Old 12-12-2011, 11:18 AM   #46
CAVEboy OP
CAVEboy's Avatar
Oddometer: 120
lemieuxmc
Thanks for the clarification. I figured this out pretty quickly when bolting everything together yesterday. With the clamps loose the whole frame easily shifted with the weight of the bike confirming what I had thought all along. I'm amazed that some of the frames I've seen on the board work the way they do. Maybe the difference between road duty and heavier use. My clamps didn't slip at all on the road with rigid suspension, but I don't think that will last with further testing. The broken mounts on the above photo seem logical. I have a few easy solutions for resisting the torsion in the clamps, but am going to do a few more test rides around the block with suspension first.
So... suspension ideas. I'm still reading so I should have something worked out soon. Any further frame critiques are welcome. Thanks for the help.
CAVEboy is offline   Reply With Quote
Old 12-14-2011, 06:40 AM   #47
CAVEboy OP
CAVEboy's Avatar
Oddometer: 120
On the Road!
Shock came from some 125 dirt bike... pretty stiff. It is working ok though. As was noted, the DR suspension will need some attention to make this thing better, but I rode it around yesterday and I think I can live with its manners around town and in the woods. This is pretty much it other than final touches and powder coat. I'll post up an update when everything is truly finished, but for now I'm pretty happy with how it all turned out.
Old 12-14-2011, 08:21 AM   #48
cwadej
Keeper of the truth
cwadej's Avatar
Oddometer: 928
did you make the tub or find it somehwere? I'd like a smaller tub on my KLR/ Velorex rig.
I went with a shock from Northen Tool,
http://www.northerntool.com/shop/too...ct_22932_22932
It works well so far. I do like the air shock you found, it fits too. I'll have to measure tonight and see if I can fit it in my fender.
...They will find the streets are guarded by United States Marines!
cwadej screwed with this post 12-14-2011 at 08:56 AM
cwadej is offline   Reply With Quote
Old 12-14-2011, 08:51 AM   #49
cwadej
Keeper of the truth
cwadej's Avatar
Oddometer: 928
Originally Posted by lemieuxmc View Post
I had slippage on my Velorex lower rear clamp on mount. I made a new mount from a single length of tubing that u-bolts to the inner and outer sidecar tubes to eliminate the torsion force, but still allow lead adjustment.
Can you show a picture from above how you tied into the clamp mount? I've having the same issue.
Old 12-14-2011, 10:33 AM   #50
CAVEboy OP
CAVEboy's Avatar
Oddometer: 120
Thanks for the info
The tub was put together with left over aluminum from a duck boat build I did a year or so ago. I am not an accomplished spool gun slinger but I can get by. The edges are a little rough and I don't really plan to clean it up at all. I'm just going to let it all oxidize for a weathered look. The beauty is that it won't rust and I can always clean it up later if needed.
I'm curious what one would have to pay for a sidecar similar to what I built? I'm trying to decide If I did well with the budget or spent more than I should have. Raw materials were my only real cost. Bearings, grade 8 hardware, and rod parts add up quickly though. Not to mention the aluminum for the tub (even though it was left over).
Old 12-14-2011, 10:43 AM   #51
Kyler
Confused Hack Nut
Kyler's Avatar
Oddometer: 2,615
I believe the frame and sub-frame alone can be bought from DMC for roughly $2K.
Ken => I'm a DAMN Rider (No rules, just ride!)
Happiness is a 3-wheel drift!
Member of the Maryland OHV Alliance
2014 Yamaha FZ-09 Adventure
Kyler is offline   Reply With Quote
Old 12-14-2011, 01:57 PM   #52
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,683
CAVEboy,
Your sidecar looks very good to me but is your dog happy?
Vince @ SWFL or WNC 2001 Kawasaki W650
2012 Dong Fang DF250RTB
2013 Sky Team ST125-8A 2013 Sky Team ST125-6B
2013 Ice Bear PBZ110-1P sidecar
2015 Ural cT
Bar None is offline   Reply With Quote
Old 12-17-2011, 05:55 PM   #53
CAVEboy OP
CAVEboy's Avatar
Oddometer: 120
Clip
Enjoy.. we sure did!
http://www.youtube.com/watch?v=9UBkx...ature=youtu.be
Just need to work out the harness for the pup before we go out on the road.
Old 12-17-2011, 07:27 PM   #54
lemieuxmc
lemieuxmc's Avatar
Oddometer: 3,360
If you look at the picture I attached to post #39, you can see the 1.25" square tube that is U-bolted to the Velorex round tubes in place of the clamp on mount. The u-bolts allow it to be moved fore and aft, and there is a short section welded at a 45" angle with a threaded rod and heim joint to allow height adjustment at the lower rear bike mount.
lemieuxmc is offline   Reply With Quote
Old 12-18-2011, 01:22 PM   #55
D.Bachtel
D.Bachtel's Avatar
Location: Nipomo ,,,, Where HWY 101 and HWY 166 collide!
Oddometer: 490
Thumb
Great stuff CAVEboy, nice rig you built there.
Superb workmanship and design.
Gracie looks happy, love the way she leans up against you tucking her head up close to the shroud.
Looking forward to more videos.
Don in Nipomo
D.Bachtel is offline   Reply With Quote
Old 03-27-2012, 09:35 AM   #56
Biebs
BMW Airhead
Biebs's Avatar
Oddometer: 514
Just a point here raw materials do not jump up and do this kind of build on there own. Your time / workmanship are more valuable. This is a great build from scratch / sidewalk chalk. A complete sidecar setup with mouting hardware is expensive. Great job.
Biebs is offline   Reply With Quote
Old 03-29-2012, 07:37 AM   #57
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,909
I really like the scaled down tub, it matches the bike size well. Great job.
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Old 03-30-2012, 08:41 AM   #58
MotoJ
Mobtown Hacker
MotoJ's Avatar
Oddometer: 1,175
Very cool build- the rig looks great and Gracie looks like she loves riding!
Doggles will protect her eyes from hits with bugs and gravel. A 45mph bumblebee in the eye can be expensive at the vet's.They'd be recommended to go along with a harness...
http://www.baxterboo.com/search.cfm/...FUGo4AodOwy8yw
The ladies used to check me out...now they just keep an eye on me.
MotoJ is offline   Reply With Quote
Old 03-31-2012, 06:24 AM   #59
CAVEboy OP
CAVEboy's Avatar
Oddometer: 120
I'll try to get an update posted soon. We have been riding it around town on and off through the winter. Gracie is sporting a nice new harness, but no doggles yet. We are pretty happy with it and I'm getting used to driving it a little more. It is pretty light in the corners without weight in the car but I wouldn't want it any heavier being attached to the DR.
Old 04-17-2012, 09:27 PM   #60
CAVEboy OP
CAVEboy's Avatar
Oddometer: 120
Update
A few finished pictures. I bolted some eye bolts behind the seat and use a couple ropes with clips to the dogs harness. It seems to work well. She is tethered just tight enough to keep her in a sitting position. The windshield folds up under the "hood" of the tub when not needed. All the small parts are powder coated and the frame was simply painted. I have hardly taken it off the pavement yet, but so far we have been enjoying it quite a bit. It was a fun project and I think it looks pretty cool too. I feel like I really have to watch out for myself riding around town because of all the head turning and swerving. Fun stuff for sure. I don't know what it is worth, but I would entertain some offers if anyone is interested. We will be moving shortly and space is at a premium. I don't know though, it is pretty cool to just sell it off now. Maybe I'll make room...! Anyways, thanks for all the help from everyone here. It was a blast to build.
Times are GMT -7.   It's 01:26 AM.
