Old 11-06-2013, 08:02 AM   #11926
777
Oddometer: 92
Injector removal
How easy is it to remove the injector with a Safari tank on, is their a link anywhere, thanks gents?
777 is offline   Reply With Quote
Old 11-06-2013, 08:25 AM   #11927
B_palmer22
B_palmer22's Avatar
Oddometer: 59
Originally Posted by Teli Rides View Post
This happened to me on a tar road on the way home, after doing a Gnarly single track and gravel roads.
When accelerating (not shifting) in 5th or 6th gear everything went fine until 5,000 rpm, after that if I twisted the throttle suddenly to WOT the engine speed went immediately to 8 K RPM (as if it were in neutral), but nothing happened immediately in the speed department, after a second the rpm's dropped to 6 k and the bike started to accelerate slower than expected. This can be a bit scary if you are overtaking with limited space. I had to be very smooth with my right hand in order to accelerate without the "rubber band effect".
After I stopped for gas, the effect condition seemed to go away, I couldn't test the acceleration under those circumstances (5th or 6th) more than once or twice, because traffic got heavy...
I have an '012 with 2,000 kms on the clock, I got a left over some months back. The dealer "had" to replace the whole top end under warranty at 1,000k.
I'm still not sure about that one as the bike ran fine when I left it for the first service. (I have changed dealer since then)
Any insight will be greatly appreciated
Its a false neutral. My 690 gets them fairly frequenly if you dont give it really positive upshifts. Try lowering the shifter one notch.
08 KTM 690 SMC
04 KTM 450 SMS
12 Triumph Street Triple R
08 Husky 510SMR SOLD, 03 KTM 300 2T Supermoto SOLD, 04 KTM 625 SMC STOLEN, 07 DRZ400SM SOLD
B_palmer22 is offline   Reply With Quote
Old 11-06-2013, 08:33 AM   #11928
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 5,917
Originally Posted by B_palmer22 View Post
Its a false neutral. My 690 gets them fairly frequently if you dont give it really positive upshifts. Try lowering the shifter one notch.
Gotta show these bikes you mean to shift! I also find that the false neutrals get more prevalent the closer I get to oil change time.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is offline   Reply With Quote
Old 11-06-2013, 09:04 AM   #11929
DirtJack
DirtJack's Avatar
Oddometer: 1,531
Originally Posted by Biped View Post
Yup, probably the difference between 15 and 25 psi tire pressure.
Way less than the difference between running a T63 rear and a Scorpion Rally. Stand the Scorpion Rally next to almost any other rear to see that it is a bit larger.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack screwed with this post 11-06-2013 at 09:13 AM
DirtJack is offline   Reply With Quote
Old 11-06-2013, 10:26 AM   #11930
AccelRus MaxiMus
Oddometer: 142
Kouba (or other) Lowering Links
Not sure, but is the concern about ride height change
from the lowering link not really a bit of an aside ?
No offense intended ! :)
A number of responses re daily weight variations (pre
or post big dump), seating position (fore or aft) tires
sizes, and/or air pressure making larger changes than
the 3/8" drop
Certainly changing only one end of the bike up or down
upsets suspension balance - I would think raising the
forks through the triples to equalize to the lowered rear
would restore the bikes balance with minimal changes to
wheelbase or other geometry (trail would change minimally
if both ends went down the same amount)
I would expect a 3/8" loss of ground clearance
One issue with the lowered rear (even with lowered front
to balance it out) is the swing arm angle - which is quite
important in relation to traction, and tire bite (road racers
know this well) - lowering the rear via the suspension (or
link) means less swingarm angle - generally a bad thing...
Perhaps larger underlying issue of importance is the change
to the suspension leverage caused by a shorter rear
suspension link
Changes to the link produces a change in the leverage of
the swingarm working against the rear spring/shock - and
in the rate of speed the shock/spring moves for unit of
deflection (up or down) at the rear wheel - effectively
changes spring rate seen by forces at the rear wheel
Question is whether the present rear shocks (stock or
otherwise) are able to work as effectively (maybe better ??)
with a link of different length...
Saw some discussion on this on the NZ forum a while back,
(2010) see post #22 at the link below - he was using an
1' 1/8" drop link
http://www.kiwibiker.co.nz/forums/sh...dventure/page2
No idea where the OP there got the data for the chart below,
but interesting read for sure...
Illuminates some of the potential issue with changing
out for a shorter rear link
For those that are swapping in the shorter link (dad2bike,
The Letter J) maybe post up what you do/don't notice
about the bike with the new link !
We have 2 x 13 690's here and one will be getting a < EDIT >1"
lowering link (shorter rider needs the room) - not sure I will
have a direct comparison (both bikes getting set up for a
different rider weight) but will know a bit more about this
in a couple of months
AccelRus MaxiMus screwed with this post 11-06-2013 at 12:21 PM
AccelRus MaxiMus is offline   Reply With Quote
Old 11-06-2013, 10:37 AM   #11931
jm65
jm65's Avatar
Oddometer: 177
Originally Posted by mezcal View Post
Pic of my setup.
hi Mezcal
What is the bracket triple clamp for steering stabilizer in your bike ?
thanks
KTM 690 R 2014
jm65 is offline   Reply With Quote
Old 11-06-2013, 11:20 AM   #11932
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,012
the 3/8" drop
suspension link
1' 1/8" drop link
We have 2 x 13 690's here and one will be getting a 1 3/8
Thanks for the input.
My son picked up the link at the Post Office today. I'll be putting it on this weekend.
I have run the 1-5/8" original link , the 1" link and now the stock link.
I had forgotten about my rebound/compression adjustments during the process. I was really screwed up and very harsh initial impact.
My set up will be very interesting as I will also be swapping out the forks for my 2003 EXC forks. It will be interesting to see how this changes my handling. I don't expect to notice much rear difference with only 3/8" drop. I don't recall much felling difference between the stock and 1". I just noticed ground clearance issues. I also have a Center stand. That requires me to get as much clearance as I can.
With me being in the extra chunky boy club and short 28" inseam I have to really swing to get my leg high enough to get over my tailbag. I'm NOT always successful to the delight of those around watching the ensuing comedy prat fall.
I'm figuring to like the extra long front end geometry. I used to love my old 80's Husky 390. The smoothest bike I knew then at high speed bumpy roads.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is online now   Reply With Quote
Old 11-06-2013, 11:22 AM   #11933
wsmc831
wsmc831's Avatar
Oddometer: 733
If you are putting on forks from an 03, what are you doing about the caliper/rotor difference?
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is offline   Reply With Quote
Old 11-06-2013, 11:44 AM   #11934
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,012
I'll be looking at all that this weekend. From my initial look the Caliper bracket will move to the EXC forks. The bracket moves the caliper out to the larger position. It is the speedo pick up that I will have to do a temporary fix for until I can order in the RR kit.
Tom
My2Wheels
690 WIKI
Old 11-06-2013, 11:46 AM   #11935
LukasM
Oddometer: 5,415
Speedo mount is the only difference, everything else will swap right over, including wheel with disc, caliper with bracket, fork guards, etc.
Old 11-06-2013, 11:47 AM   #11936
wsmc831
wsmc831's Avatar
Oddometer: 733
Hope it works...I thought about putting on my nice forks from my now dead 530, but the difference in caliper size and spacing differences stopped me before I got all that interested.
Post up results.
97 TL1000S
2010 690 EnduroR
2013 500 Exc
Old 11-06-2013, 11:56 AM   #11937
LukasM
Oddometer: 5,415
530 forks will work, too.
The hole spacing and offset on the axle clamp side is 95mm on all 48mm USD forks that came with an axial Brembo twin piston caliper, just bolt on your 690 caliper with bracket + RR speedo sensor mount and you'll be good to go.
Old 11-06-2013, 12:18 PM   #11938
Uller
Uller's Avatar
Oddometer: 1,675
1' 1/8" drop link
Thanks for the link. That was an interesting discussion on lowering links.
I liked this bit, "Sorry to sound like a stuck record but these things are over-hyped as a magic bullet bolt-on solution, such that people are quite happy to part with their cash for them without really investigating the negatives and/or alternatives. Friends don't let friends do lowering links! "
This was interesting too, "Thanks for posting Mr Kouba's reply. I was really interested to see that he completely ignored the "loss of rising rate effect". I think that this may be key and that you will find that your rear suspension bottoms out much more easily than you want."
Uller is online now   Reply With Quote
Old 11-06-2013, 01:16 PM   #11939
DirtJack
DirtJack's Avatar
Oddometer: 1,531
Originally Posted by jm65 View Post
hi Mezcal
thanks
Underground Machine (Rbott from AdvRider).
2008 KTM 690 Enduro
Old 11-06-2013, 01:18 PM   #11940
mezcal
mezcal's Avatar
Oddometer: 439
hi Mezcal
thanks
Its one Rbott makes, http://www.advrider.com/forums/showthread.php?t=397011
Black bits are from http://brpmoto.com/products?page=sho...roduct_id=2174
2011 Berg 570
mezcal is online now   Reply With Quote
Times are GMT -7.   It's 01:19 PM.
