Old 12-24-2013, 10:26 AM   #12916
mrwwwhite
mrwwwhite's Avatar
Oddometer: 436
New and improved KTM690 WUNDERFEST
Originally Posted by ramjet View Post
Is it possible to detect the start of this rocker failure before they cause major damage? What are the signs?
Mine looked fine in UB as I checked the valve clearance but 600km from Romania, the morning I started the engine I knew something was wrong. A lot more valve noise. I should have stopped there and find a solution to get the bike to Romania (which I had to do anyway). Maybe this way I could have saved my cam. 100km later I lost power so I knew my rocker was gone. The bearing was damaged but still in place. Unfortunately my cam lobe is foocked so I'll need a replacement.
BTW anyone using the RFR cam? Does it worth the 100$ difference?
mrwwwhite is offline   Reply With Quote
Old 12-24-2013, 01:43 PM   #12917
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 954
My understanding is that you will gain top end HP at a significant loss of bottom end power... not worth it if you ask me, the 690 already feels (seat o' the pants) down on bottom end compared to the big-bore thumpers of the old days and has plenty of high rpm power. I wonder if anybody is making any other options for cams?
I can ride my bike with no handlebars, no handlebars, no handlebars - Jamie Laurie
The Letter J is offline   Reply With Quote
Old 12-24-2013, 02:51 PM   #12918
HdeGroot
Oddometer: 16
Update on my problems
http://advrider.com/forums/showthrea...7#post23059697
My mechanic hooked up another cable harnass externally to my bike. or how its called.
Well it seems to run wel on another set of cables. There must be a broken wire somewhere between the computers and the throttlebody. Anyone had that happen? If so where was it? Also how much is a new set of cable three ??
Thanks in advance and happy christmass!
HdeGroot is offline   Reply With Quote
Old 12-25-2013, 02:01 PM   #12919
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,187
I left a suggestion from my experiences in your thread.
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is offline   Reply With Quote
Old 12-25-2013, 03:55 PM   #12920
HdeGroot
Oddometer: 16
Thank you, ill check.
Old 12-26-2013, 06:12 AM   #12921
drunkenrich
drunkenrich's Avatar
Oddometer: 132
Cool video
Very cool video, there is a few clips of some guys with nitrous on their bikes in the salt flats, pretty ill
http://m.youtube.com/watch?jb=225&ut...131225_Holiday
2009 Yamaha Nytro XTX
2010 KTM 690 enduro r
drunkenrich is offline   Reply With Quote
Old 12-27-2013, 10:36 AM   #12922
drunkenrich
Oddometer: 132
How often do you guys change the spark plug on your 690s? Thanks
Old 12-27-2013, 10:51 AM   #12923
NickW909
NickW909's Avatar
Oddometer: 572
The manual says 20,000km.
NickW909 is offline   Reply With Quote
Old 12-27-2013, 03:18 PM   #12924
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 765
Prefilter
I've been playing with different ideas for a prefilter for the old 690. No one seems to make one that i know of unless you have the filter form RR and put the filter sock over it.
So i figured there was room on top of the replacement foam twin pod filter to put a thin piece of foam or fabric of some sort.
This is what have come up with so far. A mesh support then foam or fabric.
All experimental at this stage.
Mesh with taped edges:
Mesh with gasket sealant around the edges and some thin bar to keep it flat:
Mesh support over the main filter:
Foam prefilter:
The airbox snorkel does fit back on alright.
I have not had a chance to ride the bike yet due to incessant rain for the past week.
Let me know you thoughts, apart from restricted airflow and having to do the 15min reset.
Cheers
Trev
2012 KTM 690 R
2010 KTM 990 R (Sold)
2008 N.Z.Yamaha Safari: http://www.advrider.com/forums/showthread.php?t=306905
2007 N.Z.Adventures Safari: http://www.advrider.com/forums/showthread.php?t=201557
Dotbond screwed with this post 12-27-2013 at 03:26 PM
Dotbond is offline   Reply With Quote
Old 12-27-2013, 05:51 PM   #12925
stewie100
soon to be andventur
stewie100's Avatar
Oddometer: 132
Hey guys I was wondering is the 690r a good bike for all in one use cause when I get my first new bike I want this and can not spend 20k on two motorcycles and this is the perfect bike to me for just about anything
stewie100 is offline   Reply With Quote
Old 12-27-2013, 06:36 PM   #12926
Dagwood_55
Dagwood_55's Avatar
Oddometer: 1,335
yea, sure.
Live long, love much, laugh often, and
Ride, Ride, Ride.....
Dagwood_55 is offline   Reply With Quote
Old 12-27-2013, 06:52 PM   #12927
burmbuster
burmbuster's Avatar
Oddometer: 1,429
Stewie,
I don't know what your previous experience is with bikes so this is just a suggestion. Do your research and ride one before you buy. I wouldn't wish this bike on anyone new to on road or off road bikes. It will learn ya real good, real quick.
_______________
2013 KTM 690 Enduro R
burmbuster is offline   Reply With Quote
Old 12-27-2013, 06:59 PM   #12928
buddoggin
buddoggin's Avatar
Oddometer: 314
You may want to start here: http://www.advrider.com/forums/showt...9337&page=2648
Current bikes:
2012 Triumph Tiger 800
2010 KTM 690 Enduro R
buddoggin is online now   Reply With Quote
Old 12-27-2013, 07:27 PM   #12929
Velociraptor
TrackBum
Oddometer: 1,107
Overnight change of viewpoint on 690
Recently traded in a road bike for a 2014 500 EXC. Did my first dirt ride on it yesterday. All I can say is WOW! Compared to my 690, the 500 had much plusher suspension(my 690 has much better suspension than stock), is radically more flickable, and seems to have way better traction. Power is a little less but only a little. So net result is the 690 is kind of ruined for me as a dirt bike. Now the 690 seems like an adventure touring bike that does really good off pavement, and the 500 seems like an "OMG I can't believe this thing is street legal!" dual sport. Of course the 690 is a better street bike but the 500, even geared down a lot from stock, can still cruise at 65-70. It gets blown around more due to the light weight, but does OK. I put a 16 tooth front sprocket back on the 690 so it will do highway a little better. The 690 is a better all around bike, but honestly, the 500 kind of blew my mind. Apples and oranges I guess, as the 500 holds 1.5L of oil and need an oil change every 15 hours.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 12-27-2013, 08:43 PM   #12930
leanin
Oddometer: 181
Foam prefilter:
Cheers
Trev
Trev, I did something similar using window screen and air filter foam on top. It catches at least 95% of the dirt/dust and the flat foam is simple to clean/oil compared to the Uni-Filter which is a pain.
leanin is offline   Reply With Quote
Times are GMT -7.   It's 06:08 PM.
