Old 07-09-2013, 07:29 PM   #9601
Kirkster
Parts Murderer
Oddometer: 296
Originally Posted by poondangle View Post
I had the same problem, minus the abuse, on mine after only 500 miles. The clutch was replaced under warranty.
Never had an issue with my clutch till today. Over 5k on the bike.
TAT 2013 the "I'm Just Sayin" tour
BMW 2007 R1200R
2012 KTM 690 R
07 WR 450F
Kirkster is offline   Reply With Quote
Old 07-09-2013, 07:43 PM   #9602
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 1,001
So what is the question? Your clutch is burnt, you need a new one.
It is really easy to change and I could easily do it trailside if I had the parts... being that you are on the road, your best bet might be ordering a cheap(er) replacement (only because it is more likely to be in stock) online and having it overnighted.
EBC part #DRC205 is a complete kit to fit the 690 and there are offbrand variations on Ebay by "Outlaw Racing" for very cheap. I don't know the KTM part number for a "kit" but if you buy 3, 28, 29, 30, and 31 in the listed quantities here: http://partsfinder.onlinemicrofiche....&c=0&d=-CLUTCH you will have the same thing.
outlaw kit: http://www.ebay.com/itm/Outlaw-Racin...1a9a9e&vxp=mtr
EBC kit: http://www.ebay.com/itm/08-KTM-690-E...28e14e&vxp=mtr
EBC friction plates only: http://www.ebay.com/itm/EBC-Clutch-F...6e7915&vxp=mtr
One question for you: does your clutch lever feel abnormally stiff and go back to normal(ish) when cool?
I can ride my bike with no handlebars, no handlebars, no handlebars - Jamie Laurie
The Letter J screwed with this post 07-09-2013 at 07:53 PM
The Letter J is offline   Reply With Quote
Old 07-09-2013, 07:58 PM   #9603
Kirkster
Parts Murderer
Oddometer: 296
No it does not feel stiff. Feels normal.
K
BMW 2007 R1200R
2012 KTM 690 R
07 WR 450F
Old 07-09-2013, 08:07 PM   #9604
Velociraptor
TrackBum
Oddometer: 1,122
This is a nice video to try and repair the clutch if you cannot find a new clutch pack.
http://www.youtube.com/watch?v=X0hnN4Hi8jE
You can lay the bike over on the left side and pull the clutch apart without having to drain the oil. Also KTM talks about some special screw or bolts to tension the plates while you unscrew the bolts holding the springs. Not necessary in my experience.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 07-09-2013, 08:11 PM   #9605
slidefighter
Gather it up, keep on...
slidefighter's Avatar
Oddometer: 365
Palmstatecrawler and KTM Mitch: I've been out of town for a couple of days; sorry for the late reply but definitely thanks for the information on getting the swingarm back together. I'll pull it back apart and start over a bit from the front. It is definitely tricky!
Again, thanks!
Lee...
Slidefighter
"Never adopt an ideology that masks a lack of courage"
slidefighter is offline   Reply With Quote
Old 07-09-2013, 08:12 PM   #9606
Kirkster
Parts Murderer
Oddometer: 296
I have. Lots of clutch exp on my Yamaha, so I know the trick about laying it over. Will order a clutch pack if I need one. Easy enough to change on the side of the road or in front of the motel door for that matter...
K
BMW 2007 R1200R
2012 KTM 690 R
07 WR 450F
Old 07-09-2013, 08:15 PM   #9607
The Letter J
Oddometer: 1,001
Okay, that supports your frictions being toast. If you had lost fluid in the system the clutch would not disengage, opposite of the symptoms you are having. If the lever was hard, you either just momentarily got the frictions hot (causing them to swell, which sometimes goes back to normal after cooling) or you had water in the clutch fluid that got hot and boiled. Your situation sounds pretty cut and dry... burnt clutch.
For the time being, just downshift if you feel it starting to slip, accelerate slowly, keep your speed down and try not to lug the motor... your clutch will have more mechanical advantage over the wheel in a lower gear, making it less likely to slip. Ideally you'd just stop traveling and replace it, but taking it easy might keep you moving.
I had to replace mine right at 5k miles and really should replace it again now at ~12k miles.
Old 07-09-2013, 08:32 PM   #9608
Kirkster
Parts Murderer
Oddometer: 296
Well if. Is is slipping in the morning I will order a whole new clutch pack from somewhere and get it overnighted.
Thanks for the quick response. Will find out in the morning...
K
BMW 2007 R1200R
2012 KTM 690 R
07 WR 450F
Old 07-09-2013, 11:09 PM   #9609
Fabless
Oddometer: 34
Preload adjust without removing shock: one solution
Originally Posted by burmbuster View Post
Picked up the new 690 today. Stormed the entire way up there and back, over 3 hours each way. [...]
I decided to set the sag on the shock as the height was a bit high and it only had about two inches of sag from the dealer.
Took the weight off the rear wheel and started backing off the spanner nut using a piece of key stock. Got it about 3/16" up and was afraid the spanner nut wouldn't last much longer with the beating so it looks like I will have to remove the shock and adjust it outside of the bike. That sucks.
Brad
I bought this spanner wrench: http://www.amazon.com/gp/product/B00415XAH0
Using a grinder, I contoured the handle to improve its reach around the shock and trellis frame so I can adjust preload without removing the shock.
Cheap and easy.
-Fabless
Fabless is offline   Reply With Quote
Old 07-10-2013, 12:22 AM   #9610
Oldbear
Don't want a pickle
Oddometer: 232
Originally Posted by Kirkster View Post
Well we made a wrong turn on the TAT in Utah today. I really abused my clutch in deep sand for a long time. When we finally made it back to pavement my clutch was slipping big time. In 6th on the highway anything over 4500 rpm and the clutch would start slipping. Where should I start looking?
Look in the manual and nothing. There does not appear to be any leakage from the master. I have not looked at the fluid in e slave yet. Exhausted...
Might be a stupid question but did you check the fluid level in the master?
If it was on the upper level it's probably overfilled now after the abuse. That's probably the most common reason for people burning their clutches on low mileage.
Oldbear is offline   Reply With Quote
Old 07-10-2013, 04:32 AM   #9611
burmbuster
burmbuster's Avatar
Oddometer: 1,444
Cheap and easy.
-Fabless
Awesome. Thanks, Fabless
_______________
2013 KTM 690 Enduro R
burmbuster is offline   Reply With Quote
Old 07-10-2013, 06:59 AM   #9612
Kirkster
Parts Murderer
Oddometer: 296
Stupid question but is the DRC205 going to fit a 2012 690 enduro?
BMW 2007 R1200R
2012 KTM 690 R
07 WR 450F
Old 07-10-2013, 07:37 AM   #9613
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,575
My guess would be yes. But I would compare the part numbers for the stock clutch pack from say a 2010 with a 2012 and see if it is different. The clutch has always worked well so I find it unlikely that they did any major changes on it.
Seth S
Seth S is offline   Reply With Quote
Old 07-10-2013, 08:36 AM   #9614
Kirkster
Parts Murderer
Oddometer: 296
I did the stare and compare and the part numbers are the same.
Parts are ordered next day air...
Thanks guys...
BMW 2007 R1200R
2012 KTM 690 R
07 WR 450F
Old 07-10-2013, 09:01 AM   #9615
Jarrek
Oddometer: 23
Hey guys!
Quick question: I've just received my UNI Filter (NU-1417ST) but it's not preoiled, so I gotta buy some filter oil. I decided to go with oil spray because it's much more convenient. What brand would you use? Is Motul good? I'm looking at Motul A2 right now.
Jarrek is offline   Reply With Quote
Times are GMT -7.   It's 02:21 AM.
