Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
View Results: Explorer or Explorer/XC
Explorer 0 0%
Explorer/xc 0 0%
Voters: 0. You may not vote on this poll
Old 01-04-2013, 05:58 PM   #3541
Voluhzia
iExplorer
Voluhzia's Avatar
Oddometer: 1,605
I changed oil/filter myself and paid $180 (all I paid to date) for 10K service. I'm at 18000 miles now and did have valves adjusted at 16K under warranty (I bitched too much), now will change oil/filter at 20K myself... Maybe I'll change air filter myself as well (requires tank removal)... Did asked to change spark plugs at 10K so will skip 20K plugs...
So far - I like owning the Explorer, cheap maintenance, powerful, reliable, cool looking, so am I on it :)
Facebook
Nova Scotia on Explorer
2012 Triumph Tiger Explorer
http://novascotiaexplorer.blogspot.com/
Voluhzia is offline   Reply With Quote
Old 01-05-2013, 03:57 AM   #3542
Kenbike
Oddometer: 696
For all of you owners who have some miles on the bike do you feel the front forks work ok as or does the fork really require compression and rebound dampening adjustments?
If it does require adjustments have you found any cost effective aftermarket options?
Ditto on rear shock, how does it work and if you have gone aftermarket what was your solution?
Has anyone found any way to strip any noticeable weight off the bike? I would assume swapping the stock muffler would save some weight?
How are all of the handle bars controls and switches holding up?
Never had a Truimph before and was wondering how these bikes are working out?
Current Bikes: 2014 BMW GSA, 2010 Vespa 300 Super scooter ( hers), 2012 Vespa 300 Super (his)
Kenbike is offline   Reply With Quote
Old 01-05-2013, 06:02 AM   #3543
Voluhzia
iExplorer
Voluhzia's Avatar
Oddometer: 1,605
Controls are OK, it hasn't been a year yet but I don't see any problems.
I have no problems with front forks, neither I did with my Vee before but people kept telling me they suck.
I like OEM exhaust can and don't worry about stripping weight down.
It's my first Triumph too. And I have a great relationship with my dealer and don't hesitate to buy stuff from them even its a little more expensive.
Facebook
Old 01-05-2013, 10:28 AM   #3544
gregdee
Motocampist
gregdee's Avatar
Oddometer: 458
[QUOTE=Kenbike;20400146
Never had a Truimph before and was wondering how these bikes are working out?[/QUOTE]
It's not quite the same but I can speak for Triumph quality. I have an '08 Sprint and I've only ever had one issue with anything at all. The fuel gauge was way off shortly after buying the bike and it was replaced under warranty. Otherwise, I have not had any issues but the rubber on the buttons on the dash is starting to deteriorate. The rubber isn't visibly cracking or anything but it is just starting to get that tacky feel to it. The bike does sit outside when I ride it to work but that's probably been fewer than 100 days. The NM sun is brutal on anything plastic or rubber.
gregdee is offline   Reply With Quote
Old 01-05-2013, 02:36 PM   #3545
Big Jon
Big Jon's Avatar
Oddometer: 339
Thumb
I've had mine since May and haven't had any trouble at all with it. I did put on a Scorpion aftermarket can. It weighs a lot less and I like the sound a lot better. The OE can sounds great on the road, but when tooling around town with it, it really sounded anemic IMO. Scorpion claims an additional 6 hp and some additional torque, but it's hard to tell when she's already putting out 135 ponies.
I'm not sure there's anyplace else to strip weight without taking away the purpose of having a bike like this. It's already got more horsepower than the average Joe can handle off road... The 800XC is much more capable for serious offroading.
It's my 1st Triumph also. After owning several Kaws, Zukes, Yammys, and Hondas all I can say is World Class.
JON
Big Jon screwed with this post 01-05-2013 at 08:03 PM
Big Jon is offline   Reply With Quote
Old 01-05-2013, 04:55 PM   #3546
gregdee
Motocampist
gregdee's Avatar
Oddometer: 458
Originally Posted by Voluhzia View Post
....I'm at 18000 miles now and did have valves adjusted at 16K under warranty (I bitched too much), .. Maybe I'll change air filter myself as well (requires tank removal)... Did asked to change spark plugs at 10K so will skip 20K plugs...
How on earth do you get the dealer to adjust valves under warranty, especially at 16k miles? Was there something that prompted you to bring the bike in at that mileage? To me the valve adjustment is a known upfront item that will need to be dealt with. Or is it expected that they just be checked and if they need adjusting then that would be a warranty item. I would assume the labor effort involved in checking or adjusting would be similar.
...Maybe I'll change air filter myself as well (requires tank removal)... Did asked to change spark plugs at 10K so will skip 20K plugs...
Is the tank removal and air filter change that much of a pain? Is it like the 800 XC where the air filter is stuffed into a spot it barely fits into? Anyone have any pictures of where the air filter sits?
Old 01-05-2013, 07:23 PM   #3547
Voluhzia
iExplorer
Voluhzia's Avatar
Oddometer: 1,605
I had concerns about engine noise, dealer, at my request contacted Triumph USA and they authorized to remove the head cover and adjust valves and timing. All three exhaust valve tappet shims were replaced.
I don't thing the air filter change is a pain, but tank removal with all the draining, pinching and stuff...
Facebook
Old 01-06-2013, 03:25 AM   #3548
Tropical Bird
From the front line
Tropical Bird's Avatar
Oddometer: 1,004
Hello all
I had about 500 km on a black TEX this weekend, courtesy of my (very good) local dealer.
Great bike.
I will be buying one this week.
The only things that annoy me:
- The screen - the bike had the factory tall screen. I'm 5' 10", average build, and the only position that was useable was full down - full up and in the middle were just awful - too much buffeting.
- The bars are about an inch (25mm) too wide.
The screen is easy fixed with a Madstad.
I was wondering if any of you TEX owners have either chopped your bars down, or replaced them with narrower ones?
Thanks.
Sound, sound the clarion, fill the fife! To all the sensual world proclaim. One crowded hour of glorious life is worth an age without a name.
Tropical Bird is offline   Reply With Quote
Old 01-06-2013, 06:41 AM   #3549
Pacific
Left Coast Adventurer
Pacific's Avatar
Oddometer: 81
There are certainly other bars that will fit. I haven't had the grips off to see where the wires route, but that would be the only concern about shortening or replacing them. Heated grip electrics go through the wires, and by all reports, it's a bear of a job. My 800XC bars were drilled to keep the housings in place. Measure twice, cut once!
Uva uvam vivendo varia fit. -- Agustus McRae, Lonesome Dove
Pacific is offline   Reply With Quote
Old 01-06-2013, 07:07 AM   #3550
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
Originally Posted by snakeroll View Post
The HD4X Hybrid OAT is the reccomended coolant for the Triumph Explorer. What do you guys use that you can get from some place like AutoZone and not the "stealer ship". Any thoughts?
are you looking for a cheaper coolant? If your going to spend that much money on a bike, shouldn't you keep good it running with the best stuff?
fbj913 is offline   Reply With Quote
Old 01-06-2013, 09:45 AM   #3551
Pecha72
Oddometer: 4,059
No big savings to be made on this. Put short: I wouldn't mess around with it. But that's just my 0.02.
Pecha72 is offline   Reply With Quote
Old 01-06-2013, 11:11 AM   #3552
Big Jon
Big Jon's Avatar
Oddometer: 339
I'm pretty cheap, but am still sticking with what Trump suggests...
JON
Old 01-06-2013, 04:49 PM   #3553
Tropical Bird
From the front line
Oddometer: 1,004
I rode it again this morning back to the dealers.
The bars aren't that bad...you can get used to them...
Old 01-06-2013, 05:04 PM   #3554
iddy
Oddometer: 49
Zerex G-05 is a Hoat antifreeze it would be the same formula as Triumph Hoat do not confuse Hoat with Oat though cause that is bad. Will make jelly if mixed.
iddy is offline   Reply With Quote
Old 01-07-2013, 12:48 PM   #3555
snakeroll
snakeroll's Avatar
Oddometer: 6
Thanks guys. I'm not trying to go cheap but just looking for options if the need would arise. The OAT and HOAT concepts are new to me and I was trying to get a "feel" for the experiences you guys may have had. Thankyou for your replies. I would enjoy any other information, as well.
snakeroll is offline   Reply With Quote
Times are GMT -7.   It's 04:22 PM.
