Old 10-14-2011, 04:45 PM   #61
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,647
Of course when you go back down to the garage after your wife releases you from duty and jump up and down on tack welds while making revving noises and the tacks break and the shock slams the carbs off the intake and your sweet $3 AA shock mount turns into an awesome nut cruncher, well that would be pretty much what I just experienced.
It does have some sweet ass action though. Right up until shit breaks
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 10-15-2011, 12:07 AM   #62
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,641
Originally Posted by sailah View Post
Here's what I am thinking about for a mount. The tube is beefy, the arms are pretty stout. I plan on bracing up the arms with some of the gussets. Plus running a couple pieces of tubing from the mount back to the frame to help stiffen the mount laterally. It looks plenty burly to me. You?
As always comments and criticism welcome.
I don't think you need the extra tube there. I'd do exactly like what you have in this picture and weld a couple of little tubes into the extra holes on the brackets.
If anything you could add a couple of gussets against the cross tube there and forward along the frame. Crappy quickly drawn lines..
larryboy is online now   Reply With Quote
Old 10-15-2011, 04:04 AM   #63
DRjoe
DRjoe's Avatar
Oddometer: 5,096
An international bike build eh, what could possibly go wrong
All we need to do now is recruit someone who works for UPS.
Originally Posted by LukasM View Post
Ok, I will try to get those measurements for you.
International build sounds cool! I am already trying to get DRJoe to work with me on a custom frame based on KTM 640 or 690 Enduro suspension and parts combined with the Kawi 650 twin (Versys or Ninja). I do the part sourcing and you guys do the design and welding!
By the way I think a BMW F800GS tank and subframe would really work perfectly on the CBR project. The shock cutout is in the same location and you would have all the fuel weight under the seat.... Have a look around the local breakers maybe you can find one cheap.
DRjoe is online now   Reply With Quote
Old 10-15-2011, 07:07 AM   #64
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,647
Absolutely nothing
Larry,
My reasoning for the tubes are that the force vector is trying to wrench the arms forward and off the crosstube as well as rotate that tube. As evidenced by my jumping, it's quite a bit of force. Now admittedly I was jumping on tack welds, but I would like to counteract that force by tying the top of the mount with a short piece of 1" tube. The additional weight is really small and I think it would do a lot to strengthen that whole mount with triangulation. I do like your idea of welding in tubes to the other holes, hadn't thought of that.
I have some smaller gussets I may use forward, what I am more concerned about is stopping the arms from trying to rotate forward as well as lateral stability.
Nessmuk
Old 10-15-2011, 10:03 AM   #65
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,641
Another good trick is to make mounting plates out of 1/4" flat for your cross tube so you can spread the load on the stock frame for that twisting force that the cross tube is going to see. An even better way to do it is to drill the frame and run the main cross tube through both walls of the frame on each side...typing out loud...yeah, that's what I'd do.
Old 10-15-2011, 10:20 AM   #66
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,647
I thought about plating the insides of the frame and considered going through the frame. Couple things stopped me. First I didn't have tubing that long and I didn't want to risk drilling a big hole and not have it aligned perfectly. What I am going to do is brace the cross tube to the frame when I am done. Good points bud
Nessmuk
Old 10-15-2011, 10:27 AM   #67
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,641
I hear ya, it's hard to get things lined up perfectly with angled spars like that frame has.
Ok, gotta get to work on the Zombie.
Maybe I should clean up and re-group, my garage is starting to look like your place.
Old 10-15-2011, 03:46 PM   #68
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,647
I got my rear shock mount where I wanted it. To avoid welds breaking again, I pretty much welded it solid. It'll need finish welding once I drop the motor out and can get to the underside. Mount is really solid. I put a dial indicator on the frame and jumped up and down and barely a wiggle. I took Larryboys advice and burned in two tubing sections to hold the plates together. Couldn't get a weld all the way around those.
Then I turned up a couple pieces and tapped one of them to take the top shock mount bolt. Welded those to the mount.
The angled brace I wanted to keep the mount from rotating forward.
I bent up the top tubes for the subframe. I want it to follow the original lines in the back as I plan on running stock YZ plastic.
I need to redesign my heim joints or redrill them. The struts will be straight.
Sorry about the crappy pics, I was trying to hold stuff and take pics with my cellphone.
Nessmuk
Old 10-15-2011, 04:04 PM   #69
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,641
That looks really good!!
Are you going to do a tube brace on the other side too?
I got some help today over here, nice to have parts held up so I can visualize what I want to do.
Old 10-15-2011, 04:14 PM   #70
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,647
I want to avoid it. I'm putting the battery down there as well as possible drop down in the fuel tank to take up that area and with a brace it is going to really intrude and lock off that space. It might be necessary but that shock mount is pretty tuff as it is, not sure it is necessary. Plus since it's off center due to the swingarm mount, it wouldn't be at the right angle to resist forward rotation like the other one. It would certainly help and with lateral flex but I think I have that covered with the gusset and the other brace.
Nessmuk
Old 10-15-2011, 09:11 PM   #71
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,647
Got a few more things done tonight.
Made the rod ends for the struts and got some of the subframe welded.
The exhaust header isn't going to work stock so I'm going to have to make a custom header that hugs the engine to clear the wheel
The stock header tubes are 1.375". I have a 1.25" die. Anyone see a problem stepping down like that? My limited exhaust knowledge says I'll lose to p end and gain torque. Yes or no?
Nessmuk
Old 10-15-2011, 09:28 PM   #72
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,641
Yeah, it's plenty strong. Do what fits.
Old 10-16-2011, 07:21 AM   #73
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,049
Yep more torque, just what you need
Your shock mount looks weak to me. You really need another brace in tension IMO.
Old 10-16-2011, 07:36 AM   #74
pennswoodsed
lizards,bugs and me
pennswoodsed's Avatar
Oddometer: 748
short answer
Yes , swag #,s and MEZ portings website advised torque peak moves 650 to 800 rpm downward for each 1/8 inch diam reduction of headpipe . My understanding (swag) is that collector behavior will mitigate small headpipes ,anyhoo.
Regards,Ed
ps Where are you located ?
pennswoodsed is offline   Reply With Quote
Old 10-16-2011, 08:12 AM   #75
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,647
Well I think after building a 145HP bike that maybe I don't 12k redline offroad
What about the mount looks weak specifically? I'm not one to underengineer a mount, but this mount is better thought out and stronger IMO than what I put on the FZ1. The crossbar will resist rotational forces applied by the lever arm and the diagonal to the frame will lock the arms in place. The only thing I see being an issue is the force vector of the arms is straight ahead rotating clockwise, the diagonal is off on an angle so the arms could buckle with extreme force applied which is why I put in the gusset.
I'm not trying to disagree with you just want to understand what makes you think that. I am open to ideas, Larrys idea of the tubes through the vacant holes made that bad boy bombproof. I also designed the bolt collars to be fat enough so that I would join the tube and the collar to further help the strength.
To me, it looks way heavier duty than what I removed, granted that was street bike stuff. But the forces were greater due to the angle and short stroke of the shock. This bike has the angle in favor of strength and a much longer and plush stroke to reduce shock load. And believe me when I say I ain't doing 30' triples
Regards,Ed
That would be great. Not only do I have the correct bending dies to make the SS header, the smaller pipes will make it easier to fit. The bike stock is about 100 HP, I would love to lose 20 and make that back in torque numbers. Even a couple would be nice. When I have taken my FZ offroad, you need to be so careful as it doesn't like to lug and my Lord will it spin some tires.
Plus those pipes are heavy as hell and I need to lose some weight.
I'm in Pittsburgh, PA
Nessmuk
Times are GMT -7.   It's 04:11 PM.
