Old 01-26-2012, 02:54 PM   #226
SportFaller
Dirt dont hurt, MUCH
SportFaller's Avatar
Oddometer: 646
and double check all the hardware after the first offroad ride, I lost both bolts from the stem support.
Shoulda used more loctite
"The chokers, and the chain saws, and the log trucks have been stilled, now spotted owls, and hippy gals, run freely through the woods!"
Bikeless in WY
http://www.dakotadualsportriders.com
SportFaller is online now   Reply With Quote
Old 01-26-2012, 02:57 PM   #227
Casejeep OP
Casejeep's Avatar
Oddometer: 733
oh yeah i got a big tube of locktite. i plan on using it on everything!
Casejeep is offline   Reply With Quote
Old 01-27-2012, 07:36 PM   #228
BMW_BIKER_KEITH
BMW_BIKER_KEITH's Avatar
Oddometer: 356
BMW Sertao
I was at a BMW store on Eugene OR over the week, and was looking at the G 650 GS.
The front fender / beak is VERY interesting! It moves with the steering. And it looks awesome...
Has anyone else looked at the fender set up on this G 650 Sertao ?
I have a hunch it may contain the needed parts to rebuild the F800GS front beak once you overhaul the cross over brake lines...
See: http://bmw.westsideracing.com/new_ve...sc=Motorcycles&
2010 Lava F800GS...AKA "Dirty Harry"
1998 R1200C Classic Black...AKA "Dick The Cruiser"
BMW_BIKER_KEITH is offline   Reply With Quote
Old 01-27-2012, 08:33 PM   #229
eddyturn
Wannabe
eddyturn's Avatar
Oddometer: 980
Originally Posted by Casejeep View Post
So here is what it looks like on the bike in full daylight.
OK... now that is a damn fine looking bike. Makes me think I should have gone with the white Mirage.
All things being equal... fat people use more soap
eddyturn is offline   Reply With Quote
Old 01-30-2012, 08:32 AM   #230
Casejeep OP
Casejeep's Avatar
Oddometer: 733
Here are some pictures of my local ride, my first with my new tires! also have a video too.
Casejeep screwed with this post 01-30-2012 at 09:21 PM
Old 01-30-2012, 07:48 PM   #231
Casejeep OP
Casejeep's Avatar
Oddometer: 733
After a chance to calm down i undid the fairing and reinstalled it for you all!
so first you take off the window and the gauge cluster, you take the cluster off by pulling off the retaining clips, they come off easy with needle-nose pliers. Note: Keep these, if you loose them they will cost you $1.50 each and you will reuse them.
These are the 2 pre drilled holes that you will be using to bolt on the new dash.
first you want to install the cluster on the dash. it makes the install so much easier.
Bolt on the dash with the 2 bolts, only screw the bolts on only 2 turns or so. try and leave it as loose as possible.
now you will want and plug the gauges back in.
Then place the outer part into position. i screwed the 2 side ones in fist, also, keep them loose. then the 2 in the center.
i then placed locktite on the 4 small screws that bolt the fairing to the dash and screw them on tight.
then place a drop of locktite on the 2 dash bolts and screw tight.
then tighten up the fairing bolts. NOTE: DO NOT USE LOCKTITE ON THESE BOLTS!!!!!!!!!!! i did and now i will never be able to take them out. it uses a rubber thing and it just spins.
Old 01-31-2012, 06:11 AM   #232
SportFaller
Oddometer: 646
I made the same mistake, loctite-ing the rubber grommets. when I took it apart to put on my new GPS, I ended up having to replace those with regular nuts. Now we know....
Bikeless in WY
Old 04-04-2012, 01:09 PM   #233
The Jester
The Jester's Avatar
Oddometer: 711
Haven't viewed all your photos as my internet connection is too slow to download them. Looks like you have done a lot of work on your bike. Judging by your post in thumpers it might be time for some suspension upgrades. Check here for inspiration
Life is not a rehearsal!
The Jester is offline   Reply With Quote
Old 04-05-2012, 12:12 AM   #234
Casejeep OP
Casejeep's Avatar
Oddometer: 733
Im starting to plan some trips and im realizing that the 800 doesnt have enough fuel for the trips i want to do. yes yes i know in the US your always within 200miles of gas, but im planning trips though Arizona and Utah through reservations all on dirt roads. its easy to go 200 miles on dirt without hitting a gas station.
OK so anyway. I was looking that the ADV Tank, but it only leave that little rear rack for your bag, and only 1.6gallons. I have Wolfman side bags so i dont have a whole lot of room in them so ill need to put the majority of my stuff in a rear bag, which that little top rack wont support well. and at $300 i can shop around first.
So i figured i could get RotoPaX 2 gallon. And the 2 gallon is thin and longer, which makes a large mounting area for a rear duffle.
(picture by Toowheels)
But im thinking since i have that one back there might as well but some water there too since ill be riding though lots of desert. but my worry is the weight.
2 Gallons Gas= 8.35lbs X2 = 16.5lbs
2 Gallons Water= 8.35lbs X2 = 16.5lbs
The RotoPaX= 5lbs X2= 10lbs
For a total extra weight of 43.5lbs
that is a huge number to have back there. would anyone do this?
Old 04-05-2012, 02:53 PM   #235
Buster714
instant human
Buster714's Avatar
Oddometer: 421
Let's figure out how to get the liquid storage down lower on the bike and pack the lighter stuff up top. You can get adapters to drop the rotopax down on the sides (water on one, fuel on the other) of the MOD top rack and put the GL great basin bag over/around that. There'd still be room on top for another dry bag if you needed it. I know you have those little wolfman bags on the racks but I'd make room for the heavy stuff down there. If there's room for the rotopax INSIDE the racks that'd be perfect. That way the rack protects the bike in a fall instead of a fuel container (yikes!). You can bring the bike by sometime and we can match up the rotopax containers and see what's possible. Just some ideas. I don't even have this much storage going on but you're usually a little ahead of me on this stuff.
Aram :: SoloMotoParts.com :: Motorcycle Parts, Gear, and Accessories
No Tax / Free Shipping / Hassle-Free Returns / Friendly Customer Service
Rekluse Video Review :: Blog :: YouTube :: Facebook :: Aram's Spot
Buster714 is offline   Reply With Quote
Old 04-05-2012, 03:19 PM   #236
toowheels
on a mission...
toowheels's Avatar
Oddometer: 837
Hi Casejeep!
Actually gas weighs 6.1lbs. per gal = 12.2lbs. for the 2gals. of gas.
Maybe 1gal of water would do it too and then some in a Camelbak while you ride (or are you as thirsty as your bike ). Then search out the water wells etc.
That's what I was going to say too Buster (Hi!) but for the MOD Top Rack you can only side mount a 1gal. and only on the non-exhaust side:
and it does work very well with the Giant Loop Great Basin as Buster suggested:
Since you have the Wolfman rack though I agree with Buster on the inside mounting on the right side(right again Buster! )
I think you may only be able to fit a 1gal in there though?
Don't forget Rotopax also has a new 1.5gal version but it sounds like you want more.
It can usually be only temporary weight up there. Dump it all in the tank as soon as you can on your ride and done!
Dave
Moto Overland [MOD] -Skid Plates, Top racks, Tool Boxes etc for Adventure bikes
& Giant Loop for Canada
www.motooverland.com
toowheels is offline   Reply With Quote
Old 04-09-2012, 03:34 PM   #237
Casejeep OP
Casejeep's Avatar
Oddometer: 733
So this weekend i did some work on my bike for my upcoming Death Valley trip in 3 weeks.
Well first i washed it, because a clean bike just wants to get dirty again...
But for my trip i bought a SPOT 2 from Best Buy for $50 (they were on sale)
so because of this i went and bought a RAM mount for it, and since i was there i bought a RAM mount for my 60CSx.
So when i got my SPOT mount i looked at the clamp that goes around your bar but there was only like a 1/4inch gap, there was no way to put it on without taking the grip off and everything. So i went looking around to see how other people have done it. and people had with the exact same mount i had. so i pm'ed Emmbeedee, and he just told me to heat it up in some hot water and push it on.
so i put boiling water into a cup and placed the clamp part into the water and let it sit for 3-5mins.
Untitled
And then i just pushed it on, and it didnt snap. i was amazed!
Untitled
i placed it on the side because im going to be installing a SCOTTS so i would have had to move it so might as well put it where it belongs.
Then i tethered the SPOT to the bike using some cord just incase i go down hard i wont lose it somewhere.
Untitled
Now to installing the RAM mount for my GPS.
Since i have the Mariage 2 fairing i would mount it to that, i dont want my bars to bet too busy.
I found the best place to put it where the bars wouldnt hit if when im turning.
Untitled
this placement works out very well, all i used is the bolts that came with the RAM mount and bought washers and a lockbolts and drilled the holes. very simple.
Untitled
Untitled
Untitled
Untitled
And the final look with both of them.
Untitled
Old 04-09-2012, 03:41 PM   #238
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,962
that extra handguard clamp can be used!
Motorfiets is offline   Reply With Quote
Old 04-09-2012, 03:56 PM   #239
Casejeep OP
Casejeep's Avatar
Oddometer: 733
I was keeping it because I figured I could use it for something. What is that that you have mounted?
Old 04-09-2012, 04:45 PM   #240
Motorfiets
Motorfiets's Avatar
Oddometer: 2,962
its a pelican case that housed a on bike camera DVR recorder (reason behind the three plugs) but i gutted the case and use it as a point and shoot case / wallet and phone case now
Times are GMT -7.   It's 12:17 AM.
