Old 12-22-2011, 07:06 PM   #1156
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Originally Posted by Gros Buck View Post
We figured that already you have the profile to quit and re-mary the same women more often then Richard Burton and Liz Taylor ...
Talking about your mate ... How is she supposed to hang behind you ??? You strap her on the rear rack with bungees ???
Your video with the camera facing forward is interesting enough. Now what we are missing here, is a video on the same trail, with the camera facing rearward at your wife desperately strapped ... Oh !!! And don't forget to put the micro on. We want to her what she has to say ...
Paul Jr 8
If the lake freezes, I'll get some two up ice riding video and I can promise you that she laughs a lot After 17 yrs, she still trusts me, figure that one out
Happy Holidays guys, I hope you all get some parts under the tree this year and most of all, enjoy your families!
Just say'IN
crankshaft is offline   Reply With Quote
Old 12-22-2011, 09:26 PM   #1157
andykeck
Oddometer: 106
Question about injector behavior at while cranking and fuel pressure
As part of a winter project to finally work the last bugs out of my SMC, I spent the evening setting up a couple of tests of the fuel system. The results lead to a couple of questions. I have the Vortex installed, so keep that in mind.
1. I'm having cold start trouble. Easy thing to do was pull the injector and take a look. I aimed the injector into a cup and cranked the bike over to see if I had spray pattern problems or dribbling. The pattern, to my eye, looked great. But I was surprised to see that the injector fires only one time during the cranking cycle, right at the first intake stroke, and not again. This would explain why no amount of cranking will do the trick if it doesn't catch the first time. Does anyone know how the stock ECU handles the startup?
2. I checked the fuel pressure, it's great. The prime immediately spikes the gauge up to, dunno, 53psi I think. The moment the prime cycle stops, the pressure bleeds down over a couple of seconds to something closer to 20psi. I don't know how the regulator works, so I don't know if that's normal or not. When I installed the current fuel pump, I'll admit that I thought the quick disconnect fitting in the tank just ahead of the regulator didn't seem as snug as I'd like, but I could be imagining things. If the line pressure isn't supposed to bleed down that quickly, my guess is that fitting is not 100%. But I really don't know. It could explain some of the hard starting though, if I turn on the key, let it prime then wait a couple of seconds while I screw with my gloves or whatever, then the line pressure would drop, meaning my one and only one injector blast is at less than half the intended fuel pressure and thus maybe not enough fuel to catch.
Ideas anyone?
andykeck is offline   Reply With Quote
Old 12-23-2011, 07:41 AM   #1158
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,203
Originally Posted by rudyunknown View Post
I will be buying a almost virgin 2011 KTM690, need to know the must have goodies, like crash bars, radiator gaurds etc. can anyone point me to some thread which already has the info. Not looking to put a new slip on etc. just need the bare minimum to be trail ready and if i drop it all the parts etc, should be still together :)
Rudy
Here's a list for new owners - of the '08 so probably some adjusts.
Stocker pipe is thermo fuclear. Might rethink that one.
OP
MOUAHAHAHAHHAHAHAHHAHAHAHHAAHHAH !!!
Gas tank up in flame maybe ??? That reminds me of my previous bike. I was lucky enough to be a nearby water hose ...
Paul Jr 8
Rick, your odometer is unaffected with the loss of the mega thread ...
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 12-23-2011, 10:15 AM   #1159
Bike Nomad
Bike Nomad's Avatar
Oddometer: 321
Rudy
Bartron's thread would be a good place to start looking for ideas...
http://advrider.com/forums/showthread.php?t=666269
DON'T GET IT TWISTED --ITS DUAL SPORT! NOT DUEL SPORT!
Bike Nomad is offline   Reply With Quote
Old 12-23-2011, 11:24 AM   #1160
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,473
a skid plate is a must. Also remove the two upper bolts that hold the radiator wind diverter in place and replace them with zip ties and you are ready for the woods. There are many things you can add later but these two things will get you off to a good start.
Seth S
Seth S is online now   Reply With Quote
Old 12-23-2011, 05:59 PM   #1161
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 2,014
Snapped chain this morning right on Christmas eve Doh! Is there any tricks for getting these off...shes tight as scottsmans wallet. I'm no expert but I think its time for new front sprocket as well
Stranded on the beach!
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon screwed with this post 12-23-2011 at 06:05 PM
Night Falcon is online now   Reply With Quote
Old 12-23-2011, 07:09 PM   #1162
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
I can't figure how that chain snapped.
I'd wait till the new parts arrive, install the rear sprocket and new chain. Then operate on that countershaft sprocket nut with an impact or a breaker bar and a friend.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 12-24-2011, 02:18 AM   #1163
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,132
or just get an impact wrench, put in neutral and whack it loose in a second.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 12-24-2011, 08:05 AM   #1164
Seth S
Seth S's Avatar
Oddometer: 4,473
+1.
and if you dont have an impact you might be able to clamp the outside diameter of the sprocket with a big set of channel locks, put the bike in gear, and use a long handled wrench to loosen.
Seth S
Old 12-24-2011, 10:56 AM   #1165
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 908
make sure you bend the flat of the washer off the nut first
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 12-24-2011, 11:10 AM   #1166
DirtJack
DirtJack's Avatar
Oddometer: 1,529
Unless you are going to stand on the pegs the whole time you're in the woods (a possibility), I would rank a Renazco seat near the top of the list. The only problem is that it usually takes several months to get one. Put your order in as soon as possible.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 12-25-2011, 07:02 PM   #1167
Renazco
Formerly AKA Boejangles
Renazco's Avatar
Oddometer: 4,744
On the 690 models we have a one week turn around
Seats www.renazco.com
Parts & Accesories www.renazcoracing.com
Renazco is offline   Reply With Quote
Old 12-25-2011, 07:45 PM   #1168
Renazco
Renazco's Avatar
Oddometer: 4,744
Originally Posted by Ryman View Post
So the custom seat I ordered last month will be here soon???
Depends on which model you chose, as you know we have two options for the 690's.
Send me an e-mail if you want to go with one of our new "Ergo" seats.
Old 12-25-2011, 08:30 PM   #1169
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
I should have went with one of your seats from the start. I've had the bike for 8 months and I'm on the 4th seat iteration and a bunch of $$ lighter.
I'll bug you in the spring if this one doesn't work out....
Old 12-25-2011, 08:49 PM   #1170
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,136
Sheepskin and Nike Shorts
IMO; I think butt burn is from latent vibration. More so than seat shape or size. If the fix doesn't solve the vibration, you still have butt burn eventually regardless of your custom seat. I've tried some of those custom seats. I recently added a sheepskin solution for a big trip last September aboard a Yam wr250r. 2500 miles! 14 hour days! Stock seat.
Sheepskin and Nike compression shorts is the answer.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Times are GMT -7.   It's 09:29 PM.
