12-15-2012, 07:32 AM
#256 |
Oddometer: 108
I already did that for some pistons, but still havent found a bike with the same piston as the nx piston.
12-16-2012, 04:51 PM
#257 |
My First Gold Chain
Oddometer: 300
The overhaul is almost complete. The new grips, mirrors, GPS mount, and poweport need mounted.
There is also a rear rack on order from Europe. It will be painted blue to match the handle bars. The bike was put outside to heat cycle the newly painted exhaust. Still required is the front sproket cover that was missing when purchased. ![]() The SV650 rear shock is still in the bike and raised the rear slightly. The bike leans just a bit more when on the side stand but not much. Preload spacers and 20 wt fork oil were added to the forks to boost up the 25 year old springs.
12-20-2012, 01:17 AM
#258 |
Oddometer: 108
Nice bike!
There are quite some design (and technical) differences with my NX125 (by 1989 Italy). Which version is this? JD12/JD09/...? |
12-20-2012, 04:24 AM
#259 |
My First Gold Chain
Oddometer: 300
I believe it is JD09? 1988 USA model for sure. Your Italian bodywork is more stylish!
We were the 4th, and now the 6th owners of this bike. 8 years ago we purchased it, broken in three pieces and in multiple boxes, out of a horse trailer resting on a bed of straw and manure, Our youngest daughter helped with the restoration and learned to ride it. ![]() Now it will be my work commuter bike.
12-20-2012, 07:08 AM
#260 |
Oddometer: 108
Great looking bike! I actualy like the USA model styling. However I prefer the front disk brake of the JD12.
I'm missing the skidplate (i dont think it was standard on the Italian version). Hard to find on the internet... I think I'll have to make one my self. |
12-20-2012, 08:37 AM
#261 |
My First Gold Chain
Oddometer: 300
A front disk brake would be nice - a tachometer would be WONDERFUL. Alas it works fine the way it is.
Skid Plate: When I get into a corner and need an obsolete / hard to find item, I go to ebay and ask everyone that has dimantled parts for sale from the same bike, "I need (what ever part...) would you have one for sale?". Everyone, without fail, will answere the question. One out of 15 will say yes and asks a low price. Everyone Wins! |
12-26-2012, 05:36 AM
#262 | |
Oddometer: 74
This is what you are looking for: NX 150 - Made in Brazil.. it shares almost everthing with your nx 125 except for the cylinder and the rear fender stuff.. http://www.youtube.com/watch?v=nL5983DBHTY |
12-26-2012, 06:30 AM
#263 |
Is still learning
Oddometer: 254
Well, the NX 150 is a great bike, really good for what it is and has very low fuel consumption, mine did 35Km per litre at 90Km/h of the speedo.. (And my Tornado does around 25Km/l at 100Km/h of the speedo).
The real problems it has is that it is an old bike right now, you can find spares here in Argentina, but not all of them... Personally, I would buy a XR 200L or XL 200, that have the same engine of the NX 200, more suspension and the most important thing, you can get newer bikes.. Really, the bike was great, it made me really happy, my problem was buying an old bike and thinking that I could just start it and ride.. It needed a lot of work, but at last it was great...
2010 Honda XR 250 Tornado |
12-26-2012, 03:42 PM
#264 | |
My First Gold Chain
Oddometer: 300
01-05-2013, 01:27 PM
#265 |
My First Gold Chain
Oddometer: 300
The bike is ready to ride. Starts up and idles great!
The rack arrived from Germany and was painted dark blue to match the handlebars, seat, and fork gators. Still need the front sprocket cover after searching and searching. It will be a long term quest. ![]() The kick stand sank deep into the packed snow and required a wooden snow shoe to keep the bike upright. The only mods were the shortened Suzuki SV650 rear shock, an inch of preload fork spring spacers, and that SWEET looking ADV sticker. |
01-15-2013, 11:22 AM
#266 |
Oddometer: 1
Hi.
Hi, very interesting reading this thread and as a newcomer I would like to say hello, and
I have just bought me one o they NX125 transcitys here in Spain and although it is ok, I am already thinking it would love me to put a beefier engine in! I have spent all day researching this little thumper and it seems to be a pain fr info/parts. I have found most suppliers but sod all on how to improve the little darling. Is it the same basically as the XLR 125? can a NX150 barrel and head be simply bolted on? lots of not so sure info about when what I need is: "This is a fact" info. any genuine and helpful comments on how to add a little to this essentially crackin machine, gratefully appreciated. |
01-16-2013, 12:27 PM
#267 |
Oddometer: 108
150cc ? I don't think you will notice a lot of difference.
I would go 223 cc: Model:165FMM Type: Single-cylinder,four-stroke air-cooled hand-clutched 250cc Displacement: 223ml Compression ratio: 9.1:1 Primary reduction: 3.333 Bore*Stroke: 65.5mm*66.2mm Max.Power & Rotating Speed:12kw/7500r/min Max.Net Power & Rotating Speed:11.5kw/7500r/min Rated Power & Rotating Speed:10.5kw/7500r/min Max.Torpue & Rotating Speed:16.5N.m/6000r/min Min.Fuel Consumption:≤354g/kw.h Ldling Speed:1500r/min Ignition:CDI Starter:electric starter/Kick starter Lubrication: Pressure/splash Transmission: 5 speed These are the specs of lifan engine: http://www.lifan.cn/English/Industry...6-df8eca5fb9eb Quality is good, en they should fit right in! |
02-08-2013, 07:24 AM
#268 |
Oddometer: 108
I just bought myself from ebay a skid plate.
But what i'm now missing is the mounting bolts/rubbers etc. Kan aynone please take some pictures of how it's mounted? Thanks! |
02-08-2013, 08:22 AM
#269 |
Nobody Home
@Honda Scoot: Your NX is a JD09. That's the only model the US got.
@Jan: You don't want one of the original equipment NX skid plates. They're flimsy, thin sheet metal and are only good for stopping small stones that are thrown off the front tire. You will need to make one yourself. Have a closer look at Honda Scoot's picture. ![]() The front bolt goes thru the skid plate and into the frame. There are two bolts, at the rear of the plate that also bolt into the frame. I used a piece of aluminum diamond plate to fabricate a skid plate for my old 1986 TLR200 (Reflex) trials bike. The three bolt arrangement was very similar to the the NX's. I bent the plate around a 3 inch or 4 inch piece of pipe and then bent a small tab for the front bolt. I then had a friend weld small pieces to strengthen the bend. From the right side, the bent piece of aluminum looked like a "J" rotated clock-wise 90º (I hope this makes sense). Don't worry about making something that "hugs" the engine case. Just make something that's strong enough to absorb hits from big rocks and tree trunks. If necessary, a skid plate is disposable, your engine case is not. Here's a nice image of the TLR200's skid plate. You can see it's very similar: ![]() And, a parts fiche image of the way the TLR200 skid plate bolts to the TLR frame (sorry it's so big).
There are some simple thruths......and dogs know what they are - Joseph Duemer Andy holds the lead. And he will, all the way to the Highway. Today is his day. |
02-18-2013, 03:43 AM
#270 |
Oddometer: 108
