Old 09-19-2011, 04:48 AM   #16
FLYING EYEBALL
out of step
FLYING EYEBALL's Avatar
Oddometer: 10,564
Awesomeness!!
if you keep poor...the struggle is simple
my photos http://jskustoms.smugmug.com/
save yourself some $ with my smuggy discount code qvMaWy1bTFU7c
FLYING EYEBALL is offline   Reply With Quote
Old 09-19-2011, 05:24 AM   #17
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,503
Interesting conversion so far. I wonder of the strength of the parts you are adding is enough considering the weight differences in the two bikes? I assume you intend to ride this off road a lot?
Keep up the good work. Contrary to what some may think, not all BMW guys are purists.
Jim
Old 09-19-2011, 06:50 AM   #18
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,713
Ditto to what jim said. I considered a dirt bike front end for my build but ended up with a 950 due to braking concerns as well as being able to find springs heavy enough for the bike and its intended uses. My bike runs .64 springs and runs very well.
With regards to brakes you may seriously want to consider a super moto setup. That was one consideration for me but I went with a known quantity after seing what that costs. I can tell you that hauling my 450# bike down from speed uses every bit of the dual brembos and could use more. Not sure what you intend to use thr bike for, but for street use id at least consider better brakes.
Kudos for a bitchin project when finished
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 09-19-2011, 07:59 AM   #19
larryboy OP
Chopper Rider
larryboy's Avatar
Oddometer: 14,990
It's hard to notice the supermoto huge front disc that is on there when it's surrounded by such a huge motorcycle, but it's there.
Rode a buddies Super Enduro and it felt fine with a similar size front rotor.
The plan is to get this thing together ASAP as good as I can do it with the amount of cash I have right now, take our trip to Death Valley, then tear into any issues that exposes. I'll have seven months before we ride the Divide with it.
I had a KLR that weighed in at 420 pounds on a certified scale and it had wimpy forks and brakes. I'm light years ahead of that with brake/fork size...ya just gotta know your limitations and don't over ride the machine for the conditions.
Edit; Oh yeah, the 950SE uses .48 springs on the front for stock and that felt really good to me on a bike that weighs nearly the same as this project, so I ordered .49 springs for this thing and will go with 20w Harley fork oil.
larryboy screwed with this post 09-19-2011 at 08:50 AM
Old 09-20-2011, 10:43 AM   #20
larryboy OP
Chopper Rider
larryboy's Avatar
Oddometer: 14,990
Got the springs yesterday, need to get some fork oil.
Parts inbound:
Two TM40-6 carburators...
Highway Dirtbike Ultimate guards.
Buell headlights with an HID conversion.
Ignition box from Germany, top secret, details later.
Two Doubletake mirrors from Neduro.
Time to get my butt into the carholio.
Old 09-20-2011, 12:09 PM   #21
larryboy OP
Chopper Rider
larryboy's Avatar
Oddometer: 14,990
Preparing for gravity.
I noticed that others who have gone back to carbs have come up with an adapter tube to hook the carbs to the stock flange, but I found that Sudco has a ton of different flanges. I think they'll have what I need, I'll have to call them tomorrow.
Old 09-20-2011, 12:31 PM   #22
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,755
Originally Posted by larryboy View Post
Preparing for gravity...
/out of lurk mode
for those of us less bmw-inclined, what that heck is that piece of metal for? hopefully not too stoopid of a question
/back to lurk mode
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 09-20-2011, 12:33 PM   #23
larryboy OP
Chopper Rider
larryboy's Avatar
Oddometer: 14,990
Originally Posted by HardWorkingDog View Post
/out of lurk mode
/back to lurk mode
Fuel pump block off plate. I bet I gain two usable gallons of fuel when the petcocks get welded in.
Old 09-20-2011, 10:57 PM   #24
JimVonBaden
"Cool" Aid!
Oddometer: 53,503
I don't know about two, but certainly more than half a gallon!
Jim
Old 09-20-2011, 11:12 PM   #25
larryboy OP
Chopper Rider
larryboy's Avatar
Oddometer: 14,990
Originally Posted by SFKLR View Post
Not the same part(s) you just sold in the Flea, is it?
No, trying to pull off a stand alone ignition system. Ordered a coil last week and the ignition box today, hope it comes together quickly...tick tock. I'm hanging onto the harness, Motronic and coil pack until I'm sure this other direction will work.
Jim
Yeah, I was thinking that just the fuel pump space would get me a little over half a gallon. I don't know BMW's, but it looks like it holds quite a bit of fuel on the side the pump can't get to? Will these bikes normally drain a tank down to nothing? I'm going to put a petcock on either side once I figure out the exact low points.
Old 09-21-2011, 08:19 AM   #26
LukasM
Oddometer: 5,426
Nice build!
You might want to change those springs if you haven't installed them yet. The SE uses .59 fork springs stock, which should be about right for your bike (maybe get some .60s). .48 or .50 is what the 640 Adventure guys run, and you have got an extra 100 lbs on them.
Old 09-21-2011, 10:35 AM   #27
larryboy OP
Chopper Rider
larryboy's Avatar
Oddometer: 14,990
Originally Posted by LukasM View Post
Nice build!
Thanks for stopping by with some info, all my web searching had me coming up with .48 on the SE? I'm going to go ahead and install the .49's I have and if it's too soft it's not a big deal, I'll just swap the tubes to another bike I have that needs upgraded springs too, then I'll put stiffer springs in that set of forks to put on this bike.
I'm not trying to build a Super Enduro or HP2 here, just after a nice riding two-up bike that is lighter and easier to handle.
Edit: Just sent SuperPlush an email, I really don't have time to do two sets of forks right now, thanks for the wake-up call, Lukas!!!
larryboy screwed with this post 09-21-2011 at 10:42 AM
Old 09-21-2011, 05:56 PM   #28
JimVonBaden
"Cool" Aid!
Oddometer: 53,503
You can usually get about 2/10 of a gallong by tilting the bike over to the left when empty. You can probably recognize another 2-3/10 with the petcocks at the lowest position on the tank lobe.
Jim
Old 09-21-2011, 11:19 PM   #29
larryboy OP
Chopper Rider
larryboy's Avatar
Oddometer: 14,990
Jim
Hmm, so I'm still in the ballpark as far as I can tell. Looks like they say it's a 5.8 gallon tank and if a feller was to take care of his fuel pump and keep it submersed you only get to use 3.8 or so based on the way my fill ups were going before I tore it apart.
Shooting for all 5.8 usable and carrying my 1.5 spare can for those few times I need the extra range...Wyoming on the Divide.
Old 09-22-2011, 05:07 PM   #30
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,132
The 950 Adventure is the bike that came with the .48s, the SE had the .59 like Lukas said. Most people put stiffer springs in the 950A forks. But what takes so long about replacing fork springs?
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Times are GMT -7.   It's 02:24 AM.
