12-29-2010, 04:13 PM
#1 |
Oddometer: 1,025
Evap Fuel Nozzle (EFN) Tool
This tool is designed to hold the spring loaded boot back for you while you're filling your tank and or gas can.
The tool is the same size as your drivers license/gas card and being only 1/8" thick will fit in your wallet or a jacket pocket. It is made of ABS plastic to prevent damage to the paint finish on your fuel tank It's easy to use and makes filling up a cinch. Slide the tool over the nozzle, depress the boot past the ring that holds the nozzle in place on a car fuel filler, and slide it over to lock the boot in place. Yes I know that they are already out there, but I'd like to think that mine is better than the others and cheaper to boot, i.e. $5.00 shipped. That price is for the lower 48 since I'm simply slipping the tool into an envelope and slapping a stamp on it. Anyplace else will be $5.00 plus shipping, i.e. whatever it actually costs me to do the same thing to places outside the lower 48. ![]() ![]() Here is a video clip showing how easy it is to use the tool. The first couple of seconds show how how you have to hold the boot back to activate fuel flow, followed by the EFN Tool in use. pm me if interested. Kai Ju screwed with this post 07-26-2012 at 07:48 AM |
12-29-2010, 09:18 PM
#2 | |
Oddometer: 1,023
Why do you feel that is better than this? ![]() Walter
"How much a dunce That has been set to roam Excels a dunce That has stayed at home." |
12-29-2010, 09:43 PM
#3 |
Oddometer: 1,025
Because the tines of the fork can catch the boot while my tool slips over the nozzle itself and is then slid across beneath the ridge, capturing the boot. Once my tool is on the nozzle you can't drop it, while fumbling with the open tool and heavy gloves invites dropping it.
I tried the open tool, which is why I looked for a better solution. Mine is also cheaper, the Aerostich sold tool is $8.00, plus shipping. Kai Ju screwed with this post 12-29-2010 at 09:50 PM |
12-29-2010, 10:14 PM
#4 |
Oddometer: 342
yepper
I'll bite!
Where do I sign up? Steve
1971 Moto Guzzi 125 Stornello 1971 CL100 1972 SL125 1972 TS125 1974 XL125 1975 CB360T 81 miles since new! 1985 XLV750 1988 RTL250S 1988 NX650 1989 XL600V Transalp White 50K Miles 1990 XL600V Transalp Red 7K Miles near perfect 1990 XL600V Transalp Moonstone 1990 VFR750R RC30 1990 NT650 1990 CB-1 1991 CBR400RR 1993 CRM250R 1993 NSR250RR 1994 XRV750 Africa Twin 1994 RVF750RR RC45 1995 RVF400RR NC35 1996 CBR250RR 2000 W650 2003 FJR1300 2004 RVT1000 RC51 |
12-29-2010, 10:32 PM
#5 |
Oddometer: 1,025
Vapor Recovery Nozzle Tool
you have mail.
That's a nice line-up,btw. 1990 CB-1 1991 CBR400RR 1993 CRM250R 1993 NSR250RR 1994 XRV750 Africa Twin 1994 RVF750RR RC45 1995 RVF400RR NC35 1996 CBR250RR Kai Ju screwed with this post 12-29-2010 at 10:39 PM |
12-29-2010, 10:49 PM
#6 |
Oddometer: 342
Paypal sent
Thanks Steve
12-29-2010, 10:58 PM
#7 |
Oddometer: 1,025
Thanks Steve, it'll go in the mail tomorrow.
Once you've received it please let me know how it works for you. Alex Kai Ju screwed with this post 12-29-2010 at 11:04 PM |
12-29-2010, 11:07 PM
#8 | |
Oddometer: 1,623
I hate to sound pessimistic, but how does this thing help?
The vapour recovery boot fit fine around my tank filler neck and the pump switched on just fine I was annoyed by the loss of fuel capacity, to get the tank full I had to compress the silly thing by hand so I could pull the nozzle out far enough to fill all the way and still have the pump run. putting a piece of wood on there will only gain the height of the threaded portion, an inch maybe? not a substantial difference in fuel capacity. Is there some factor I'm missing here? I only bought gas in California twice so maybe there is another reason.
Sometimes wheelies happen Quote:
12-29-2010, 11:14 PM
#9 |
Oddometer: 1,025
"I was annoyed by the loss of fuel capacity, to get the tank full I had to compress the silly thing by hand so I could pull the nozzle out far enough to fill all the way and still have the pump run."
That's what the tool is designed to do. It holds the boot back for you so that you can actually top the tank off. It just makes it easier. I've used mine for about two years now and when we go on group rides my buddies always ask me where I got it and if they could have one. That's why I decided to start making them for sale. |
12-29-2010, 11:22 PM
#10 |
Oddometer: 342
why?
In the Peoples Republic of California we've got these POS vapor recovery foreskins that limit the volume you can get in the tank. They work on a automobile gas tank with a lengthy filler neck. But are a PITA on a bike. You can try to pull the foreskin back with one hand so you can see if you can fill the remaining volume without squirting yourself in the face while holding the nozzle with the other. These devices free up one hand so you can hold the nozzle and still look into the tank.
Some of us have bikes with marginal tank volumes like the Transalp, so I like to get the tank as full as possible. Many of my older bikes have a hump in the middle which prevent proper insertion of the nose into the tank. No fuel will flow unless you compress the foreskin. I like his take on the idea and wish the creator good luck. Steve
12-29-2010, 11:25 PM
#11 | ||
Oddometer: 1,623
If the tool will hold the boot compressed so you can pull the nozzle out to top off then its a great idea. Acting just as a washer like in the picture, meh I'm going to write a letter to the Governor now, explaining that their recovery nozzle reduces tank capacity for us and therefore requires us to fuel up more often, causing more chances of releasing dangerous fuel vapours into the atmosphere. Perhaps a motorcycle adapter can be supplied at each gas station. It would have to be nothing more than an extenstion to the existing vapour recovery boot to reduce the effective nozzle length. come to think of it, we had a vapour recovery system here for a short period of time, it was nothing more than an accordian hose attached to the existing pump, and it did in fact reduce the effective nozzle length.
12-30-2010, 12:04 AM
#12 |
Oddometer: 1,025
Sorry about the crappy pictures but I was by myself and trying to hold the nozzle with one hand and taking pics with the other.
The second pic shows the tool holding the boot which allows you to lift the nozzle out of the tank for a full fill up. |
12-30-2010, 12:23 AM
#13 | |
Oddometer: 1,623
thanks it makes perfect sense now, I wasn't realizing that it would hold the boot compressed on its own
12-30-2010, 08:34 AM
#14 |
Oddometer: 1,850
when i saw that device in the areostich catalog, i thought "crap-ola". so this is deja vue all over again. yes these days,the foreskin nozzles are used in more than just calif. and i've personally have been able to outsmart 'em ( although from now on i'm going to feel a bit gay pulling it back).... maybe the next generation of foreskined nossels???- i'm going to pass- i'm fine on crap
12-30-2010, 08:53 AM
#15 | |
Oddometer: 1,025
Bully for you , but outsmarting 'em is having a tool to hold it back for you.... |
