Old 12-29-2011, 09:55 AM   #1216
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,662
I can intentionally activate the slipper on pavement --- specifically, riding it like a SuMo, i.e. shifting down 2 gears at once, and dropping the clutch. I find that so completely un-intuitive that even when I'm trying to do it, my brain goes on automatic about half the time and rev-matches with the throttle.
Now that you mention it, the clutch *does* have a very light pull. I had attributed that to the hydraulics, not the slipper. Doesn't the Rekluse also use flyweights that lock up harder at higher RPM?
When they say Harleys are for 1%ers, I don't think they mean guys who sell crank and get in bar fights any more.
Roadracer_Al is offline   Reply With Quote
Old 12-29-2011, 12:23 PM   #1217
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,709
the Rekluse uses metal balls that act as weights and as the clutch spins up they travel outwards along slots and lock the clutch plates together. The clutches comes with 2 different types of metal balls...one is heavier than the other. If you want faster lockup you run the heavier balls. There are also two different sets of springs for tuning the preload.
Seth S
Seth S is online now   Reply With Quote
Old 12-29-2011, 12:37 PM   #1218
poondangle
Slow
poondangle's Avatar
Oddometer: 1,580
Words to live by there!
poondangle is offline   Reply With Quote
Old 12-29-2011, 01:17 PM   #1219
Seth S
Seth S's Avatar
Oddometer: 4,709
I know I said balls
Seth S
Old 12-29-2011, 08:03 PM   #1220
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 848
You read Esquire Seth ???
Paul Jr
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 12-29-2011, 08:28 PM   #1221
Bartron
Bike Punisher
Bartron's Avatar
Oddometer: 709
Since we're on the topic of the slipper clutch, one thing I've found is that if descending really steep rocky terrain with the bike engine off and using the clutch as a rear brake, the thing would not brake worth a darn and kept bump starting. I haven't had this issue with other bikes so presume it has to do with the slipper. Curious what the experts think.
Yeah, I know, I should have pinned and prayed but I suck.
Ride on.
:: Furious Basterds: Velox, Vehemens, Oblivio
:: "For those who don't understand, no explanation is possible. For those who do, none is necessary."
Bartron is offline   Reply With Quote
Old 12-29-2011, 11:39 PM   #1222
Oz-Strom
Still trying
Oz-Strom's Avatar
Oddometer: 768
I am surprised that you guys don't notice the slipper working. I find it works a treat , particularly on steep downhills where the rear won' lock under compression. Or just banging it down a couple coming into a dirt corner.
Am I imagining this?
Oz-Strom is offline   Reply With Quote
Old 12-30-2011, 01:35 AM   #1223
.chris
690 Advenduro
.chris's Avatar
Oddometer: 94
Nope, I am with you on this one.
Try riding a bike without a slipper clutch, it almost ended badly for me.
I am interested in the future, because it's where I am going to live
.chris is offline   Reply With Quote
Old 12-30-2011, 01:55 AM   #1224
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
Explain.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 12-30-2011, 04:54 AM   #1225
SKINNY
SKINNY's Avatar
Oddometer: 653
I've slid the rear wheel most of the way down steep hills and never had any indication that the slipper was working. I've also locked the rear brake and killed the motor at speed and couldn't get enough traction to re-start...Maybe the dirt in your part of the world has better traction,...
SKINNY is offline   Reply With Quote
Old 12-30-2011, 06:58 AM   #1226
engineerjoe
Oddometer: 38
Basically the slipper clutch limits the torque that can go back into the engine. On my SMC on pavement I've noticed that the slipper keeps the RPM's at about 6k to 6.5k no matter how many gears you downshift. It will keep it there till the wheel speed meets the engine speed. And it feels like a nice constant, smooth engine braking. On pavement it will not break traction on it's own, I need to be heavy on the front brake to get a slide.
I really don't see how the slipper clutch would come into the right conditions to work correctly off road unless you were going full motocross speeds or maybe for a split second when landing jumps. There just isn't enough traction to put torque back through the clutch, the rear wheel slides before that happens
engineerjoe is offline   Reply With Quote
Old 12-30-2011, 07:11 AM   #1227
SKINNY
SKINNY's Avatar
Oddometer: 653
That was my take on the slipper clutch...I've put close to 10,000 miles on my 08 690E and it's always acted like a conventional clutch off-road
Old 12-30-2011, 10:56 AM   #1228
Roadracer_Al
Oddometer: 1,662
My experience as well.
It makes complete sense for KTM to equip the bike with one since there is no penalty for off-road use (other than preventing the aftermarket from supplying a twist-n-go clutch) and the motor is also used in a factory SM bike.
Old 12-30-2011, 11:46 AM   #1229
dirtbikeslob
Oddometer: 300
what did you ride before slipper clutches were invented?
dirtbikeslob is offline   Reply With Quote
Old 12-30-2011, 11:50 AM   #1230
Seth S
Seth S's Avatar
Oddometer: 4,709
Paul Jr
google images
Seth S
Times are GMT -7.   It's 12:27 PM.
