Old 09-24-2013, 08:29 PM   #11206
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 759
Originally Posted by vander View Post
I have been riding the 690 for some weeks now and two things are clear:
As for the position, is a bar riser the way to go, or are lower footpegs available? What is better?
Based on information I received today, I believe we will see lowered (.5 inch) foot pegs from Black Dog Cycle Works that will fit the 690. Not sure exactly when...
sdd04 is offline   Reply With Quote
Old 09-24-2013, 10:55 PM   #11207
pookguy88
Oddometer: 107
Originally Posted by CordR View Post
So I was all set to respond to the above with a line about checking the 690 wiki at http://ktm690.info/ but I'm getting a 'Bad Gateway'...server something...proxy geek speak etc.
Did I miss something? Is the wiki still around?
C
noticed this today too... looks like someone forgot to pay the hosting bills..
pookguy88 is offline   Reply With Quote
Old 09-24-2013, 11:11 PM   #11208
palmstatecrawler
palmstatecrawler's Avatar
Oddometer: 485
Question In need of a seat bumper and radiator bumper. PLEASE HELP!!!
I was goin over the bike today and noticed one of the bumpers on the underside of the seat is missing. I also saw that the shroud bolt was missing and so was the threaded bumper that attaches to the radiator mount. Does anyone happen to have these somewhere?
'13 KTM 690 Enduro R w/ full akrapovic exhaust, Evo1 lid, uni filter, Renazco seat, hard parts windshield and footpad, scotts damper with BRP submount, hammerhead shifter, flatlands skidplate, lost dog centerstand, Touratech engine guards, r&g front and rear axle and exhaust sliders, piaa 1100's, Doubletake mirrors, G2cam system,
'07 Kawasaki KLX250, '86 Yamaha BW80
palmstatecrawler is offline   Reply With Quote
Old 09-25-2013, 12:19 AM   #11209
Hoots
Hoots's Avatar
Oddometer: 1,419
Are you asking whether anyone happens to have picked up your missing shroud bolt ... ?
EDIT:
Hoots screwed with this post 09-25-2013 at 01:53 AM
Hoots is offline   Reply With Quote
Old 09-25-2013, 12:23 AM   #11210
palmstatecrawler
Oddometer: 485
Someone that is using these? Just thought I'd ask.
Old 09-25-2013, 12:46 AM   #11211
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 5,887
No, I just moved apartments and my new ISP is being stupidly slow in sending a tech out. The server should be up in a day or two. I didn't think anyone used the website .
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is offline   Reply With Quote
Old 09-25-2013, 05:02 AM   #11212
johnno950
Oddometer: 1,049
For those of you that just can't get enough pics of broken things, my riding partner, and I guess he's now my mechanic, is sending me pics as he strips the bike down and we wait for parts.....
almost looks like the suspension travel completey bottoms out and the swing arm still has travel when the shock is fully compressed,looks like its been torn apart and made of sub standard material
johnno950 screwed with this post 09-25-2013 at 05:23 AM
johnno950 is offline   Reply With Quote
Old 09-25-2013, 06:56 AM   #11213
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 957
Originally Posted by Mudguts View Post
Mr the bong , you can adjust the idel by the set screw on the right side of the throttle body it is a PITA , it's is also in the vortex manual , just do set the idel to high or you will blow the TB off with a back fire
Mine was modified to allow the idle speed to be set from the outside. Used a cap screw and a lock nut. Takes 30 seconds once the seat is off.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 09-25-2013, 08:44 AM   #11214
pookguy88
Oddometer: 107
question, I'm on a 1 5/8" kouba lowering link right now on the stock spring. I'd like to move back to the 1" kouba and get a softer spring.
what spring would you guys recommend for my weight? (145-150lb with gear)
I'm pretty sure I'm not getting the proper sag with the stock spring (too hard). But I figure if I have the shock out anyway to adjust the preload I should just get the proper spring.
Old 09-25-2013, 11:41 AM   #11215
motoged
motoged's Avatar
Oddometer: 908
PSC,
I lost one of the bumpers from the seat, went to auto parts store and had no luck. Then I went to my friend's auto-body shop and dug around in his box of "Bolts & Crap"....found exactly what I needed...
Good luck.
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 09-25-2013, 11:46 AM   #11216
motoged
motoged's Avatar
Oddometer: 908
Brad,
I appreciate your efforts with this issue. I also know how meticulous you are with inventive solutions....so I am surprised that you haven't just suggested some JB Weld, a little buffing with your favourite Dremmel, and some WD 40 (as it has been proven to be an excellent lubricant... )....
A better designed pro-link with zerks (sp?) would be a marketable item....getting into that broken part of the linkage is a real PIA
I have heard, however, that even linkages w/ zerks don't always get grease to where it is needed...
Ged Schwartz
Kamloops , BC
Old 09-25-2013, 12:04 PM   #11217
samppa2005
Oddometer: 51
I didn't read the whole thread on how the link broke but it looks as if the bolt broke and the link got wedged at an angle and then broke. It could be that the bearings were gone already before the bolt broke. In the end though it's sort of irrelevant. It takes quite a bit of abuse to break the link or there has been a manufacturing fault. The thing is though that before you go and put in a stronger link you should thenk what part will fail next? In engineering it's fairly common to use "fuse" parts. They break before anything dangerous or expencive breaks. If you make the link stronger what will break next? Shock, swing arm?
samppa2005 is offline   Reply With Quote
Old 09-25-2013, 12:39 PM   #11218
Uller
Uller's Avatar
Oddometer: 1,674
Thanks for your take on it.
I very much would like to discuss and debate this failure. It interests me. So, I am not trying to argue, but, to debate this when I state the following (It is sometimes hard to understand the tone in here and I know I seem to be argumentative at times....)
Again, I still don't see how the front of the link gets ripped out after the bolt shears. Under typical conditions, such as bike/rider weight and normal riding, I believe this link to be under compression. Only when the front face of the wheel contacts a large immovable object pulling back and up on it, in this case the backside of a ditch, does the link come under a tensional force.
IMO, the broken link exhibits signs of a tension related failure that could only come from the link being pulled backwards (the tension) while the shaft inside the bearing, which is held in place by the bolt, remains fixed.
Uller is online now   Reply With Quote
Old 09-25-2013, 12:48 PM   #11219
Uller
Uller's Avatar
Oddometer: 1,674
Originally Posted by motoged View Post
Brad,
No problem Ged. I really like the 690 and plan on riding it for many more years to come. Having a "bullet proof" bike is a priority of mine. I should say thanks to the rest of you for all helping convince others that there is a market for stuff.
Side note, on my last ride, the JB weld repair I did to the chain guide mounting tab that broke; failed. The only reason I didn't have a serious problem on my hands was because I had installed the Bullet Proof Designs Swingarm Guard before leaving. (no affiliation)
https://www.bulletproofdesigns.com/p...arm-guard.html
The part that was only made because the ADVRider 690 Community spoke up en mass.
P.S - I hate WD 40. There are much better lubricants and penetrating oils. Kroil Oil Rocks!
Uller screwed with this post 09-25-2013 at 08:16 PM
Old 09-25-2013, 01:34 PM   #11220
samppa2005
Oddometer: 51
I'm an engineer so arguing is what i do for a living The thing is that the link is designed to take a huge amount of compression some decompression and very little bending. If you look at the closeup of the link you see that the sides of the link are flattened. Means it has been stuck in between the swing. If you get it stuck for one reason or another the bending will break the link. If you make the link stronger the bending resulting from a some type of failure (be it a siezed bearing or broken bolt) will end up breaking something else like the shock or swing arm. So it's not the compression/decompression that broke that link (in my opinion) but either the bearing siezed or more likely the bolt broke and allowed the swing to become lodged and thus creating bending on the link.
Times are GMT -7.   It's 09:13 AM.
