01-02-2012, 11:23 AM
#1261 | |
Safari Scramble!!!!!
Oddometer: 3,193
Seth S My intuition nearly makes up for my lack of good judgement. Just installed my new trolling motorHusaberg tank for sale: HERE |
01-02-2012, 11:31 AM
#1262 | |
Way Offline
Oddometer: 1,162
![]() Did some further searching now that I've got a part # and you're correct from what's been posted anyway, won't fit the '08E cluster. Fits my '10 though.
I am at one with my duality. |
01-02-2012, 11:32 AM
#1263 |
Oddometer: 25
Oh ya Seth good point. I have a 2010 R model that the switch plugs into
A ship is safe in the harbor, but that's not why ships are built... '10 KTM 690R:) |
01-02-2012, 08:22 PM
#1264 | |
Meatbucket Supreme
Oddometer: 205
Corn fed, inbred, brain dead. 2010 KTM 690 Enduro 2009 KTM 400XCW Plated |
01-02-2012, 08:46 PM
#1265 |
Way Offline
Oddometer: 1,162
The screen is designed to work with gloves. "Resistive" touch screen, whatever that proprietary lingo means to the end user. I'll use protective sheets over the screen so hopefully that won't mess with the functionality wearing gloves.
01-02-2012, 09:06 PM
#1266 |
canned fruit
Oddometer: 325
decals
Does anyone have a set of the top shroud graphics for an 08,
(ok, it's a long shot)
I know the voices arn't real, but they do have good ideas. |
01-02-2012, 10:10 PM
#1267 |
Oddometer: 527
![]() Does this light have a hi and low beam????
Ged Schwartz Kamloops , BC '96 GS 1100 '04 450 EXC '09 690 EXC Baja '05 Baja 06/07 Baja 08/09 BC Alpine Single Track |
01-03-2012, 12:20 AM
#1268 |
Oddometer: 3,193
Not if it is the HID. Boatman sells a conversion kit to install a 7" VW H4 headlight in that frame.
01-03-2012, 04:55 AM
#1269 |
Oddometer: 570
Nope, it is an HID high beam. The two LED lights are my low beam: 900 lumens each.
Johnlt 2007 BMW R1200 RT, 2002 Suzuki DRZ400S, 2000 Suzuki DR200 1985 BMW R80RT, 1975 BMW R75/6 Yamaha WR250R |
01-03-2012, 05:04 AM
#1270 |
Oddometer: 570
high speed wobble
At highway speeds of 65-85 mph, my 690E seems “nervous” and has a slight tendency to wobble, especially if I initiate it. Never a serious problem yet, but a little un-nerving. I recently put a a kouba lowering link on and dropped the front TT down about ˝ inch but still has the same tendency. I am not running a steering damper so can’t try that. My only thought is I have the large Baja HID light on it along with a small shield above the light which is considerable weight. I’ve not ridden it with the OEM light so can’t compare. I’d appreciate any ideas on what I might try to improve it. tks
01-03-2012, 05:24 AM
#1271 | |
Oddometer: 3,193
what are you running for a front tire and at what pressure?
01-03-2012, 05:38 AM
#1272 |
Oddometer: 570
I'm running a 606 up front at 22 lbs. and a 908 in the rear at 24. I had Mefo Explorers on before and experienced the same thing.
01-03-2012, 05:44 AM
#1273 |
Oddometer: 188
I had the same problem when I got mine, very flappy and a bit scary at times. Mine had worn michelin desert tires on. I ended up changing the forks for SXF ones and was running the front of the bike a bit higher than stock which seemed to help calm it down. It now has different tires on and is a lot calmer so I will be dropping the front back down soon. The bike seems to be a lot more nervous than my EXC.
www.dazedproductions.co.uk |
01-03-2012, 05:48 AM
#1274 | |
Oddometer: 165
01-03-2012, 07:35 AM
#1275 |
Way Offline
Oddometer: 1,162
Wobble.
It was recommended to me to start with pitching the MT21 first off. That didn't do it so I put it back on. Second recommendation was to reset/check the fork/triple alignment and retorque everything related. I cleaned up the inside of the fork clamps as well. That did the trick.
