Old 07-31-2013, 03:44 AM   #10006
DirtJack
DirtJack's Avatar
Oddometer: 1,600
Originally Posted by cyborg View Post
Thanks Steven!
So the way I read it:
Cluster (32-pin)->Remote (4 wire)
18 ->1-> permanently connect to a chassis ground
02 ->2-> UP (temp connect to ground when button pushed)
21 ->3-> DOWN (temp connect to ground when button pushed)
19 ->4-> MODE (temp connect to ground when button pushed)
Does that look right? Is your information from a 990?
I checked these pin numbers against the 2012/13 690 Enduro R P10 Combination Instrument (Display) 32-pin wiring shown the the '13 shop manual wiring diagram. What I find is:
Cluster Pin
18 = currently unused
02 = used, orange wire, ground
21 = currently unused
19 = currently unused
Pin "02" (2?) concerns me because is is being used currently as a ground, so that would probably not work as the UP button.
Thoughts from the collective?
These are all the pins currently populated on my 2013 display (P10) connector)
Some of the following may not apply because it is for a 2008 690E which has a similar (same?) instrument as current model 690's. Maurizio did a very nice installation of a TrailTech Vector on his 2008 690E which was documented in the old MegaThread and recently redone at Maurizio's Vector Installation. He gives the following pin out's:
Pin 2 - Ground
Pin 4 - FI fault Light
pin 7 - Fuel Reserve Light
pin 11 - Neutral Light
pin 12 - High Beam Light
pin 15 - Ground
This doesn't have much to do with the Trip master application except to confirm that on the 2008's , pin 2 is ground. High Beam light is on 12 rather than 8.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack screwed with this post 07-31-2013 at 04:26 AM
DirtJack is offline   Reply With Quote
Old 07-31-2013, 09:59 AM   #10007
fluff34567
fluff34567's Avatar
Oddometer: 1,104
Originally Posted by sprouty115 View Post
I'm guessing you haven't had the surreal experience of an 80mph tank-slapper?
Originally Posted by Albie View Post
One of those will make you shit your pants, doing one of those at 140 will make you see God DAMHIK!
yep it happened to me at 130kmh whilst passing a truck - i thought fall of truck or barrier side - not good!
it also happens at 80kmp with the bike unloaded.
its down to my front tyre which is a bit worn
fluff34567 is offline   Reply With Quote
Old 07-31-2013, 10:00 AM   #10008
fluff34567
fluff34567's Avatar
Oddometer: 1,104
îm looking for a 14 tooth front sprocket - is there a KTM part that will fit or is it aftermarket only ?
Old 07-31-2013, 10:47 AM   #10009
DirtJack
DirtJack's Avatar
Oddometer: 1,600
Just put one on a couple of days ago. KTM part number 58033029014, $26.50
2008 KTM 690 Enduro
Old 07-31-2013, 11:06 AM   #10010
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 843
Thanks for the part number for the sprocket. This brings up a problem I'm having that maybe you all can help me with. When I go to KTM-Parts and go to open the different catalogs, like sprockets, what happens is the image of all the sprockets will be there for literally a second, and then the page is blank. Doesn't matter which catalog I try to open-it's the same.
I'm using IE10, but have had the same results with Google Chrome.
Any ideas?
sdd04 is offline   Reply With Quote
Old 07-31-2013, 12:06 PM   #10011
fluff34567
fluff34567's Avatar
Oddometer: 1,104
excellent thanks.
Old 07-31-2013, 01:37 PM   #10012
brianpc
Oddometer: 317
Hey all,
Apologies for just chiming in here with a q, but it's semi-related to all the 690 pics posted in this thread (and my q doesn't warrant a full thread haha):
The stock 690E mirrors are "ok", semi-usable when they're not vibrating to hell. Anybody have a good aftermarket mirror setup that works well but is less obtrusive / tucks away when offroad? Thanks in advance.
brianpc is offline   Reply With Quote
Old 07-31-2013, 01:42 PM   #10013
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,813
Double Takes! Best mirror I've tried.
Old 07-31-2013, 01:51 PM   #10014
Hoots
Hoots's Avatar
Oddometer: 1,573
+1
I've got the longer RAM mount (only because I was leant / given them) and will change to shorter at some stage ...
Hoots is offline   Reply With Quote
Old 07-31-2013, 01:52 PM   #10015
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,128
+1 on the doubletake mirrors.
I have them on all my bikes.
Sent from outside my mind.
Tom-2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC
My2Wheels
dad2bike is offline   Reply With Quote
Old 07-31-2013, 02:12 PM   #10016
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,737
Originally Posted by brianpc View Post
Hey all,
I like doubletakes but if you have HDB hand guards their integrated mirrors are great.
v8toilet is offline   Reply With Quote
Old 07-31-2013, 02:19 PM   #10017
ramjet
ramjet's Avatar
Oddometer: 2,311
Hey all,
I prefer these they fold out of the way quickly and look less funky, good at speed.
http://www.ktmtwins.com/ktm-690-950-...folding-mirror
"Moral courage is the most valuable and usually the most absent characteristic in men." Gen. George S. Patton
ramjet is offline   Reply With Quote
Old 07-31-2013, 03:37 PM   #10018
bcbullet
Breatheless
bcbullet's Avatar
Oddometer: 509
Speaking of mirrors, if you swap left for right you end up with about 1" less height on them...not quite so drastic looking.
bcbullet is online now   Reply With Quote
Old 07-31-2013, 04:41 PM   #10019
Biped
NooB Again
Biped's Avatar
Oddometer: 348
Disabling Roll-Over Switch
For those of you that have disabled your roll-over switch, this may be a asobering story. Bear in mind that Gary was riding a 500 EXC, so not sure if that had a roll-over switch or not. I'll be riding with his club this weekend and wish him a speedy recovery. He was about to trade his 990 for a 690, hope he gets to do that some day.
"Gary apparently tagged a tree with his right bars, which in turn sent him over the bars. Unfortunately his bike landed on him and commenced to devour him with a stuck throttle. Once the dust cleared and he was attended to by his fellow riders, he had burn marks on his hand and forearm down to the bone. He also got a huge, bone-deep gash from his shoulder down to his elbow and it sounds like the brake disc did that damage. He lost a huge amount of blood, but his fellow riders were able to get him attended to and he was eventually flown to hospital in Portland."
If it moves and it should not, duct tape it, if it does not move and it should WD40 it!
Biped is offline   Reply With Quote
Old 07-31-2013, 07:09 PM   #10020
DirtJack
DirtJack's Avatar
Oddometer: 1,600
Originally Posted by Uller View Post
I believe, not 100% positive though, that if you flip the blocks you can get enough adjustment to make it work.
Turns out that 14/42 will not fit a chain (116 links) which is needed for 14/48. However, 15/48 and 16/48 (same as stock) will. Gives lots of choices and changing the front sprocket is easier than changing the rear.
2008 KTM 690 Enduro
Times are GMT -7.   It's 10:39 AM.
