09-15-2011, 06:45 AM
#16 | |
Oddometer: 17,983
^^^ This ^^^ Spending the money you save on training is far more likely to pay dividends.
"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind." — Dr. Seuss “Watch out for everything bigger than you, they have the "right of weight" Bib |
09-15-2011, 07:00 AM
#17 |
Oddometer: 1,108
I won't argue that that wearing any helmet is better than no helmet...this goes without saying. However being an informed consumer helps me make a decision when purchasing anything. I want the best I can get for my money and that doesn't always mean the most expensive. That's the point the article makes the $80 DOT helmet was safer than the $400 Snell helmet so knowing that you can save that money and spend it on something else....like training.
So no I'm not going to slap just any bucket on my head because its better than nothing. I'm gonna do a little research, try on the ones that I think will work for me so I know they fit right and give myself better odds than,...."better than nothing". |
09-15-2011, 07:43 AM
#18 |
Yinzer
Oddometer: 1,202
yes, any helmet is far, far better than no helmet.
but, a helmet that absorbs impact energy is definitely going to be better than one that transmits it to your head. it's the same principle as crumple zones in modern cars...which make them much safer than older cars without them in collisions (even though being in any car is far, far better than being a pedestrian in a collision). |
09-15-2011, 09:05 AM
#19 |
Daredevil Clutz
I found this site to be useful in comparing impact ratings between helmets with different and or multiple standards ratings:
http://sharp.direct.gov.uk/ The most interesting, but probably least useful feature is seeing the severity of impact for different parts of the head for each helmet tested: ![]() It would be nice if there was an equivalent site for helmets that are only sold in the US however. My Scorpion EXO-700 does a pretty decent job by their tests. Like the current standards, It is worth noting that the SHARP tests do not take into account rotational injury, so superskin helmets like the Lazer Solano see no advantage on them. |
09-15-2011, 12:46 PM
#20 |
Oddometer: 485
Here's the actual Federal Motor Vehicle Safety Standard 218, called the DOT standard, in Title 49 Code of Federal Regulations section 571.218
http://frwebgate.access.gpo.gov/cgi-bin/get-cfr.cgi?TITLE=49&PART=571&SECTION=218&YEAR=2001&TYPE=PDF One thing about the FMVSS218 standard is that it only tests the top of the helmet, so half-helmets can qualify for the DOT approval. This shows the small number of helmets that NHSTA tests, and the ones that fail for functional reasons, not just labeling or something. http://www.nhtsa.gov/cars/testing/comply/fmvss218/ This and following pages of this link shows where the Snell M2010 standards meet and where they differ from ECE and DOT standards. http://snellm2010.org/testingM2010.html One think I find impressive is the limit on shock the helmet is allowed to transfer to the head, 275 Gs for Snell & ECE vs. 400 Gs for FMVSS218 (DOT). The harder the brain is allowed to bounce around inside the skull, the more brain damage occurs. http://snellm2010.org/morePeakAcceleration.html Snell M2010 helmets are available from about US$100 and up. As said above, and well documented by webbikeworld.com, helmet interior shape to match the rider's head shape is a critical part of proper helmet sizing and fit and safety. http://www.webbikeworld.com/motorcyc...met-shapes.htm |
09-15-2011, 01:18 PM
#21 | |
Oddometer: 740
I think that showing the amount of protection by area is actually very useful. The temporal areas of the head are much more sensitive to impact, due to the bony protuberances within the skull. I may look into switching helmets based on the SHARP review. I like the way that all of the bell helmets are five stars. |
09-15-2011, 01:41 PM
#22 |
Oddometer: 4,096
The peak G's allowed by a helmet only tells part of the story. How long the G load is sustained is just as important. It may seem that Snell only allowing 275 Gs is better that the 400 G DOT standard but that is not necessarily the case. DOT limits the time allowed for over 200Gs and over 150Gs. Snell has no provisions for limiting the time that the G load is sustained.
As several have stated earlier, buy a helmet that fits and meets your needs. I would not worry about Snell or ECE certification. I certainly would not pay extra for Snell certification. |
09-15-2011, 02:12 PM
#23 | |
Rectum Non Bustibus
Oddometer: 3,509
10 Ducati 1098 Streetfighter S - "Sleipnir" 09 Kaw Versys "The problem with Socialism is that you eventually run out of other people's money" _____ Margaret Thatcher |
09-16-2011, 03:32 AM
#24 | |
Forever N00b
Oddometer: 1,602
The 2005 Motorcyclist article emphasized that any full-coverage helmet meeting any modern standard works better than the best helmets available a couple decades ago.
Motorcycles are magical. |
09-16-2011, 03:45 AM
#25 | |
Forever N00b
Oddometer: 1,602
I DID use SHARP to select my current helmet, but with the understanding that I was looking at overall performance of the manufacturer instead of impact data for the model I can buy here. If you are interested in a flip-up, SHARP gives the % of time the chinbar stays closed during impacts.
06-02-2012, 02:17 PM
#26 |
Oddometer: 1
Why not Full Face
If you are going to wear a helmet why not just wear a full face. I mean we wear a helmet just in case of a crash. Why wouldnt a person want a helmet that would provide the MOST protection. I ride mostly in Florida and my buddies are always on me about "in this heat how can you wear a full face helmet". What they dont know is that I am actually cooler wearing a full face than they are wearing half helmets because of the insulation. It is true, they dont believe it. Just my opinion
06-02-2012, 05:49 PM
#27 |
Oddometer: 485
The facebook link above is a good one. The MSF article is way too old. The original Dexter Ford article is out of date.
DOT only tests a couple of dozen helmets a year. The manufacturers self-certify. I had dinner with the owner of a low cost Chinese maker, and she told me that they send their helmets to a Swiss testing company's Chinese lab for DOT testing and to a German lab for ECE testing. They don't do Snell. Snell does test the visor and the chin bar on full face helmets submitted to them. It is only recently that DOT allowed helmets sold in the U.S. to have both DOT and ECE stickers on them, even if the helmets had met both standards. I think the DOT spec is the bottom of the barrel. I'd prefer ECE and I also trust the new Snell M2010 standards. The U.K.'s SHARP testing scheme tests the extend the helmets exceed the ECE minimums. Their article on helmet fit is a good one.
It's not what you look at that matters, it's what you see. Henry David Thoreau |
06-03-2012, 10:33 PM
#28 |
MNE
I am wearing a Nolan.....
06-04-2012, 07:04 AM
#29 | |
jack of all trades...
Oddometer: 6,587
By the way if Parelever is so damn hot for handling, why is BMW NOT running it on the superbike? Face it, your preferences just don't match some writers, it's hardly about being fired for writing the truth. It's about trying to relate what is going on in a particular model. They now tell when cruisers handle good... for a cruiser. The reader has to equate that with their preferences. I was in sales and knew the competition in 83. That Sabre was a departure from the norm and worked great other than the rev limiter thing. It wasn't my kind of ride, but it was far superior in power and power delivery than most any other 750 at that time. It had sport touring or even touring potential as well as being a great standard. The power spread was immense and smooth. That was part of the problem, too smooth, too easy to over rev. 1983 saw rev limiters on the V45s and V65s. Back to helmets... Fact is from the only reliable research so far most any helmet would work in most all accidents since the blows are usually glancing and of low impact since falling off a bike is only about 4 feet to the ground maximum. Falling off a bicycle is worse due to the height. Of course that is only the fall to the ground. The glancing blows are what would tear up one's bare head, thus the fact that any helmet would work. You are 100% right, it's primarily all about fit first. Bad fit is a bad fit, whether on a $100 special or a $700 top shelf. Then it is about quality of interior, venting, features, and finish. The point of the orginal Motorcyclist helmet expose was to bring out the point that price didn't always equate best protection AND THAT SNELL WAS RUBBER STAMPING AUTO SPECS ON MOTORCYCLE HELMETS. Snell did not have separate specifications for motorcycles. That caused Snell helmets to transmit more shock to one's skull. Snell also did not differenciate between head size which equated head weight. Now they do all this. It took that article, pissed off helmet manufacturers, and Snell being proven faulty for bikes to get it changed. Part of the drive behind the article were the people involved, to whom Snell would not listen. One specific one, Dr. Thome, a leading expert in helmet safety in design having worked with Dr. Hurt and others, gave the whole thing huge credibility. Learning from what they demonstrated I wouldn't be concerned over ANY helmet that has a bit of a name, regardless of price. Vega has good stuff, Z1R has good stuff, obviously Arai and Shoei have good stuff. I wouldn't be concerned with any of them on my head, other than fit.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens! Mark - klx678 95 KLX650C w/Vulcan piston bigbore, 90 Zephyr 550 markk53 screwed with this post 06-04-2012 at 07:18 AM |
06-04-2012, 07:34 AM
#30 | |
Oddometer: 17,983
