Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
View Results: Explorer or Explorer/XC
Explorer 0 0%
Explorer/xc 0 0%
Voters: 0. You may not vote on this poll
Old 10-09-2013, 07:28 PM   #4351
Hank.SD
Jet Measurer
Hank.SD's Avatar
Oddometer: 1,282
Originally Posted by Tropical Bird View Post
My bike goes in for the replacement head tomorrow.
Shall report back.
Did you get it back yet, and if so, how does it sound?
My head is getting pretty nasty sounding and I'm just shy of 7K miles. Originally I thought I'd wait until next winter and get it done then, which will be just towards the end of warranty, but now I think its going to happen sooner than later.
Hank.SD is offline   Reply With Quote
Old 10-13-2013, 06:35 PM   #4352
ZZ4Blazer
Oddometer: 281
Mine was right around 7k mi also when I had mine replaced. Didn't realize how loud it was till I rode across the parking lot with my helmet halfway off.
I strung the front of the bike up from the little loft in my garage. I was thinking there was a lot more weight on the front end with it on the centerstand. Ive got a pull up bar I made out of pipe bolted to the loft. If it can hold my weight, the 50 lbs or so to hold the front end with the wheel off would be no problem.
Quite easy removing the wheels. Metzler NEXT mounted up. I thought my EXP's were great tires. These are supposed to be even better. Hopefully Ill get another 10K miles otta these tires too.
"homesick for a place Ive never been"
'13 Triumph Tiger Explorer 1200
08 Yamaha WR450F - woods/adventure monster in the making
ZZ4Blazer is offline   Reply With Quote
Old 10-14-2013, 04:12 AM   #4353
GarrettRB
Bike Nerd
GarrettRB's Avatar
Oddometer: 218
I didn't have my head replaced, I had the regular 10k maintenance and that made my engine much quieter.
GarrettRB is offline   Reply With Quote
Old 10-14-2013, 09:53 AM   #4354
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 558
GarrettRB,
Did they tell you exactly how much your valves were out?(I'm assuming that is what was causing the noise)
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is online now   Reply With Quote
Old 10-14-2013, 09:58 AM   #4355
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 558
Question Clutch cable Help
General question,
Anyone here reroute the clutch cable to get an extra 2 inches to mount a Rox Riser or other handlebar extender? If so did you just disconnect the cable at the reservoir and which way did you route it?
Old 10-14-2013, 07:23 PM   #4356
Big Jon
Big Jon's Avatar
Oddometer: 336
Thumb
Originally Posted by pfy50 View Post
General question,
I've got 2" ROX Risers on mine & didn't have to reroute the cable at all. It's not a bit snug.
JON
Big Jon is online now   Reply With Quote
Old 10-14-2013, 09:09 PM   #4357
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 558
Hello Jon,
Yeah I got the plain 2inch risers and was attempting to install them last week and all the bundled cables going up to the left switch were loose enough but the clutch the way it is set up on mine has only about a 1-1 1/2" of straight pull and has no room for any turning of the handlebars.
Just to verify my clutch cable goes; along with the electrical wiring; down thru the wire retaining bar, around the front of the steering head, and under the rightside plastic fascia for the fuel tank correct?
Old 10-14-2013, 10:40 PM   #4358
EOD-KTM
EOD-KTM's Avatar
Oddometer: 18
I have the Rox 2" riser and 20 mm spacers on my TEX and have no problem with cable length.
I am not sure why your cables are so tight.
Sent from my iPad using Tapatalk HD
EOD-KTM is offline   Reply With Quote
Old 10-15-2013, 04:12 AM   #4359
GarrettRB
Bike Nerd
GarrettRB's Avatar
Oddometer: 218
GarrettRB,
He didn't say how much but he did say they needed to be adjusted. It was the 10k maintenance so they also did the special cam adjustment too.
Old 10-15-2013, 04:43 AM   #4360
Big Jon
Big Jon's Avatar
Oddometer: 336
Hello Jon,
That's correct. I just went out & looked and even though I've got plenty of slack, I reached up behind the driving light & grabbed the cable where it goes into the rectangle hole in the plastic fascia and tugged on it very lightly. I pulled up a good inch of slack and it still is free to move where it goes through that hole. Maybe yours is hung up or twisted around some of the wires @ that part of the harness...
JON
Old 10-15-2013, 10:07 PM   #4361
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 558
Yeh, Jon I think it probably is. The cable has no give at that point you mentioned. I probably got the cable router on his OFF day
I suppose I'm going to have to pull all the rightside plastic off to get a view of where the problem is. I'll try it when I get back from FLorida next week, and report back.
Old 10-16-2013, 05:25 AM   #4362
eemsreno
Oddometer: 959
Tiger On The White Rim Trail
Hi guys
I am not a Tiger rider, but I took these pictures of a friend of mine and I thought you guys might enjoy seeing them.
Six of us rode out to Moab last Thursday and rode the W.R.T.
Mike had no off roading experience before this trip.
He was a long time H.D. guy and before a trip to Ouray last June I talked him into going to a Triumph dealer and we test road the 1200s.
I just knew if I could get him to test ride one and realize there was life after H. D.s he would like it.
Well the night before we were to leave for Ouray, Co. he calls me up and said come see what I have here at home.
He rode out to Moab with us but had no intention of getting off road.
He must learn fast. But he has the right bike to learn on.
I hope you don't mind me budding in on your thread.
Thanks Steve
I have a R.R. over on the XTZ site.
http://www.yamahasupertenere.com/ind...0383#msg160383
eemsreno is online now   Reply With Quote
Old 10-16-2013, 05:37 AM   #4363
Big Jon
Big Jon's Avatar
Oddometer: 336
Thumb
Great pics. Love the first one! Thanks for sharing.
JON
Old 10-16-2013, 05:53 AM   #4364
Big Jon
Big Jon's Avatar
Oddometer: 336
Rox risers
Hey phy50, here's another thing you may want to check out...
http://www.tiger-explorer.com/index.....html#msg83022
JON
Old 10-16-2013, 09:34 AM   #4365
Gerbo
Oddometer: 16
First time poster.
Hey all...new to ADV. I'm picking a '13 explorer tonight. I know...threads are no good without pics. I just wanted to say I'm in for the fun. I've been through the super bike and Harley stage. Time to get something more utilitarian. I'm psyched and it looks like there's an awesome crowd on here.
Anything you guys suggest that I watch out for or need to do in the break-in period? I'm looking at accessorizing, so that'll come pretty soon as well.
Cheers,
Gerbo
Gerbo is offline   Reply With Quote
Times are GMT -7.   It's 06:14 AM.
