| View Results: Explorer or Explorer/XC | |||
| Explorer |
0 | 0% |
| Explorer/xc |
0 | 0% |
| Voters: 0. You may not vote on this poll | |||
03-09-2012, 11:57 AM
#1621 |
2 Wheeled Backpacker
Oddometer: 206
Nice little blurb here about Triumphs
http://www.motorcycledaily.com/2012/...ning-momentum/
1996 Triumph Daytona 1200 Gopher Everett? No thank you, Delmar. One third of a gopher would only arouse my appetite without bedding it down. |
03-09-2012, 12:07 PM
#1622 |
Oddometer: 17,983
It is fair to say that I was more than a little excited as I approached the neatly organized line of thirty brand new shiny Triumph Tiger 1200 Explorers glistening in the morning sun of southern Spain. The various press reviews I had read had all been very positive and I was keen to see just how good it really is. Although there was not a cloud in the sky the temperature was still a little nippy at just 6 degrees C, so I promptly selected a bike with heated grips fitted as I only had my summer gloves with me and I am basically a wimp when it comes to riding with cold hands.
The first major thing that hit me when I sat on the bike and lifted it off the side stand was how incredibly light it felt. The official weight figures for the Explorer claim it is some thirty kilos heavier than the BMW R1200GS which is the benchmark bike in this class, a bike which I have ridden many times and always feels heavy when you lift it off the side stand. With this in mind I was expecting the Explorer with it’s extra weight to feel heavier, however Triumph have clearly given this matter serious consideration and have created a very well balanced bike that is easy to lift off the side stand and carries it’s weight very well indeed. This became even more evident as I wheeled the bike backwards out of the line up and eased it onto the centre stand with very little effort. As I pressed the starter button I was met with the unmistakable growl of a Triumph triple, which quickly turns into a pleasing yet inoffensive snarl as the revs rise. Even from cold the engine feels crisp and responsive and the bike feels instantly familiar: you know you’re sitting on a Triumph. The first part of our route took in several miles of motorway so I decided to have a play with the cruise control, which is fitted as standard on the Explorer. The operation is really quite simple: you must be in fourth gear or higher, press the cruise control switch (I switched it on before starting the ride and just left it on standby), then when you want to use it just press and hold the ‘Set’ button on the right switchgear for a couple of seconds and it’s on. You can then adjust the desired speed easily by pressing the ‘up’ or ‘down’ buttons. Coming off cruise control is also simple, either touch the brake, pull the clutch lever or rotate the throttle twist grip forward as far as it will go. Soon we left the motorway and headed into the mountains onto twistier roads and I was quickly surprised by just how well the Explorer handles. It is remarkably planted through the corners and changes direction effortlessly even at speed. On several occasions I encountered significant bumps mid corner which where no problem for the bike, and on one particular corner there was a speed bump which I hit at over sixty mph whilst still leaning slightly, this I expected to be messy, but again the suspension dealt with it with minimal fuss. At one point I slowed the Explorer down to under 2000RPM in sixth gear and fully opened the throttle to see how the engine responded. The result was no juddering, just smooth acceleration which grew with the revs, this is due to the massive amount of torque and the ride by wire throttle; the engine does not bog down or over fuel, it just pulls cleanly. On the outbound journey I had set the seat in it’s lowest position, which although not uncomfortable, I found a little too low for my 6’2” frame, so for the return journey I raised it to the higher position which I found suited me better. Overall I found the upright riding position and spacious layout to be very comfortable and at no point during the two and a half hours that I was riding did I feel uncomfortable in any way. During the ride I left the adjustable screen in it’s standard position which offered more than adequate protection from the wind, with very little buffeting. On reflection when I arrived back at our hotel it was easy to see why the press are raving so much about the Explorer; it is a very versatile all round bike, the riding position is natural and very comfortable with good wind protection, the chassis is extremely well balanced meaning it is easy to maneuver both when riding and when parking / pushing and the engine is absolutely superb with lots of torque and smooth, useable power throughout the rev range. The gearbox is slick and the controls are intuitive and fall easily to hand. As for the total riding experience, the Explorer is very hard not to like; it is equally competent cruising down a motorway as it is on twisty roads, and when ridden hard it delivers in every aspect. I had big expectations for the Explorer and I am pleased to say that they were easily surpassed. I cannot wait to get on our demonstrator. __________________ What is past is prologue Willy Shakespeare
"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind." — Dr. Seuss “Watch out for everything bigger than you, they have the "right of weight" Bib |
03-09-2012, 06:12 PM
#1623 |
Oddometer: 903
03-10-2012, 04:23 AM
#1624 |
echt bezopen
Oddometer: 394
My dealer (Mport Rotterdam) has a black Explorer on display.
03-10-2012, 07:58 AM
#1625 |
Oddometer: 17
03-10-2012, 08:54 AM
#1626 |
Oddometer: 10
Then this must look familiar...
photo1 ![]() photo2 ![]() photo3 ![]() photo4 ![]() photo5 ![]() photo6 ![]() At first I didn't even see it eventhough it's located at the entrance, but behind another motorcycle (visible on photo nr.4).I expected it to be in the Triumphcorner, hence my initial disappointment to only find a cardboard Explorer (photo nr. 1). ![]() The black whathamacallit finishing on the left heelplate (photo 2 & 6) is missing. And the tank seems to be bulkier on the one seen by me at the Dutch Utrecht motorexhibition. But that it's due to the angle in which the photo was taken in combination with poor lighting. Or perhaps black isn't the right color for it. ![]() Is the driveshaft (photo 6) to big? You may all judge for yourself. I'll drop by my own dealer trying to find out more, which will probably be next saturday. edit: Truth be told, putting it near the entrance is however the perfect location to role it out to give it a spin! ndeeka screwed with this post 03-10-2012 at 09:00 AM |
03-10-2012, 09:38 AM
#1627 |
echt bezopen
Oddometer: 394
It's their demo so you can take it out
when my 800 goes in for service next week or so I will go for a little testride with the 1200
03-10-2012, 09:45 AM
#1628 | |
Oddometer: 10
![]() Please report back, here or at MF, doesn't matter for me. Actually... I might do the same, the engine needs to be broken in anyway.
03-10-2012, 09:53 AM
#1629 |
motomaniac
Oddometer: 140
I'm really impressed how they cleaned up the motor its just clean looking compared to my 03 S3 which has hoses running everywhere on the outside.
The black and grey they used also looks good compared to a solid black motor,I can only imagine how this engine must run .My 955i had plenty of power and never had one hicup in the 8 years I owned it, much better than my wifes 885 in her 97 (T509) so much smoother. This bike is gonna be like riding a raped ape
03-10-2012, 10:09 AM
#1630 |
Oddometer: 451
03-10-2012, 03:03 PM
#1631 |
armchair asshole
Oddometer: 2,551
Has the centerstand recall for this bike been announced yet?
03-10-2012, 08:09 PM
#1632 | |
Oddometer: 471
2003 Aprilia Tuono 2002 Triumph Sprint ST |
03-11-2012, 03:35 AM
#1633 |
Tiger Racing Division
Oddometer: 9
Here you could found my report of triumph explorer press launch in Granada, hope you enjoy it
http://www.mrtigerontheroad.com/?p=397
BIG TOY FOR BIG BOY |
03-11-2012, 05:12 AM
#1634 | |
pass the catnip
Oddometer: 7,546
That's the best review I've seen so far in terms of outlining features. Thanks! |
03-11-2012, 06:05 AM
#1635 | |
Oddometer: 867
2013 HyperStrada 2012 Super Tenere 09 Monster 696 (wife's bike) |
