Old 06-19-2013, 08:14 AM   #9361
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,004
Originally Posted by touser View Post
is there a small inline fuel filter on the 690? Not the one in the tank.
Only the one in the tank.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is online now   Reply With Quote
Old 06-19-2013, 08:22 AM   #9362
sprouty115
sprouty115's Avatar
Oddometer: 1,498
Originally Posted by TheMuffinMan View Post
~23.8-26 celsius (75-80 Fahrenheit). Heavy stop and go traffic the radiator fan was running almost constantly. I filled all three tanks on the bike that morning and had about 30 miles on them. After about 50 minutes riding through stop and go traffic gas was leaking out of the right RR tank vent and cap. The cap was installed tightly.
When I removed the left tank cap I could see the gas level was low and I could see it boiling when I started to take the right cap off gas was pouring out so I retightened the cap, pulled over and let it cool down for five minutes before continuing home. Later in the evening I looked at the tanks again and the left and right tanks had equal amounts of fuel. I had this happen on my 950 adventure when I installed a second radiator fan on the right side.
I'm running the stock header pipe with an FMF Q4 slip o with an EVO-1 airbox and FI map. 2012 690 Enduro at 1830m elevation (6000ft).
I am curious to see if I'll have similar problems on trails in the mountains where my 950 had issues with heat and boiling the gas.
As far as vibrations coming through the tanks it is very annoying, no one else has experienced this? they are not minor; and I'm running a TKC-80 up front and a Metzler Sahara 3 on the back, both are balanced. The stock side panels did not vibrate from what I could tell.
Is the tank vent functioning? While gas can boil at a much lower temperature than you might think it, normally doesn't happen because it evaproates relatively quickly. However, if you increase the pressure of the vessel containing it you will lower the temp even further
Oops, got that backwards, lower pressure = lower boiling point. So much for trying to remember 10th-grade science...
sprouty115 screwed with this post 06-19-2013 at 08:30 AM
sprouty115 is offline   Reply With Quote
Old 06-19-2013, 08:26 AM   #9363
TheMuffinMan
Oddometer: 6,004
Originally Posted by sprouty115 View Post
Is the tank vent functioning? While gas can boil at a much lower temperature than you might think it, normally doesn't happen because it evaproates relatively quickly. However, if you increase the pressure of the vessle containing it you will lower the temp even further...
I believe so. When I removed the left gas cap the fuel did not stop boiling until 5 minutes had passed.
Old 06-19-2013, 08:54 AM   #9364
HeadinSouth
vroom!
HeadinSouth's Avatar
Oddometer: 96
Hey guys!
Read through most of the posts and wanted to thank you all for adding your mods and thoughts.
That being said I cant help being frustrated that i cant find a summary of must do to the bike and proper tuning of the engine.
Electrical connections break or were not done correctly from the factory, the fuel tank may come lose, the throttle may fall apart, the bike might just start stalling on its own, the fuel pump seems to stop working after a certain time, etc.
Some people put on pipes and tune, others dont. Some mod the airbox, tune and other dont. Then there is a huge amount of tuning codes available. Some people just put in a new ECU.
If someone knows where I can get a full one page summary of the info that would be very helpful.
This is either the most complicate motorcycle on the planet or Im terrible with Google.
Thanks guys.
HeadinSouth is offline   Reply With Quote
Old 06-19-2013, 09:05 AM   #9365
TheMuffinMan
Oddometer: 6,004
Originally Posted by HeadinSouth View Post
Hey guys!
Thanks guys.
Check out the http://ktm690.info hall of wisdom. It's not really a how to setup a new bike but it's a compilation of common breaks and fixes or mods.
Old 06-19-2013, 09:14 AM   #9366
sprouty115
sprouty115's Avatar
Oddometer: 1,498
Hey guys!
Thanks guys.
I don't know of a one-page summary, but this will get you most of the way there with a few pages of reading.
http://ktm690.info/index.php/690_Hall_of_Wisdom
http://www.advrider.com/forums/showthread.php?t=846888
BTW, it is perfectly acceptable to ride the bike 100%-bone-stock and to expect to have a wonderful time. It is not, as some of might like to imply, a time-bomb ready to drop dead in the darkest corner of the earth. So if you just plan on driving around town you can pretty much ignore all of the mods with no greater risk of mechanical issue than any other modern bike.
Old 06-19-2013, 11:25 AM   #9367
HeadinSouth
vroom!
Oddometer: 96
Thanks guys.
If you find someone that has spent a ton of time with a dyno and trying different air box mods and pipes, please let me know.
Old 06-19-2013, 11:54 AM   #9368
SKINNY
SKINNY's Avatar
Oddometer: 645
In your earlier post you mentioned running a non stock map...
Stick your fingers between the pipe & the tank after it's warmed up
If it's hot enough to be uncomfortable, you have map problems...
Is it possible that what you think is boiling fuel is actually fuel gravity flowing into the tank?
SKINNY is offline   Reply With Quote
Old 06-19-2013, 11:59 AM   #9369
TheMuffinMan
Oddometer: 6,004
Not quite sure what you mean by that, but it was definitely boiling. The way their fuel taps are setup wouldn't allow for bubbling unless it was boiling. These were not small bubbles either in the left tank it was somewhat violent churning.
My pipe was way to hot to do that even on the stock map. My map is the KTM factory evo-1 airbox map so I doubt it would make the bike run hotter than normal. The heat feels the same on the left side if not a bit more concentrated (which I would expect) since the tanks were installed.
Old 06-19-2013, 12:43 PM   #9370
sprouty115
sprouty115's Avatar
Oddometer: 1,498
He's was asking if there was an imbalance in the volume of fuel in one tank compared to the other and if the "boiling" was simply gas flowing from the tank with more fuel into the tank with less.
Old 06-19-2013, 02:05 PM   #9371
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 961
Fuel transfer between the Evo tanks is really slow, so its unlikely. In my opinion, there will be signs of heat damage to the lower left tank if the exhaust set-up was the cause. I wrapped heat bandage around the heater and stuck aluminium heat tape to the tank, but I think I was over-cautious.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 06-19-2013, 03:28 PM   #9372
SKINNY
SKINNY's Avatar
Oddometer: 645
I put exhaust tape on my left side tank, but it came unstuck after 1 or 2 days' riding....
based on the amount of heat coming off my 2012 with stock map...I'd say something is wrong if you're getting enough heat to boil the fuel.
I suppose you could get a cheap industrial thermometer and see exactly what temps you're dealing with..
Rally Raid posted on this thread (I think) that they were having trouble with the Akro header pipe over-heating the left tank, but no info on the stock header pipe
Old 06-19-2013, 04:37 PM   #9373
DirtJack
DirtJack's Avatar
Oddometer: 1,580
Like you, I had fuel boiling issues when I installed a second fan on my 990. I tried reflective insulating tape on the right tank where the fan output was hitting the tank. The final solution was to fab a deflector for the right fan similar to the deflector used on the left side tank. I'm guessing that the 690 fan needs a deflector so that its output does not go directly on the left side Evo tank. Before I installed the deflector on my right 990 fan, the right tank would get so hot you could not touch it and fuel would boil if it was high enough in the tank to reach the hot portion of the tank.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 06-19-2013, 06:31 PM   #9374
TheMuffinMan
Oddometer: 6,004
Yeah, after thinking about it for a bit that might be the case with the 690. I'm going to check it out a bit, though as long as I'm moving it's not a problem; it's only in heavy stop and go traffic. I will need to find a solution anyway since the trails here have lots of slow 5-15mph climbing and generally are not gentle on bikes as far as heat goes.
I also fabbed a deflector for the 950's right side fan and that solved problems on that bike.
Old 06-19-2013, 06:39 PM   #9375
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 974
Originally Posted by Bigbugberg View Post
Anyone put a 150/18 on the back???
Will it fit?
I ran a 150/90/18 Terraflex on the back for about 1500 miles. It would contact the underside of the tank with a decent hit, but I think that with a more typical 150/70/18 you would have less clearance issues. As far as fitment on the 2.5" wide rim, it fit just fine but is probably a bit more "crowned" than most people prefer.
I can ride my bike with no handlebars, no handlebars, no handlebars - Jamie Laurie
The Letter J is offline   Reply With Quote
Times are GMT -7.   It's 10:09 PM.
