12-26-2011, 09:12 AM
#121 |
Oddometer: 23
I am running Maxima synthetic @ 32 to 1 in my 247 Cotas and it works well. I probably could go with less oil but I figure if it is not fouling plugs it is good to go. That is a nice 200 Cota you picked up...
Be careful however as 2 years ago I couldn't spell "Cota" and now I have 3 of them! I don't get how that works.... ![]() Sam |
12-26-2011, 11:16 AM
#122 |
Oddometer: 191
Silkolene Comp 2 is a great oil that burns clean and leaves little residue behind.
All 2T oils will "protect" a trials engine so therefore a "clean burn" is what becomes important. http://www.silkolene.com/index.php?c...duct&sub=ride# Since a trials bikes runs at low RPM much of the oil goes un-burned and residue builds up in the engine and exhaust. On some bikes you can see the black spooge leaking out of some exhaust pipe joints.....also the exhaust packing gets soaked in oil and hardens the packing and then performance decreases. That is why re-packing silencers becomes necessary. That's also why you see 2 stroke trials bikes smoke like crazy after a long hill climb...the exhaust is full of un-burned oil. |
12-26-2011, 01:32 PM
#123 | |
Location: Summer: Kemiö, Finland; Winter: North Germany
Oddometer: 641
For normal classic trials 1:75 or 1,5% is standard here in Europe, for modern indoor events 1:100 / 1% is standard. To be sure not to clogg your exhaust something inbetween 1:50 for trails and 1:75 for trial is completly OK when you use synthetic 2-stroke oil like Ipone shyntesis 2 which has a homologation for to be used up to 1,5%: http://www.trials-action.de/product_...roducts_id=729 Mix it with premium gas and the lowest amount of ethanol you can get. In the "old" days due to the closed build exhausts, (see (*) ), we got 1:100 or 1% two-stroke oil that was expecially made for Bultaco trialsbikes for example, (Montesa or Fantic, ... had also their own homologated brands oil too). They don't produce this oil anymore and sadly with the new kind of gas not recommendable anymore. Back then I never had any issues with 1:100 or 1% when using the Bultaco oil, sadly got very fast a problem with Castrol TTS, which isn't bad either but doesnt deliver a full "grease-layer" when thinned so much. |
12-26-2011, 01:53 PM
#124 | |
Oddometer: 641
Very cool and much better then a heavy Bultaco Sherpa (I have a Bultaco Sherpa !!!), the Montesa is much lighter has a shorter wheelbase, ... you can do terrific thing with this bike. Congratulation to your decision. Here in Germany this model is often used in classictrials, there are also a lot of modded bikes around, here a 330 from Spain:
12-26-2011, 05:14 PM
#125 |
Got Snow?
Oddometer: 2,025
I think the manual calls for 3% but that would be oil from back in 1980 plus good non ethanol fuel. There are some places around that reportedly still have non ethanol fuel but I need to research where to get it.
Thanks for all the info and accolades regarding the decision... I assure you it was purely beginners luck... I saw it on Craigslist and e-mailed the seller and next thing I know I'm making plans to go see it the following morning. I had second thoughts after reading about the kickstart issues and some transmission troubles but I figured I at least owed the seller a look at for his troubles. Once I saw that it was 99% original and in great shape I figured I couldn't really go wrong.
Wayne - 1984 HD FXRS... Not your stereotypical Harley rider. 1980 Montesa Cota 200 Got Logs? 03 DRZ 400s Gone but not forgotten... Days get shorter, Nights get longer, Snow gets deeper... Life is good! |
12-26-2011, 07:27 PM
#126 | |
Professional Idiot
Oddometer: 927
12-27-2011, 03:37 AM
#127 |
Got Snow?
Oddometer: 2,025
Yes it was in Newark... Strange thing was that I had been searching CL for Bultaco, Ossa, Montesa for over a month and it just showed up even though the post date was Nov. 26th.
12-27-2011, 07:32 AM
#128 |
Oddometer: 31
Winter Project
1983 Cota 349.
Do-list: - Lower the footpegs, 25mm or so. - Fix the LOUSY brakes. Hopefully Galfer makes shoes for it. - Try to improve the on/off clutch. - Remove the chain tubes (it has a chain tensioner). - Experiment with raising the forks, 10mm or so.
12-27-2011, 07:41 AM
#129 | |
Trails Evangelist
Oddometer: 967
- get some hand squeezing workout tools, that is what it will take. Heheee Crap, looks like museum quality? drum brakes are just crappy, that is why arhma and itsa wont let you convert to disc, they are that much better even with 80's era calipers, you know? what you can do is sand the pads enough to get that hardened/contaminated layer off, easy here, you want to preserve that 99% of the pads contact the drum area, if you get this out of round so to speak, braking gets worse. I always slightly sand on the drums, kind of cross ways, so it wears the pads in better seems to brake better. that was back in the day, but you risk eventually wearing out the drum area eventually. Some were thinly chrome plated drum inserts. Not positive about montessa, I had the 1975 172 model in my day... |
12-27-2011, 09:07 AM
#130 | |
Oddometer: 641
This is a very nice Montesa, a real machine of the beginning 80's with 350cc! To your chain tubes, one of the best things Montesa invited, many build these tubes to their other machines to get the chain better protected against mud, ... (I did mount them to my Italjet Piuma back these days!). The drum brakes are drum brakes you can't expect the power of disk brakes, to get the maximum out of your brakes do as follows: - take chalk and appla it to the brake pads, now mount the the brake capilar with the axle in the hub, turn the capilar and engage the brake lever her and then. When you now take the capilar out ayou will see how much of the brake have really contact with the drum, normally only 30% when new pads are insatalled. Easiset way to align them to the drum is to mount the complete capilar with the pads in a lathe and turn down exessive material. Then you have full contact between brake drum and brake pad: After milling away exessive material with a lathe: The trick is to mount new brake pads as the old one are to hard, fresh coated ones are much smoother and do their job very well. An enhancement would be to place steel inserts inside the drums, these will brake much better, Last enhancement you can do is to mount grooved brake pads if you want, but these wear quick! ![]() Here the adress for the grooved brake pads: http://www.trialsbits.co.uk/product_...roducts_id=178 |
12-29-2011, 08:02 PM
#131 |
the famous james
Oddometer: 8,072
1975 Honda TL250
This is my ride
I am not intimidated by the DMV James and Colleen Tucker.Real Cafe Racers drink tea. Aut viam inveniam aut faciam |
12-29-2011, 08:03 PM
#132 |
the famous james
Oddometer: 8,072
another
other side
01-03-2012, 03:25 PM
#133 | |
Oddometer: 58
Here's my Dalesman :) ![]() My dad purchased it new and it was the first bike I rode on when I was 3 or 4 until I got my own bike. I still have it , and love it. Any idea where to get a cork for the Ewarts petcock? Awesome thread. Lurkerlou screwed with this post 01-03-2012 at 04:21 PM |
01-03-2012, 05:00 PM
#134 | |
Oddometer: 641
![]() ![]() ![]() To the petcock you might, (I' am not sure), find here the right cork for your petcock: http://www.domiracer.com/petcocks.html |
01-03-2012, 07:15 PM
#135 |
Oddometer: 58
I replied to your PM too PSchrauber that is the ticket right there buddy.
10 of them for $6.95 you gotta love that! Thanks again for the steer in the right direction my friend. |
