05-07-2012, 11:45 AM
#181 |
Oddometer: 74
Looking good man!!!
05-07-2012, 12:24 PM
#182 |
Lampin' it
Oddometer: 4,234
True I did the exhaust for the main reason of wheel clearance. However the oil filter access is a nice benefit. On my other build I used the stock fz1 exhaust and every time I change the oil, huge mess on the pipes.
We're not out here to rough it. We're here to smooth it . Things are rough enough in town. Nessmuk |
05-07-2012, 12:25 PM
#183 |
Lampin' it
Oddometer: 4,234
05-23-2012, 07:52 PM
#184 |
Lampin' it
Oddometer: 4,234
Lots of good progress has been made. I was at a standstill for a few weeks waiting on some funds to get the final push rolling.
Ordered the last of the epoxy resins I'll need to finish the carbon fiber airbox cover. Getting the steel tubing from my buddy to finish the engine cradle. Got more argon so I can finish welding the header Bought the tank liner so I can seal up the pin holes from my less than airtight tank welding job Once I get the engine cradle finished and bent, I can mount the radiator lower mounts (uppers are done) and that should be the last engine system to get finalized other than the exhaust can mounting Ordered 2 sets of tires for it tonight. I got some Shinko 705 for the dirt wheels and some Bridgestone Battleax tires for the 17 supermoto rims. Also got new sprockets for both wheels ![]() ![]() I expect there will be some teething issues, but am fairly confident that it should work as expected.
05-24-2012, 05:03 AM
#185 |
Once you go Triple...
Oddometer: 20,491
'12 Tiger 800XC '07 TE510 '02 Sprint ST '99 XR650L '99 Speed Triple |
06-02-2012, 03:47 PM
#186 |
Lampin' it
Oddometer: 4,234
Got some good progress on the bike today. I never liked the front engine supports/cradle so I ripped it off and redid them. Most of the reason is that it got in the way of your boots and also couldn't drop the engine. And since I need to drop the engine in order to finish welding the frame...
So I ordered up some more 1" steel for a crash guard/front engine mount/radiator mount. My 1" bending die has a much tighter radius than the 1.25" the old one was made from, but it's plenty strong. ![]() The back part of the guard lands where the rear shock mount ties to the backbone. I decided to plate over the entire area to help stiffen up the frame. ![]() I'm getting better at my ability to bend the way I want it. It gets expensive with DOM tubing costing $4/ft so you tend to learn fast ![]() ![]() I machined up a threaded bushing that I welded to the bars. Also machined up the aluminum spacer I am holding. M10 bolt comes in from the engine side and locks it all together. ![]() Clutch side ![]() Also discovered that my Arrow can is a tight slip fit on my tubing so I just need to attach the spring retainers and make an exhaust mount ![]() I need to take off the header and do some finish welding on it, couple hoses to connect and the engine should fire. The small stuff at the end is what takes so friggen long line the tank Mount the chain and sprockets Make headlight Make rear fender/brake light/blinkers Connect cables Build battery box Get master cylinder sealed up Mount front fender Finish the airbox cover with carbon fiber Redo shifter linkage, right now it's in GP style ![]() Plus about 50 other things I forgot Rip the entire thing down, finish welding, and paint it. Reassemble, go ride. Getting much closer, today was a good day of progress and not a lot of swearing, always a good judge of progress.
06-03-2012, 05:13 AM
#187 |
Oddometer: 997
Those crash bars are nice. Can't wait till she sees the light of day. Can you make different dies for your bender on the lathe?
06-03-2012, 07:47 AM
#188 |
Lampin' it
Oddometer: 4,234
No the dies are specific and rather complicated. The smaller ones are $150-200. The big dues like 2" are 300+
06-03-2012, 06:33 PM
#189 |
louder, louder, louder!
Oddometer: 1,093
Yeah, I keep thinking I need big dies so I can custom bend exhausts, but I keep shying away on the price.
------------------------------ Suck, Squeeze, Bang, Blow ------------------------------ New Rider Training in the San Francisco Bay Area at Motorcycle University". Learn to Ride...Better! |
06-03-2012, 07:09 PM
#190 |
Oddometer: 572
Crash bars look really nice!
06-04-2012, 05:33 AM
#191 | |
Lampin' it
Oddometer: 4,234
I have 2 dies, 1&1.25" which I find covers most what I want. I'd like to get the 3/4 for luggage racks but I get by. Having a tubing bender is one of those purchases you never regret
06-09-2012, 01:37 PM
#192 |
Lampin' it
Oddometer: 4,234
Made some progress after I had the flu
![]() Built out the tail section/fender ![]() ![]() Got a new epoxy system so I decided to play around with some other composites. This is Kevlar, I kinda like the rough look, I might leave it bare like that after I go over it with some more resin. You can see some bubbles under the Kevlar layer which annoy me but not that much ![]() ![]() Ass end with exhaust ![]() I'm getting much closer to where I can possibly ride it. I need to finish welding the exhaust, one more attachment for the radiator, and then seal the gas tank. That should be all the systems needed to fire the motor. I really wish I had the drive to work as hard as I did on the last project but riding is fun too Heading to Hatfield McCoy next weekend with the Husky for some R&R.
06-09-2012, 05:57 PM
#193 |
Oddometer: 667
Thats one wild ride,
06-19-2012, 04:24 AM
#194 |
Oddometer: 594
That tailsection looks killer. (Literally)
"Pay no attention to that man behind the curtain!" Current: 1987 CBR600, 1995 XR600R - Past: 1993 DR350 (Dirt Model) |
07-17-2012, 06:42 PM
#195 |
Oddometer: 997
Hey its been a month since HM, get back to work on this or the trailer project
