| View Results: Explorer or Explorer/XC | |||
| Explorer |
0 | 0% |
| Explorer/xc |
0 | 0% |
| Voters: 0. You may not vote on this poll | |||
01-05-2013, 07:23 PM
#3556 |
iExplorer
I had concerns about engine noise, dealer, at my request contacted Triumph USA and they authorized to remove the head cover and adjust valves and timing. All three exhaust valve tappet shims were replaced.
I don't thing the air filter change is a pain, but tank removal with all the draining, pinching and stuff... Nova Scotia on Explorer |
01-06-2013, 03:25 AM
#3557 |
From the front line
Oddometer: 970
Hello all
I had about 500 km on a black TEX this weekend, courtesy of my (very good) local dealer. Great bike. I will be buying one this week. The only things that annoy me: - The screen - the bike had the factory tall screen. I'm 5' 10", average build, and the only position that was useable was full down - full up and in the middle were just awful - too much buffeting. - The bars are about an inch (25mm) too wide. The screen is easy fixed with a Madstad. I was wondering if any of you TEX owners have either chopped your bars down, or replaced them with narrower ones? Thanks.
Sound, sound the clarion, fill the fife! To all the sensual world proclaim. One crowded hour of glorious life is worth an age without a name. |
01-06-2013, 06:41 AM
#3558 |
Left Coast Adventurer
Oddometer: 79
There are certainly other bars that will fit. I haven't had the grips off to see where the wires route, but that would be the only concern about shortening or replacing them. Heated grip electrics go through the wires, and by all reports, it's a bear of a job. My 800XC bars were drilled to keep the housings in place. Measure twice, cut once!
Uva uvam vivendo varia fit. -- Agustus McRae, Lonesome Dove |
01-06-2013, 07:07 AM
#3559 |
Oddometer: 1,876
are you looking for a cheaper coolant? If your going to spend that much money on a bike, shouldn't you keep good it running with the best stuff?
Ride 365 LLC Braaaap! |
01-06-2013, 09:45 AM
#3560 |
Oddometer: 1,407
No big savings to be made on this. Put short: I wouldn't mess around with it. But that's just my 0.02.
01-06-2013, 11:11 AM
#3561 |
Oddometer: 141
I'm pretty cheap, but am still sticking with what Trump suggests...
JON |
01-06-2013, 04:49 PM
#3562 |
From the front line
Oddometer: 970
I rode it again this morning back to the dealers.
The bars aren't that bad...you can get used to them...
01-06-2013, 05:04 PM
#3563 |
Oddometer: 48
Zerex G-05 is a Hoat antifreeze it would be the same formula as Triumph Hoat do not confuse Hoat with Oat though cause that is bad. Will make jelly if mixed.
01-07-2013, 12:48 PM
#3564 |
Oddometer: 6
Thanks guys. I'm not trying to go cheap but just looking for options if the need would arise. The OAT and HOAT concepts are new to me and I was trying to get a "feel" for the experiences you guys may have had. Thankyou for your replies. I would enjoy any other information, as well.
01-07-2013, 01:05 PM
#3565 |
Oddometer: 6
Iddy,
Your reply was very interesting to me. So you cannot mix the HOAT and OAT? |
01-07-2013, 01:30 PM
#3566 |
A beer? Yes, please
Oddometer: 1,391
NO, and also keep the little lambs away from the ivy.
"A Washington Terrace man was shot and killed by Weber County a sheriff’s deputy early Saturday while police were trying to talk the man out of taking his own life" -Salt Lake Tribune 5/25/13 |
01-08-2013, 05:33 PM
#3567 |
Motocampist
Oddometer: 188
Aux lights
With regard to aux lights what are they really there for? I try like hell to not ride at night so in my case I would assume that the aux lights were there to get you noticed. What do you all say?
Of those of you that have the Triumph aux lights/fog lights, do you like them and are they worth the price. I like the idea of just having them plug right in. |
01-08-2013, 06:03 PM
#3568 | |
Oddometer: 79
I ordered PIAA's, then returned them and went with the (slightly more expensive) OEM lights because of the simplicity of installation.
01-08-2013, 06:09 PM
#3569 |
iExplorer
I like my OEM too... They don't light as far as the headlights but wide and very visible from distance in day and night time
![]() Nova Scotia on Explorer Voluhzia screwed with this post 01-08-2013 at 06:27 PM |
01-09-2013, 06:08 AM
#3570 |
Motocampist
Oddometer: 188
auxillary power
How are you guys powering your auxiliaries like powerlet sockets or gps units? Have you added a fuse block and then wired from there? Is there a good way to tie into the existing electrical system or do you just run a lead directly from the battery to a fuse block or similar device?
