Old 12-15-2013, 09:56 AM   #12676
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,994
Originally Posted by sdd04 View Post
Are you still happy with the swap-any negatives?
It was a good swap. 2 hours well spent in the shop. High Interstate speeds are now much more stable. Not "640A Stable", but much much better.
At this point I think the pancake flipper sized front sail of a front fender flops wiggles and vibrates hither and yon and is the reason for the season at this point.
The steering is supposed to feel slower on the turns-I can't really tell a difference, but the twitchyness doesn't seem near as bad.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 12-15-2013, 12:26 PM   #12677
mezcal
mezcal's Avatar
Oddometer: 468
Originally Posted by dad2bike View Post
This looks like an issue with the smaller instrument cluster. I haven't heard of any of the larger units with Tach have the issue.
When I first bought my '09 I tore the bike down leaving the cables unplugged for 2 weeks. Had the same thing happen. It was goofy since it ONLY zeroed the ODO not the tripmeters.
Being as I just bought the bike I had that odo reading written down. It came in kinda handy for me as I run a logbook in the tankbag. All my work started at 0.
Mine went out at 12100km, maybe a little more but it wasn't over 12200 I know that much. I have paperwork for the 10000km service done in Sept this year so when I come to sell it eventually that will be enough evidence for the new owner.
Mine was the same, trip meters were fine but it did reset the clock.
2011 Berg 570
mezcal is offline   Reply With Quote
Old 12-15-2013, 12:36 PM   #12678
Velociraptor
TrackBum
Oddometer: 1,129
Mine did that too on my 2009. Reset itself around 6,000 miles when I disconnected the battery. So I have it in my maintenance spreadsheet. Only did it once.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 12-15-2013, 02:02 PM   #12679
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,240
Originally Posted by crankshaft View Post
Thanks Clif! So been daydreaming again, which always gets me in trouble... I'm getting my 690 ready for an endurance ice race in January and I was looking at improving the steering a bit. Anyone messed with the geometry at all, or moved the radiator? I have a brand new set of fluiddyne radiators for a 450 RFS bike (longer and thicker). Might also make it easier to add another fan, like the dirt tricks unit. Thoughts?
That's a lot more mods there Crank! That poor 690 is probably nothing like it started eh?
I know nothing of geometry mods, only that my 2013 is a bit different from the older ones '11 and down and seems very stable all the up to the ton. My 690 has had a full suspension rework by Konflict Motorsports, with preload adjust front and rear, and a Akra can on it and a 690RR air filter kit still sitting on the workbench. Otherwise a stock engine setup. Not even a map change (gasp! ). But it won't stay stock for too much longer I hope. Plus I have the walking 690 Wiki, Uller, only 30 minutes away when I start digging into it. In fact Uller and I were chainsawing up some trees in my backyard last weekend (with temps in low 20's, brrrr) while yakking bikes, always a dangerous mixture . Lucky we didn't cut anything off that we shouldn't have.
cyborg is offline   Reply With Quote
Old 12-15-2013, 02:20 PM   #12680
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 921
Originally Posted by Bike Nomad View Post
There you go bobzilla, only 1 ECU on the 2014 model. Whatcha waiting for? Go reserve one now.
You know you want too. You're handy, you know that your dual sporting time just doesn't have that same joie de vivre, now that you are reasonably certain that your forays into the desert won't involve a little wrenching time (I mean why even bring tools if you aren't going to use them? Remember the deep sense of personal accomplishment when you fixed something out in the dez?) or a tow rope? Being towed just helps to get to know your riding buddies better and builds up a distinct riding skill set you wouldn't have otherwise.
For those of you who have not been following the thread that long, bobzilla had an early model 690 (or maybe two--I can't remember for sure) and came up with a number of elegant mods to address certain issues, and shared them with us.
Seriously though, here's a challenge for you bobzilla. Go order up a 2014 Enduro R. Set to work addressing every known issue/weakness on the bike right out of the box, fuel pump, R/R, custom wiring harness, rad protection, clutch slave, flimsy brake pedal,etc., etc. add a skid plate, shark fin, HDB hand protectors, stick on case protectors, lockite and safety wire stuff where possible etc. Maybe do a build thread for "bobzilla's Bulletproof, Big Basin Blastin' Battle Bike". C'mon I haven't seen a really good 690 Enduro build thread since Bartron's.
ya make me smile
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 12-15-2013, 02:58 PM   #12681
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
I'm running SE forks right now, hiked up in the clamps 1.5 inches and a Kouba link rear for 1 5/8 drop. Going to switch to the 22mm setting on the clamps to get her to twitch Average speeds on the ice are about 50 mph with burst over 80 in a straight bit. My 690 is a franken bike for sure but it runs great...EVERY single time I ask it to 70 hp at the rear tire is also helpful
Just say'IN
crankshaft is offline   Reply With Quote
Old 12-15-2013, 03:18 PM   #12682
inyang
5secs away
inyang's Avatar
Oddometer: 419
Originally Posted by Seth S View Post
my experience is that the wiring harness has lots of very small wires with thin insulation and they like to wind said wires around lots of tight bends in tight bundles. Over time dust and debris work their way into the harness along with moisture/drying cycles and the wiring insulation gets damaged. After one ride in Canada in lots of deep water I found my turn signals and headlight were glowing with the bike off and the key out of the ignition. I later found several wires with splits in the insulation that were in close proximity to one another. When things got wet the moisture acted as a conduit to short circuits together. Best thing to do is to start up behind the headlight and just start inspecting connectors and wires. Put a small amount of dielectric grease in every connector you can get to. Look for damaged in the wires themselves...and focus on the circuits that the codes hint to.
My '11 690R wiring loom showed same problem.
Indicators stopped working at certain steering positions
Horn was touch and go
Bike would not start in gear (Side Stand bypass done)
Dash goes blank at times
I finally checked the main harness running through the neck to the front of the bike and so many of the little wires were cut, am surprised the bike was still running.
'11 - 690R
inyang is offline   Reply With Quote
Old 12-15-2013, 03:56 PM   #12683
ramjet
ramjet's Avatar
Oddometer: 2,323
Is it the gauge of wire necessary to make the circuitry have proper resistance or is it cheap ass to save a buck on KTM's part. I see so many various elec probs on '08-11 bikes it seems ridiculous. KTM -" Ready to Repair " might be the slogan they're working on.
"Moral courage is the most valuable and usually the most absent characteristic in men." Gen. George S. Patton
ramjet is offline   Reply With Quote
Old 12-15-2013, 04:17 PM   #12684
cyborg
cyborg's Avatar
Oddometer: 5,240
Looking forward to your ice racing videos with the 690! Make sure and post 'em up here.
Old 12-15-2013, 05:22 PM   #12685
DanTheMan07
Oddometer: 141
Originally Posted by dirty_sanchez View Post
The stem on your bike sounded pretty darned tight. Mine was pretty snug but far from needing to chock it up in the bearing press in order to press it out from the lower triple.
I had to beat mine like it sh!t on my carpet.
DanTheMan07 is offline   Reply With Quote
Old 12-15-2013, 06:01 PM   #12686
Monterey_BS
On or Off - not sure
Monterey_BS's Avatar
Oddometer: 250
Mine's a '12.
Bob in Monterey
Monterey_BS is offline   Reply With Quote
Old 12-15-2013, 07:23 PM   #12687
Hoots
Hoots's Avatar
Oddometer: 1,586
Originally Posted by Monterey_BS View Post
Mine's a '12.
So is mine ...
Hoots is online now   Reply With Quote
Old 12-15-2013, 07:57 PM   #12688
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,147
Mine's a '12.
Originally Posted by Hoots View Post
So is mine ...
I guess now I have.
Tom-2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC
My2Wheels
dad2bike is offline   Reply With Quote
Old 12-15-2013, 08:41 PM   #12689
ArcticRider
ArcticRider's Avatar
Oddometer: 170
Thanks !
Seth,
Thanks very much for the advice. After wetting it down with the hose this weekend it refuses to start at all.
Just blinks "14" and "6" and "8".
Sure appreciate your help.
ArcticRider is offline   Reply With Quote
Old 12-15-2013, 09:02 PM   #12690
Bike Nomad
Bike Nomad's Avatar
Oddometer: 321
Originally Posted by bobzilla View Post
ya make me smile
I went ahead and got the artist's conception of what bobzilla would look like after rejoining the 690 collective...
Plump & happy. Content with life. Relaxing with a cold brew (notice the first one is almost gone and he has a pitcher standing by) after a long day of riding the dez on his beloved brand new 690 Enduro. The deeply tanned sun kissed cheeks. The KTM orange riding jersey. Nirvana in Nevada can be yours again bobzilla--just pick up the phone and call your local KTM dealer--the life you improve could be your own.
If the last one made you smile, I hope this one made you mop up the coffee from your keyboard!
DON'T GET IT TWISTED --ITS DUAL SPORT! NOT DUEL SPORT!
Bike Nomad is offline   Reply With Quote
Times are GMT -7.   It's 12:25 AM.
