Old 03-25-2014, 07:05 AM   #14776
FriedDuck
Why die all tensed up?
FriedDuck's Avatar
Oddometer: 427
Mosfet regulators
What's a good source for a mosfet reg/rect? I'm chasing down one from a 2007+ Honda CBR600RR which should be a direct swap (vs. the FH020 that roadstercycle sells.)
Bikebandit lists $250. This unit is used on a ton of bikes & I'm trying to see if there's a source that's less money.
I'll post up pics when I'm done with the swap.
Thanks, Jeff
FriedDuck is offline   Reply With Quote
Old 03-25-2014, 07:57 AM   #14777
MeinMotorrad
MeinMotorrad's Avatar
Oddometer: 1,479
Thanks, Jeff
roadstercycles.com should have what you're looking for.
'12 KTM 690 Enduro R
MeinMotorrad is offline   Reply With Quote
Old 03-25-2014, 08:03 AM   #14778
LukasM
Oddometer: 5,418
No he doesn't, and I haven't seen the FH008 from any other aftermarket suppliers either. For OEM used on Ebay will be your best bet, that's where I got mine.
Unlike the FH012 or FH020 it will fit perfectly in the stock location, it's the same size and bolt pattern and doesn't have the bulky connectors on the side.
No clearancing of the fins will be needed with my Evo 2 kit bracket either!
Old 03-25-2014, 08:14 AM   #14779
FriedDuck
FriedDuck's Avatar
Oddometer: 427
Thanks Lukas!
It was your idea, in a roundabout way, that set me on this chase. Uller gave me the tip you'd told him. And this is exactly why I'm using that unit. I don't want to have the hassle of relocating. I am going to re-terminate it in weatherpak (sp?) connectors, though.
Cheers,
Jeff
Old 03-25-2014, 08:23 AM   #14780
MeinMotorrad
Oddometer: 1,479
FriedDuck
Oops. I should have paid more attention to your post.
Old 03-25-2014, 08:27 AM   #14781
LukasM
Oddometer: 5,418
Hi Jeff,
This is exactly what I'm doing, just picked up some green, red and yellow wires during my lunch break. As you can see I cut off the stock Honda connectors, so I will extend the wires and run green and red directly to the battery, and the yellow ones to the stator. I have also cut off the piece of shit brown stock stator connector, obviously it's not suitable for a dirt bike and just a question of time until it causes problems! Mine had lots of dirt and corrosion inside it, will be replaced by a waterproof Weatherpack as well.
Lukas
Old 03-25-2014, 11:55 AM   #14782
can'o'kiwi
full metal jock-itch
can'o'kiwi's Avatar
Oddometer: 132
Originally Posted by fluff34567 View Post
Should be blanked if your SAS is removed and also see your wires have bfoken off the air temperature sensor plug..... a known issue.
Sent from my GT-I9505 using Tapatalk 2
Ahh thanks sas is removed thats a random pic off the interweb
ahhh, yeah i told you that would happen.... quick run
can'o'kiwi is offline   Reply With Quote
Old 03-25-2014, 01:00 PM   #14783
BeHyper
BeHyper's Avatar
Oddometer: 49
Don't grind the welding!... ;-)
Originally Posted by Nowwhat View Post
just a little buffing....
BeHyper is offline   Reply With Quote
Old 03-25-2014, 01:42 PM   #14784
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 977
Originally Posted by motoged View Post
TLJ,
Thanks for that link....I have the Cyclops 7" Rally light (love it)...and wonder how the LED bulb would increase illumination... ????
I will give him a call....
Perfect, now you can be the guinea pig for this DOT approved hi/lo LED light that will drop right into your 7" race light! http://www.discountfleetsupply.com/tlc27270c.html
I have a 7" light on mine (with a flood lens) right now too and can't decide which route I want to take. Either replace the lens with a Cibie and the LED "bulb" or possibly even try out the Trucklite? Not a cheap experiment for me either way.
I can ride my bike with no handlebars, no handlebars, no handlebars - Jamie Laurie
The Letter J is offline   Reply With Quote
Old 03-25-2014, 02:09 PM   #14785
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,939
Frame looks good
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 03-25-2014, 08:03 PM   #14786
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 847
Originally Posted by LukasM View Post
Hi Jeff,
Lukas
Fill it with a dielectric grease, silicone base, as thick as possible ... Corning Ware for example. It works ... so no need to replace shitty OEM connector ...
Paul Jr
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 03-25-2014, 08:18 PM   #14787
gen
gen's Avatar
Oddometer: 802
Wow. I wish I had known this before I bought the FH020. I have a new FH020 but need to figure out the mounting.
The one benefit of the FH020 is that the socket at the R/R is quite good and can be mated with the waterproof Furukawa QLW .250” Connector.
DoD#1458 | GaijinRiders | 2010 KTM 690 Enduro
gen screwed with this post 03-25-2014 at 08:25 PM
gen is offline   Reply With Quote
Old 03-25-2014, 09:05 PM   #14788
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,939
300mm Front and Rear
Old 03-25-2014, 09:34 PM   #14789
isaac004
isaac004's Avatar
Oddometer: 838
Question...I think this will be fine, but just wanted to air it out to make sure. I installed the Rally Raid Soft Pannier Rear Racks on my 2014 690, and also installed a Agri Supply Tube behind the right rack, to hold a 1L MSR fuel bottle.
Has anyone else done this? Seen any clearance issues with the swing arm at full compression? I haven't been able to compress the back end down to simulate, but it seems OK and consistent with the muffler on the left side. I figure those of you with RR rear tanks may also have a similar clearance.
isaac004 is offline   Reply With Quote
Old 03-25-2014, 09:40 PM   #14790
DrtSqtr
DrtSqtr's Avatar
Oddometer: 146
Did you upgrade with aftermarket rear shock or did you mod the stock one?
Did you go with RR 300mm fork kit?
DrtSqtr is offline   Reply With Quote
Times are GMT -7.   It's 07:25 AM.
