09-20-2011, 05:09 PM
#1 |
I'm Barry F'n Gibb!!
Oddometer: 4,595
$$$ to repaint frame?
I recently purchased a '75 R90/6 project. The tank, fenders and headlight shell are definitely getting painted, a long-ago owner did a screwed up job on them.
After pulling these pieces off, I'm questioning whether I should have all of the frame parts repainted as well. There's some minor issues with the frame paint, but nothing terrible. I'm not looking for a showroom-condition restoration, just a good looking, clean 35 year old bike. Can anyone give me some price ranges on what you spent to have the frame, subframe, and other black bits repainted? Did you prep the parts yourself and just pay a pro for the color coat and clear coat, or did you send the whole thing out to be stripped and painted? Thanks in advance, Stu |
09-20-2011, 05:29 PM
#2 |
Kickstart Enthusiast
Oddometer: 1,809
I haven't had any frames done in quite a few years, but I plan on having two Royal Enfield frames and associated bits powder coated, so I asked a friend who recently restored a Norton about current prices for powder coating, and he said it ran him about $250 to have a Commando frame and the miscellania attached to it done.
He masked the places where he didn't want paint, but the powder coater did the sand blasting and cleaning. Prices will vary according to location. |
09-20-2011, 05:33 PM
#3 |
Smells güt!
Oddometer: 461
I had my R75/6 main frame, swingarm, and rear subframe sandblasted and powder coated for around $200
Just be really picky with the powder coater to plug all holes and bearing races! |
09-20-2011, 05:34 PM
#4 |
As above, so below
Oddometer: 486
I have my frames powder coat, saves a lot of hassle. I can get them done locally for $150-$250 depending on the required prep work and quantity of parts. The media blasting can sometimes be an additional fee.
Slash 5 Revive |
09-20-2011, 05:47 PM
#5 |
Oddometer: 4,595
Thanks for the info, I've been following your cafe build thread. I contacted a local powder coater for an estimate.
09-20-2011, 05:57 PM
#6 |
Oddometer: 534
My frame, swingarm and lots of little brackets were $300 for powder coat. Check your powder coater carefully. Mine came with a referal from K&L Chrome. This shop is known for being on "Trick my Truck" on CMT. It looks OK, but I think I would have had a nicer finish and nearly as tough had I painted everything myself.
1979 V-1000SP 1988 R100RS 1996 R1100RSL 1998 CR250 |
09-21-2011, 09:02 AM
#7 |
Beemerguru...G/S guy
Oddometer: 635
Been using the same shop for powder coating for the last 15 years...averages around $500 but that also includes every little part...frame, subframe, center stand, side stand, handle bars and controls, brackets, lower fork sliders, seat bracket, clutch and brake handles, etc.
A good shop will know what to plug and mask off so you don't have to chase or Dremel every hole when it comes back.
Greg Hutchinson BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club http://gregsgssite.shutterfly.com/ ![]() |
09-21-2011, 10:20 AM
#8 |
De Oppresso Liber
Oddometer: 30,330
Might want to check with a place like One Day paint and body.. Correctly applied, a good epoxy paint on a properly prepped frame can last a lifetime and is way smoother and better looking than any powder coated frame I have ever seen. I can also say it is a bit cheaper, less than half what I see powder coating go for.
"I claim to be frightened of horses but do so only to get out of attending parades. It's peculiar but ...it works. The Horses get it. RESISTANCE IS NOT FUTILE. IT'S VOLTAGE DIVIDED BY CURRENT |
09-21-2011, 10:34 AM
#9 |
Oddometer: 173
Epoxy chalks & fades in the sun....
It is hard & chemical resistant but not the best choice.I have used a 2 part liniear polyurethane marine paint in the past.Awlgrip marine paint is very hard & glossy & holds up to the sun.If you are paying someone to do the job,powder coating is the best value.
09-21-2011, 10:45 AM
#10 |
bikes, booze, broads...
Oddometer: 8,306
alternativism
...Have you got the motor out of the frame? If you don't want to go that far, you can get some pretty decent results with some elbow grease and some creative rattlecan techniques...
'08 R1200R / '10 WR290X/R '81 R100RS Rattlecandy Red '06 950 ADV Orangeboom '05 R12GS Wedding Bike '91 R100GSPD Derelict |
09-21-2011, 10:48 AM
#11 |
De Oppresso Liber
Oddometer: 30,330
If the body shop is instructed to use flex agent in the paint it works great on frames. and I have never seen frames that were painted fade in the sun.....In fact, the total faded out beater parts 1969 CL350 I got as a parts bike still has shiny epoxy paint on the frame.
09-21-2011, 10:52 AM
#12 |
Tetrapod
Oddometer: 3,424
I've gone the route of having the frame, swingarm, etc bead blasted (usually fairly cheap, as I recall about $70) and then just haul it out to the back yard and put on multiple coats of good quality enamel spray paint from a can. Last bike I did like that, about 9 years ago now, still looks fine. Less than $100 all up.
Edit: in fact, just starting on a project and this is exactly the process I'm planning to use. http://advrider.com/forums/showthread.php?t=720997
"It's not what you look at that matters, it's what you see." - Thoreau |
09-21-2011, 12:00 PM
#13 | |
De Oppresso Liber
Oddometer: 30,330
09-21-2011, 03:07 PM
#14 |
Oddometer: 4,595
I got some responses from local shops that blast and powdercoat motorcycles, ~ $200 for the frame and other black bits. I think I'm going to go this route and spend my time on the mechanicals like rebuilding the forks, instead of sanding the frame and doing it myself.
09-21-2011, 03:33 PM
#15 | |
De Oppresso Liber
Oddometer: 30,330
