff off AGAIN and started wiggling wires while I tried to start it. Seems to be related to something in or around the big wiring bundle slightly to the front and right and below the spark plug. I started wiggling that and the bike would try and start then die as I moved it. It finally started for good and after that when I moved the bundle it had no effect. Bike ran fine the 10 miles left to home. Time to strip the bike and see if I can find the exact problem.
Exact same thing I've been experiencing, I hope the fuel pump fixes my problem but won't know until I get the pump.
Just say'IN
crankshaft is offline   Reply With Quote
Old 09-12-2011, 01:08 PM   #78
Velociraptor
TrackBum
Oddometer: 1,135
My bike did this for one day about a month or two after I bought it in August 2009 then has run fine ever since until yesterday. I am going to focus on the coil and other wiring first, but I also ordered one of those fuel pumps for the Husky. I am going to clean up the connections around the throttle body too and use dielectric grease.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 09-12-2011, 01:37 PM   #79
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 1,000
All things being equal, as the forks have the same 275mm travel as the shock, I'm going to measure front sag tomorrow. I'll then set the rear to the same sag. At least the 2 sides will be balanced. From there I'll make an assesment of what spring rate will be required.
FWIW, I'm at 30% of total travel for rear sag now. I was at 33%, but the action was harsh, I thought I was too low in the stroke.
Trickiest suspension I've ever messed with, balance is not nice.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 09-12-2011, 04:10 PM   #80
Sparrowhawk
Sparrowhawk's Avatar
Oddometer: 2,343
Visor Down says this new adventure model is based on the RC8 but I see a 690 engine there.
Looks like KTM took styling cues from the old F650GS.
Sparrowhawk screwed with this post 09-12-2011 at 04:23 PM
Sparrowhawk is offline   Reply With Quote
Old 09-12-2011, 04:21 PM   #81
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
Also looks like someone could use a Photoshop refresher course. That picture is a mess.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 09-12-2011, 04:36 PM   #82
crankshaft OP
crankshaft's Avatar
Oddometer: 14,005
Did BMW buy KTM when we weren't looking?
Just say'IN
Old 09-12-2011, 06:46 PM   #83
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,793
Well that thing sure looks ugly. Lets hope its just another ugly concept photo and if they make a real one they work all the ugliness out of it.
Seth S
Seth S is offline   Reply With Quote
Old 09-12-2011, 07:48 PM   #84
Tarheel Wheeler
Around
Tarheel Wheeler's Avatar
Oddometer: 3,648
If it does look like that then I saved a bunch of money.
Adversity is the state in which man most easily becomes acquainted with himself, being especially free of admirers then. John Wooden
"Get to riding or get to dying"...http://www.youtube.com/watch?v=K_T41kJm-PE
Tarheel Wheeler is offline   Reply With Quote
Old 09-12-2011, 10:00 PM   #85
andykeck
Oddometer: 109
Should be Wednesday, I think.
andykeck is offline   Reply With Quote
Old 09-12-2011, 10:36 PM   #86
Velociraptor
TrackBum
Oddometer: 1,135
Had a closer look at the wiring tonight. No obvious shorts but one lead on the coil was a little loose. Started the bike and wiggled it around to no effect. The engine only died when I almost pulled the lead off, but there certainly could have been a loose connection there that was causing a problem that I fixed by wiggling the wires around yesterday. I crimped the connector and now it fits tight. I checked all the connector plugs around the throttle body and all looked clean. Added dielectric grease anyway. Nothing left to do now but some test riding.....
2014 KTM EXC 500
2002 RC51 SOLD
Old 09-12-2011, 10:47 PM   #87
Bill the Bong
Supern00ba
Oddometer: 1,000
The coil connectors have been a common problem in South Africa as well. I've reported on it in the old, recently demised super threat
Old 09-13-2011, 03:14 AM   #88
Bike Nomad
Bike Nomad's Avatar
Oddometer: 321
Originally Posted by bobzilla View Post
anybody remember what rear rotor will work for the 690? bent mine and need it asap
thanks
btw 1800 miles off road zero problems with anything but the bent rotor. fi worked flawlessly. thanks to those that helped me sort the maps.
bobzilla,
Correct me if I'm wrong--but I seem to recall you use the Scott's shark fin rear rotor protectors ( which are pretty beefy) on all of your off road bikes. If that is the case ( and I know you are a man of few words) would you mind briefly sharing the story of how you bent the rear rotor?
DON'T GET IT TWISTED --ITS DUAL SPORT! NOT DUEL SPORT!
Bike Nomad is offline   Reply With Quote
Old 09-13-2011, 03:35 AM   #89
Bike Nomad
Bike Nomad's Avatar
Oddometer: 321
Well its not a 690, but this link http://www.youtube.com/watch?v=zeswy...layer_embedded gives video proof that KTM does quality assurance checks at the end of the assembly line--at least on their 2011 RC8R 1190s. It's a 5 min video, kinda interesting. About 3/4 the way through the camera guy zooms in on a sign posted as a warning to the operator of the testing equipment. I'm curious as to why if the factory is in Austria (I'm assuming)--why the sign is in English and not German?
Old 09-13-2011, 05:23 AM   #90
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 928
Originally Posted by Bike Nomad View Post
bobzilla,
im not too sure how it hapened either as i do use scotts protector. i do ride it in lots of rocks and have destroyed the chain guide also.
is there a good chain guide replacement?
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Times are GMT -7.   It's 11:02 PM.
