Old 10-04-2013, 02:55 PM   #11341
Uller
Uller's Avatar
Oddometer: 1,672
Originally Posted by Okieboy2 View Post
Somebody convince Kouba to make a stock length so I can buy one.
You can help by sending him an email and expressing your desire to purchase one.
njkouba@ix.netcom.com
Edit:
I went back and found the parts list (created by Beaney) to upgrade the 690 with rally parts.
Pull rods from 450 rally bike
Rocker arm 660 rally bike ( requires machining)
Rear shock 450 rally ( Having a custom made Ohlins ttx made giving 305mm of travel)
Uller screwed with this post 10-04-2013 at 03:08 PM
Uller is offline   Reply With Quote
Old 10-04-2013, 04:14 PM   #11342
motoged
motoged's Avatar
Oddometer: 907
[QUOTE=MeinMotorrad;22476720]I hit a piece of concrete on the road at night doing about 70. I'm guessing the concrete was about 7 or 8 inches tall but really difficult to remember properly. Bike went airborne for some distance but landed straight and thankfully I was able to come to a stop without falling.
The front wheel is buckled but I can't see any other damage to the forks or steering. Should I be worried about other damage?...QUOTE]
MM,
In situations like that I later discover that my underwear has been damaged... .
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 10-04-2013, 07:12 PM   #11343
gen
gen's Avatar
Oddometer: 799
Big sharp hits like that can damage steering head bearings, so try to get the front wheel off the ground and check for any notches or clicks or play in the steering.
Also your forks may be out of alignment. If you know how to check this you should or have the dealer check.
DoD#1458 | GaijinRiders | 2010 KTM 690 Enduro
gen is offline   Reply With Quote
Old 10-04-2013, 07:15 PM   #11344
gen
gen's Avatar
Oddometer: 799
Originally Posted by 13x View Post
Does a 2012 SMC R triple tress serve any purpose if I fit it on E R, well other then blink factor.
The offset is different because the forks are different. I think the steering will be sharper- you may or may not want that.
Also if you are running any steering damper, I have been told that it not work on the SMC triple trees. I'd love to know whether it does or not.
Old 10-04-2013, 08:57 PM   #11345
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 847
Originally Posted by Seth S View Post
All of the links shown so far with the exception of the Kouba Link are cast units ...
Problem is we do not know what alloy they are using.
You can easily triple the strength of a part with an appropriate alloy. Pretty easy to jump from 25,000 to 75,000 psi (707x T6) with an appropriated selection.
Drop forging will add up to 15% and extra life.
Heat treatment is critical to many aluminium alloy.
Paul Jr
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 10-05-2013, 06:06 AM   #11346
MeinMotorrad
MeinMotorrad's Avatar
Location: Between Velez Rubio and Huercal Overa, Spain.
Oddometer: 1,384
Thanks for all the advice guys.
I've been trying to get in touch with the nearest KTM dealer who is in a place called Boe, about a 60km ride from me, but no luck so far. Maybe Google translate isn't so great - pas de fumée française.
Wheels: Anybody tried these. I'm wondering if they're stronger. I've seen some Excel wheels (Wheels with hubs machined the lightest on the market. Wheel with strapping, hub and spokes. - That's the google translation), for 369 Euros but I don't know anything about them. Will I have to get bearings also? I've never bought a new wheel before.
'12 KTM 690 Enduro R
MeinMotorrad is offline   Reply With Quote
Old 10-05-2013, 10:39 AM   #11347
ramjet
ramjet's Avatar
Oddometer: 2,132
Wheels: Anybody tried these. I'm wondering if they're stronger. I've seen some [URL="http://www.shopktm.fr/produit.asp?Lng=5&NuC=7&DoC=ktm&Prod=921&NProd=Ktm-Roue-avant-Excel-noire"][COLOR
If that is the ST-X, that is the one I have. I replaced the OEM 1.85 with the DID ST-X 1.6. Used same tire as OEM. I just bought the rim and used existing spokes and hub and relaced.
http://www.didchain.com/LXSXDirtstar.html
Coffee first. Then your mundane socialist bullshit.. Lenny Bruce
ramjet is offline   Reply With Quote
Old 10-05-2013, 11:45 AM   #11348
DirtJack
DirtJack's Avatar
Oddometer: 1,459
The stock rims are 36 spoke rather than 32 spoke, so if you are re-using the original hub, you need a 36 spoke rim. If you are using a complete wheel, then the number of spokes is less of an issue. You need only be concerned about axle diameter, hub width, spacers, and rotor mount.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 10-05-2013, 12:39 PM   #11349
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,454
Paul Jr
Yes a good point. We have a tool in the lab at work that will tell the material makeup. Might be able to sneak a piece in
Seth S
Seth S is offline   Reply With Quote
Old 10-05-2013, 02:58 PM   #11350
kito
Oddometer: 274
Hi I'm on the lookout for a new bike and at the moment it looks like the 690 with RR evo 2 tanks is at the top of the list. I will be buying secondhand so are the any year models I should avoid or be looking out for ? I see a lot of you guys are changing your exhaust. Is this just to get away from the CAT ? If so has anyone removed the CAT from the OE and welded it back up ? (I did this on my x challenge and it worked great) if I did this would the bike need to be remapped ? ( on my BMW it never) . Are the any known faults I should be looking out for when going to see 690 ? What are they like to work on ? Iv never had a KTM so it's all new to me.
Sorry for so many questions
Thanks kito
kito is offline   Reply With Quote
Old 10-05-2013, 03:40 PM   #11351
Hank.SD
Jet Measurer
Hank.SD's Avatar
Oddometer: 1,272
Just took my new to me 08 out for a shakedown run. Holy crap that's fun. One problem is a leaky gas cap. Maybe its all the wheelies
What is the best solution for that?
Hank.SD is online now   Reply With Quote
Old 10-05-2013, 05:09 PM   #11352
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,161
Buy a KLR if you need a solution for the wheelies.
Rally Raid & KTM Twins has a solution for the fuel cap.
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is online now   Reply With Quote
Old 10-05-2013, 05:22 PM   #11353
Hank.SD
Jet Measurer
Hank.SD's Avatar
Oddometer: 1,272
I've owned a couple KLRs.. I don't think I'll be revisiting that any time soon. This thing is fun!
Old 10-05-2013, 05:34 PM   #11354
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,713
Thanks kito
The main reason for exhaust swap is that the stock boat anchor gets so hot it's regularly referred to as nuclear. It's not safe and it's heavy.
v8toilet is online now   Reply With Quote
Old 10-05-2013, 06:06 PM   #11355
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,890
Get a real 690CC bike, swap the can and swap the pleated filter for the UNI twin pod and you'll be ace!
No need to bother with a remap. It'll run like a scalded ape just the way it is.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is online now   Reply With Quote
Times are GMT -7.   It's 01:40 PM.
