Old 06-29-2012, 10:30 AM   #286
Twin-shocker
Oddometer: 1,673
Has the Aus OKO importer now gone out of business I wonder?
Old 06-29-2012, 10:44 AM   #287
ivsforever
Oddometer: 16
OKO or Mikuni Carb
Originally Posted by Pete-NZ View Post
I have a 35 year old Amal on my Cota 348..
I think a new carb wouldn't hurt it..
I see OKO carbs seem to have bit of a following.
Are they any better than a Mikuni ?
Try www.OKO-Australia.com.au/
The website works?.
ivsforever is offline   Reply With Quote
Old 06-29-2012, 06:53 PM   #288
SnoDrtRider
Got Snow?
SnoDrtRider's Avatar
Oddometer: 2,395
Thanks...
I better check out if they are a no go here aswell before I buy to be safe...
Has anyone dealt with this out fit ?.... Are they above board ?...
http://www.mid-atlantictrials.com/Menu.html
They have pre jetted OKO 101 carbs for the Cota 348..
Originally Posted by motojunky View Post
Yes, Mid-Atlantic Trials is above board. It's a "he" as opposed to a "they" and he's a good guy. I've been competing in the Mid-Atlantic Trials series since early last year and have gotten to know him fairly well. I would have no hesitation purchasing from him if I needed a carb.
Originally Posted by Jeff_S2R1K View Post
Definitely above board! Great guy to deal with.
+++ on Roger being a great guy to deal with...
Toying around with the idea of an OKO for my Cota 200 one night I send roger and E-mail with my info. A few minutes later the phone rings and it's Roger we spend a half hour discussing options, bikes and Mid Atlantic Trials.
Wayne 2005 BMW F650GS... 1984 HD FXRS
Gone but not forgotten...
'80 Montesa Cota 200, '03 DRZ 400s,
'80 Suzuki GS850G, '74 Honda MT250 Enduro
'71 Kawasaki 100,1971 Honda SL70, Sears Mini Bike
SnoDrtRider is offline   Reply With Quote
Old 06-29-2012, 09:03 PM   #289
Pete-NZ
Pete-NZ's Avatar
Oddometer: 730
I think I will get it though him.. And hes got everything I want in one place
carb / air cleaner / cable kit / side pull twist grip..
And his site gives you the shiping cost right up front with out
haveing to go though the buy process only to be shocked
when the shiping cost is tagged on....
Thats out of the way......
SHOCK & FORK SPRING QUESTION
What are the best make/type for a Cota 348 ?
How do Betor shocks stack up ?
Here.... my XR250 leaner side car build
http://www.advrider.com/forums/showthread.php?t=716993
Pete-NZ is offline   Reply With Quote
Old 07-01-2012, 12:03 AM   #290
AteamNM
Wonna Be ADVrider
AteamNM's Avatar
Oddometer: 3,670
http://advrider.com/forums/showthread.php?t=794576
North Carolina - Mint!
1987 Honda Reflex 200 Trials bike (TLR 200)
I have for sale a 1987 Honda Reflex 200. It had 400 original miles on it when purchased from the original owner, and now has a hair over 1000. It is completely stock, except for the tires which are new. It is extremely clean and was stored in a shed under a cover. It starts on the first kick, doesn't burn oil, and is a pleasure to ride. The pictures speak for themselves. It has a clear NC title and the tags still have quite a bit of time on them. I believe it could use a stator rewinding due to the fact that the lights are sometimes dim. Asking $1800 please ask if you have any questions! I have no idea what these are worth, if I'm way low or high let me know!
The Honda Reflex (TLR200) is a dual purpose trials motorcycle sold through 1986 to 1987. Both year models are the exactly the same. 1987 models were left over bikes from 1986, re-badged as 1987 models. The Honda Reflex used an XR200 engine in a different frame. This engine was the also used in a three-wheeler made by Honda.
The Reflex also has the tight turning radii typical of trials motorcycles. Its steering column can almost turn completely horizontal to the bike's frame. It's designed to be a stand up motorcycle, though it does have a seat and lights for road use. With light sprocket modifications it is a functional bike for motorcycle trials
Specifications
Dimensions
Overall Length: 2080mm
Seat height: 780mm
Dry weight: 90 kg
Engine
Type: Gasoline air cooled 4 stroke cycle
Bore x Stroke: 65.5 x 57.8mm
Compression Ratio: 8.2:1
Valve Train: Over head cam Chain driven
Maximum Horsepower: 13.4ps/6,500rpm
Displacement: 194cc
Drive Train
Clutch: Wet Multi Plate
Transmission 6 speed constant mesh
Frame
Type: Diamond Frame
Front suspension Travel:160mm
Rear suspension Travel:150mm
AteamNM is online now   Reply With Quote
Old 07-01-2012, 02:32 AM   #291
Twin-shocker
Oddometer: 1,673
I wonder whether or not it would be better to keep the stock air box, as removing this means water can get inside the motor pretty easily? Its possible to make adapters to fit OKO carbs to stock air boxes, and its also a good idea to modify them slightly for trials use, as fuel starvation can be a problem unless this alteration has been carried out.
Old 07-01-2012, 02:44 AM   #292
Twin-shocker
Oddometer: 1,673
Reflex uses a TLR motor..........only difference being that Reflex was fitted with US required smog equipment, which means reduced power and is less responsive than the TLR.
XR has considerably more power than the Reflex/TLR, as well as different gearing, ignition system, clutch cover, cylinder head, cylinder, compression ratio, crankshaft.
ATC200 motor is basically the same as XR except it has completely different kickstart which kicks forward, and different gear ratios.
ATC200X motors use different cylinder and head castings to ATC200, and these are worth fitting to trials bikes as the fins are bigger and cooling is better.
Reflex fitted with a few cheap pit bike parts from Ebay, works much better than stock TLR, and the only downside to these bikes over the TLR is the front forks and steel wheel rims.
Old 07-01-2012, 02:45 AM   #293
Pete-NZ
Pete-NZ's Avatar
Oddometer: 730
You are so correct....
Air box was missing when I bought it...
If I could fined one I would be all over it like a blow fly on a turd..
But till then I will make do with a uni filter..
If I have to I fabicate a alloy unit..
Pete-NZ screwed with this post 07-01-2012 at 02:57 AM
Old 07-01-2012, 04:00 AM   #294
Twin-shocker
Oddometer: 1,673
Can see your problem...........seems strange you cant find a used air box, as there were quite a few of those bikes made? Easy way to make one would be a cut the shape you need out of polystyrene, making it a little smaller than required, lay up GRP over that and when the GRP has cured cut hole for the intake tube, pour in acetone which will dissolve the polystyrene. Wont look as nice as alloy, but should work fine and will be easy enough to make.
Old 07-01-2012, 04:12 AM   #295
Pete-NZ
Pete-NZ's Avatar
Oddometer: 730
Thats not a silly idea...
didn't think of it....
I use the build alloy jet boats hull..we put GRP tops on them
so done heaps of fiber glassing...
PVC foam is the stuff to use..
Pete-NZ screwed with this post 07-01-2012 at 04:17 AM
Old 07-01-2012, 04:29 AM   #296
Twin-shocker
Oddometer: 1,673
PU foam cant be dissolved by acetone, so you would need to make filter in 2 parts or cut it in half and join back together.
Old 07-01-2012, 04:36 AM   #297
Pete-NZ
Pete-NZ's Avatar
Oddometer: 730
Open top.. dig it out
Old 07-01-2012, 04:45 AM   #298
Twin-shocker
Oddometer: 1,673
Means a lot of work which isnt needed................I would tend to make filter with closed top, and cut a hole in it to accept filter element from modern bike.
Old 07-26-2012, 08:34 PM   #299
Pete-NZ
Pete-NZ's Avatar
Oddometer: 730
Got the frame finished... just waiting on a shit load of bits to arrive..
shocks/fork springs/guards/carb/decals etc...
Having probs finding stainless spoke kits.... They want silly prises for custom made kits...
Wheels will have gold anodized rims with black hubs...
By petenz at 2012-07-26
Pete-NZ screwed with this post 07-27-2012 at 01:31 AM
Old 07-26-2012, 10:16 PM   #300
lineaway
Oddometer: 2,575
Wow , that `77 sure resembles an `82. Nice.
lineaway is online now   Reply With Quote
Times are GMT -7.   It's 04:28 PM.
