Old 07-20-2013, 07:47 AM   #9856
DirtJack
DirtJack's Avatar
Oddometer: 1,515
Originally Posted by Harty View Post
Been out on the 690 today and it usually starts on the button, but it started taking a few turns to fire up, rode home and got on driveway, stalled the bloody thing, now it just won't fire up! (Yes I have a full tank of fuel), so start with new spark plug??? Bike has been in the shade for 30 mins, it started straight up!
Next time this happens, when you try to start the bike listen for the fuel pump prime noise when you turn the key on. If you don't hear the buzz, the bike won't start. Usually waiting a few minutes will bring back the fuel pump prime and then the bike will start. Read this thread. Your fuel pump needs replacing. Most of us run the California Cycleworks pump and some even carry a spare. I haven't heard of a failure of the CA Cycleworks pump yet. Cheers.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is online now   Reply With Quote
Old 07-20-2013, 08:10 AM   #9857
StepOnIt
Assitoner
StepOnIt's Avatar
Oddometer: 1,009
Laugh Play on words
Originally Posted by shipwrek12001 View Post
Well, ordered the Mosfet, now I'm grounded for 10 days or so being in Canuck land... I sure hope this isn't a lesson in spending money. .
That sucks about your bike, wish i was closer and could give you a hand or at least pull parts off my working bike and see if that helps .
Also I am sure you are not a grounded type of man
The road less traveled is the road I travel more.
"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." Dean Martin
StepOnIt is offline   Reply With Quote
Old 07-20-2013, 08:33 AM   #9858
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,665
In the meantime.. you could use just about any R/R to get you out riding. When mine failed in Tajik, I installed an R/R from a 95 kawasaki. It bolts up. Splice the wires and go ride. Its still going 15,000km later.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 07-20-2013, 09:15 AM   #9859
777
Oddometer: 92
Rear tail rack
I just bought a rear rack for my 690, it seems to fit over the petrol cap area and has a lifting mechnisim, any seen this before and know how to fit it?
777 is offline   Reply With Quote
Old 07-20-2013, 09:20 AM   #9860
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,003
Pics would help. Several versions out there.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is online now   Reply With Quote
Old 07-20-2013, 09:34 AM   #9861
777
Oddometer: 92
Not sure how to post pic, but it seems you remove the grab handles and it fit over where the handles will go COVERING the petrol filler cap, the plate has a lever you pull and it lifts up on a hinge system to allows acces to filler cap.
Old 07-20-2013, 11:45 AM   #9862
Bigbugberg
Meatbucket Supreme
Bigbugberg's Avatar
Oddometer: 324
Top End Oil
Looking at PalmStates 690 above, I see an oil line off the filter cover on the right side. My 2010 does not have this. I assume it pushes oil up to the top end spraying the rockers etc.
Question, can the earlier models be retrofitted for this extra oil? Would I want to do this? Does this help alleviate the cam spalling of previous years?
Inquiring minds want to know.
Never half-ass anything, always use your full ass
2010 KTM 690 Enduro
2009 KTM 400XCW Plated
Bigbugberg is offline   Reply With Quote
Old 07-20-2013, 11:51 AM   #9863
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,193
Do the mount bars look like this?
KTM 690 SMC/Enduro Rear Top Bracket
KTM Part Number: 76512027050
cyborg is offline   Reply With Quote
Old 07-20-2013, 12:02 PM   #9864
BIG-E
AKA; Mongo-E
BIG-E's Avatar
Oddometer: 2,062
Originally Posted by matt33 View Post
I use balancing beads in my tires. My shop installs them with the tires for a modest fee ($15-ish per tire). 2 oz in my tires and they are very smooth at speed.
http://www.motorcycle-superstore.com...ing-Beads.aspx
+1!
2 oz's in a 908 and you are good to GO!!!
If your wheel fills up with mud, all bets are off, until the wheel is clean. Same with regular weights.
I even carry 2 oz's in my tool pack in case I loose all the beads from a flat.
Everyone says I am crazy, but I love the Dyna-Beads..
"If my Technique Improves, so will my riding"!
BIG-E is offline   Reply With Quote
Old 07-20-2013, 12:05 PM   #9865
DirtJack
DirtJack's Avatar
Oddometer: 1,515
Rocker Woes
Reading the discussion of rocker issues a week or so ago and my bike being occasionally hard starting, I began to fear I might have rocker issues too (15,400 miles on my 2008). So I ordered up replacement rockers (they are backordered like others had said). Well I needed to check valve clearance (plus a ton of other maintenance things to prep for a trip to Ouray August 9) anyway, so off with the valve cover.
Some scoring on the outer surface of the rollers. The exhaust valves are outside the upper range (.008 fits, but .009 does not). Intakes are at the upper limit of proper range (.004 and .005). The side clearance of the roller is above .01 on both rollers. Anyone know what the side clearance should be?
Hope I get my replacements before August 9.
2008 KTM 690 Enduro
DirtJack screwed with this post 08-01-2013 at 07:42 PM Reason: Correct valve clearance values
Old 07-20-2013, 12:17 PM   #9866
DirtJack
DirtJack's Avatar
Oddometer: 1,515
Originally Posted by cyborg View Post
Here is a simple, easy to install voltage monitor that will show you under or over voltage conditions.
These are great. I have them on my 690 and 990. Great to see exactly what is happening to bike voltage levels. You can see all of the indicator levels as you roll up to a stoplight with LEDs on, Euro light on high beam, Heated Grips and the dual fans start to run. Flashing green indicates RR failure. Fortunately haven't seen that one yet.
2008 KTM 690 Enduro
Old 07-20-2013, 01:58 PM   #9867
shipwrek12001
Shipwrek
shipwrek12001's Avatar
Oddometer: 2,086
I wish I had a bike to share parts for trouble shooting.....
fuel pump in the spring, v-regulator now... what is up for the fall?
Fak it, just go.... away
shipwrek12001 is offline   Reply With Quote
Old 07-20-2013, 02:04 PM   #9868
777
Oddometer: 92
Nope it is a flat plate the mounts on the holes were the grab handles are the holes closer to the seat has a hinge on the flat plate and the holes near the tail light has a relese spring you pull and lift the flat plate up to get to the filler hole
Old 07-20-2013, 02:27 PM   #9869
Biped
NooB Again
Biped's Avatar
Oddometer: 321
That is just an extension hose to an oil pressure switch for low pressure warning. The rally bikes had the switch on the filter cover, wonder why the added the extension hose. Not sure if the earlier models have wiring to use this function.
If it moves and it should not, duct tape it, if it does not move and it should WD40 it!
Biped is offline   Reply With Quote
Old 07-20-2013, 02:57 PM   #9870
mbrick
Oddometer: 126
I have a few questions for a 690 rebuild:
1. What is the proper piston ring orientation? 120 each apart for all 3? Which one forward? The manual did not say anything that I could find. I also thought to place the oil ring spring joint opposite the ring opening.
2. These two parts for the clutch, is #1 supposed to be flat? I noticed both of them looked like bellville springs. And if they are, which direction does the inside face on #1? These both fit underneath/within that larger ID friction disk.
Also, there should be engine oil in the cavity behind the slave cylinder, surrounding the push rod, correct? I didn't see anything in the basket area that would seal it off.
mbrick screwed with this post 07-20-2013 at 03:13 PM
mbrick is offline   Reply With Quote
Times are GMT -7.   It's 08:31 AM.
