Old 09-25-2011, 08:41 AM   #46
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,935
Looking great!
Do you have any plans to replace that rear rack? It is notoriously weak, and could be much more functional. You might even lose a few pounds with something custom.
Jim
JimVonBaden is online now   Reply With Quote
Old 09-25-2011, 09:07 AM   #47
Nixels
Face fears - live life
Nixels's Avatar
Oddometer: 7,736
So Mrs Larryboy wants you riding on a bumblebee? So everyone knows they're likely to get stung if they get too close?
Looks good. I like that you fab on the frame to keep it simple & straight.
Coffee first, then all your other mundane bullshit. Benjava
SmugMug coupon: cwbkgu7KGL2D2/save $5
Nixels is offline   Reply With Quote
Old 09-25-2011, 09:46 AM   #48
larryboy OP
Chopper Rider
larryboy's Avatar
Oddometer: 14,834
I'll check out those guys for cable stuff, thanks Jim!!!
The Acewell is a 3701 that I bought for another project that has stalled out for now, so I've stolen a few parts from it. The main reason I got this model originally was for the tach as that bike revs to 12k or something. Not sure what features this thing has. I've been trucking through the mechanical stuff as that's easy for me, I'm weaker when it comes to electrical and want plenty of my time dedicated to the electrical system...full scratch built harness.
What part of the rear rack is weak, JVB? Something on the back is tweaked a bit and it's been tough to just ignore it and get my numbers right on the front graft. I'm going to put a backrest and a Happy Trails flat deck on the back, but don't intend to carry any real amount of weight back there.
Yes, Mrs LB likes the BumbleBee look. Oh yeah, I'm going to work in a couple of passenger grab handles and will put some Polly Heaters in them for the passenger.
larryboy is online now   Reply With Quote
Old 09-25-2011, 11:24 AM   #49
larryboy OP
Chopper Rider
larryboy's Avatar
Oddometer: 14,834
I was going to get her some heated gloves, but we ride a lot and wear out tons of expensive gloves as it is. She uses grab handles if the bike has them and I have a spare set of Polly Heaters...why not?
Old 09-25-2011, 02:09 PM   #50
JimVonBaden
"Cool" Aid!
Oddometer: 52,935
The silver aluminum part often breaks right in the middle by the vertical grip. If you can, it would be worth your while to at least reinforce it. Or, better yet, replace it with a purpose built tube rack.
Jim
Old 09-25-2011, 02:46 PM   #51
larryboy OP
Chopper Rider
larryboy's Avatar
Oddometer: 14,834
Yeah, I can see what you mean there. I'll add a strut from the rear bag mount tab that will run around to hold up the tail plate. Thanks for the heads up!!! Muchas Gracias!!
Old 09-25-2011, 02:48 PM   #52
larryboy OP
Chopper Rider
larryboy's Avatar
Oddometer: 14,834
Oh yeah, I was going to make the new muffler box out of some stout stuff, but it looks like I can go with thinner material if I just make a skid plate for the center stand.
Old 09-25-2011, 03:36 PM   #53
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Sure, that Flander's Co. has everything.
3701 is a basic model. Indicators are listed as: left turn, right turn, neutral, and high beam.
http://www.acewell-meter.com/c0_1.php?pid=5&bid=11
Something for your whiteboard: Get the crankshaft to 60 before TDC, and figure out a way to lock it there. Do not use the front crank pulley for any locking mechanism you may devise. The front crank pulley must be accessible to remove and replace during the ignition modifications you'll be doing.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 09-25-2011, 03:43 PM   #54
larryboy OP
Chopper Rider
larryboy's Avatar
Oddometer: 14,834
Ok, I'll come up with something.
Old 09-25-2011, 04:11 PM   #55
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Maybe "lock" is too strong of a word. A fine line mark, and a fixed pointer to that mark will work. You'll just have to be more careful if the crank isn't actually locked in place.
Maybe a fine line mark on the crank pulley, and a rigid pointer 'bracket' fixed in place using a couple of the alternator belt front plastic cover bolts would work. Or the other way around, hang the pointer off the pulley, and put the mark on the motor front cover. Maybe clamp the pointer to the pulley with a large band clamp, without scratching the drive belt vee-groves.
The primary consideration is the mark or pointer on the crank pulley needs to be located so the pulley can be removed and replaced from the crank without knocking the pointer out of adjustment. You'll be taking a die grinder to the 'timing window' on the backside of the crank pulley, so allow for doing that without knocking the 60BTDC pointer out of alignment.
Old 09-25-2011, 04:13 PM   #56
larryboy OP
Chopper Rider
larryboy's Avatar
Oddometer: 14,834
Gotchya, no problemo...I have the "technology".
Old 09-25-2011, 05:57 PM   #57
villageidiot
Oddometer: 1,772
...oh for an 1150 thumper with one carb.
small progressive weber??
villageidiot is offline   Reply With Quote
Old 09-25-2011, 06:17 PM   #58
Benjava
Benjava's Avatar
Oddometer: 1,920
there's more where those came from if you need foot peg heaters, and no the 1600whatever don't got those either
"Limbautomy" what's the Rush?
Benjava is offline   Reply With Quote
Old 09-26-2011, 09:55 AM   #59
larryboy OP
Chopper Rider
larryboy's Avatar
Oddometer: 14,834
The 12-cell battery should work fine. An 8 cell will also work acceptably. Inside that battery, 4 of the 3.6 volt A123 Systems cells are connected in series to make '12 volts'. Then 3 rows in parallel, of 4 the cells in series (aka: 4S3P), gives the current rating.
Ordered the 12 cell, I don't want to play around with not enough CCA's on a zero degree morning in the middle of nowhere by ourselves. I'm going to do a battery disconnect switch instead of a keyed ignition.
Didn't do much yesterday, needed a day off and I noticed that my plan for one of the trellis tubes is really close to the carbs, I'm going to wait for the manifolds to mockup a little better.
Old 09-26-2011, 10:49 AM   #60
BikePilot
BikePilot's Avatar
Oddometer: 11,251
The 20w fork oil will probably give you a nasty high-speed spike. Those forks take 5w stock and aftermarket tuners tend to run goldvalves (larger orifice) or thinner oil. On the heavy bike I might go to the 7.5w oil, but don't think I'd go thicker and first off I'd try to re-valve for more low speed damping in both directions and stick with 5w. 5w will also change less with temp so you won't feel it fade as much
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Times are GMT -7.   It's 12:41 PM.
