Old 02-17-2014, 11:04 PM   #14011
shan
shan's Avatar
Oddometer: 66
Originally Posted by DaveInSt.Augustine View Post
What brand bar risers do you have on your bike? How much rise do they have?
and looks like this with its top piece
shan is offline   Reply With Quote
Old 02-17-2014, 11:34 PM   #14012
motoged
motoged's Avatar
Oddometer: 908
Who does this guy's suspension?
http://www.wimp.com/turbulencelanding/
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is online now   Reply With Quote
Old 02-18-2014, 01:20 AM   #14013
fluff34567
fluff34567's Avatar
Oddometer: 1,077
Originally Posted by Seth S View Post
it is a MecaSystem riser and it raises the bars 65mm higher than original $225.
Got it through Rally Management Services
Longer clutch/brake/ throttle lines and cables I guess,
Sent from my GT-I9505 using Tapatalk 2
fluff34567 is offline   Reply With Quote
Old 02-18-2014, 04:07 AM   #14014
sprouty115
sprouty115's Avatar
Oddometer: 1,489
Originally Posted by Just_P_Dirty View Post
I removed the canister and the SAS today to get ready for the new exhaust pipe. Pretty easy but I have one question-
I saw that with tune ecu you can just turn off the SAS so you do not have to wire in a resistor. Can you also use tune ecu to turn off the signal for the canister or do I still have to solder in a resistor?
No resisitor required if you have TuneECU and a cable.
sprouty115 is offline   Reply With Quote
Old 02-18-2014, 04:25 AM   #14015
tacomodo
Trailblaze
Oddometer: 59
Are there any bang-4-ur-buck ways to raise this bike? I'm a bit hesitant shelling out for new forks and stuff
That may be true, sir. But I have a hammer
tacomodo is offline   Reply With Quote
Old 02-18-2014, 04:34 AM   #14016
Boysie
Oddometer: 14
Anyone know what this plug is for?
Boysie is offline   Reply With Quote
Old 02-18-2014, 04:56 AM   #14017
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,595
Fat Ass Racing!
Old 02-18-2014, 06:44 AM   #14018
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 800
Originally Posted by Boysie View Post
Based on location, my guess is the connector for the switch for the canister.
sdd04 is offline   Reply With Quote
Old 02-18-2014, 07:35 AM   #14019
LethPhaos
brb
LethPhaos's Avatar
Oddometer: 579
My EU model '08 has that connector too, I've often wondered what it was
EDIT: looks like you're right
source: http://ktm690.info/index.php/Canisterectomy_-_Bartron
Strange, as EU models don't have the canister, I would expect the wire loom not to have the connector alltogether
| KTM 690 SMC RRP | Honda RD04 Africa Twin |
Balkan ADV - RR around Europe on the AT
Bacon trip log map
LethPhaos is offline   Reply With Quote
Old 02-18-2014, 08:10 AM   #14020
Parigi
Hoinar
Parigi's Avatar
Oddometer: 285
This means that it must be a way to turn that off in the ECU, right?
Parigi is offline   Reply With Quote
Old 02-18-2014, 09:01 AM   #14021
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,545
run higher tire pressure.
Seth S
Seth S is offline   Reply With Quote
Old 02-18-2014, 10:53 AM   #14022
Anders-
Oddometer: 169
Or a different profile, maybe
Seriously though, what's your sag? (I'd say most scandinavians are a bit heavier than the 690 is sprung for :)
Also, check the rally-raid stuff.
Edit: that was meant for tacomodo, but I haven't figured out how to multiquote yet
Anders- is offline   Reply With Quote
Old 02-18-2014, 10:54 AM   #14023
tacomodo
Trailblaze
Oddometer: 59
Not sure what you mean by sag, haven't got the bike yet. But I'm 2 meters tall, weighing in at around 96kg
Last bike I had I mounted different links on the rear shock to add 4-5 cm, which helped greatly. I haven't manage to find anything similar for the 690.
So far my plan is to find the tallest bar risers I can (hopefully also some that move the bars forward), try to find lower foot pegs, and also get a taller seat. Seat is last on the list as they are ridiculously expensive.
Old 02-18-2014, 11:10 AM   #14024
MeinMotorrad
MeinMotorrad's Avatar
Oddometer: 1,479
I think maybe you're going to find this bike pretty cramped. If you get the tallest bar risers you can you will also have to get longer cables (I don't know how this works with the '14 fly by wire system though - are you getting a '14?)
As for the seat; its not just for height that it's needed. Your ass will thank you especially if you weigh in at 96kg.
'12 KTM 690 Enduro R
MeinMotorrad is offline   Reply With Quote
Old 02-18-2014, 11:43 AM   #14025
Hoots
Hoots's Avatar
Oddometer: 1,462
Originally Posted by spaceman_spiff View Post
That thing makes no attempt to follow the lines of the bike. It looks like there was no thought or design put into it. I would get the rear tank from RR if I was gonna get an accessory tank back there
I think it looks better than the RR rear tank - and infinitely better than the Safari tank ...
The additional volume (over RR rear) would also be a good thing ...
My RR rack broke (metal fatigue) - and the RR rack is integrated into the fitment for the rear tank - this Tumbleweed arrangement looks a bit stronger, and is in any case a separate item (called a Wild Burro rack) ...
Hoots is offline   Reply With Quote
Times are GMT -7.   It's 10:18 PM.
