10-14-2011, 06:18 AM
#31 | |
Oddometer: 108
10-17-2011, 12:48 AM
#32 |
Oddometer: 108
It's done!
The rear gear is mounted, there is no play anymore. The old gear was just to worn... |
10-17-2011, 11:13 AM
#33 |
Nobody Home
Great, glad you figured that out.
There are some simple thruths......and dogs know what they are - Joseph Duemer Andy holds the lead. And he will, all the way to the Highway. Today is his day. |
10-18-2011, 12:36 AM
#34 |
Oddometer: 108
This morning i removed the seat. Time for some new fabric on that!
I've put some rust bolt & nuts in a liquid which removes the rust. The result is OK. The chain is now also mounted, now just have to make the tension right. |
10-18-2011, 04:09 AM
#35 |
Is still learning
Oddometer: 268
Come on!
Just buy some new bolts! They aren't sooo expensive! Well, I can tell you that I separated my front tyre from the wheel in order to put it in it right position/way (The guy who changed my tyres put the front tire with the drawings pointing to the opposite side they should point) doing this, I did a little cut in the tube, but as it is the first I do this kind of job, it isn't sooo bad, je! I'm repairing it tonight, je. I've talked to a guy who works with hidraulic machines and he will get my bent fork straight for monday, so I'm doing other things meanwhile, so as to get a fully operating bike next week.. And I'll see if i can stay a little longer in the city this week so as to buy the transmision I need... Well, that's all for now. Greetings! I have to go to school! jaja!
2010 Honda XR 250 Tornado |
10-18-2011, 04:12 AM
#36 |
Oddometer: 108
There are so manny bolts on the NX125... I'm not going to replace them all
Now they are full of grease and a little rusty. I use this: ![]() Putting the bolts & nuts in it, removes the rust after a while. |
10-18-2011, 07:22 AM
#37 | ||
Nobody Home
10-18-2011, 08:49 AM
#38 |
Is still learning
Oddometer: 268
I don't think there are sooo much bolts on the NX...
Mine doesn't have so many and actually, it has some original bolts yet, jej! I'm doing little things these days, so stay tuned, jej!
10-18-2011, 09:01 AM
#39 |
Oddometer: 108
In time i might replace the bolts, but if i can get them as new with this method, why bother... It's not the thread that is rusty, so the bolts are still as strong as new.
10-18-2011, 09:04 AM
#40 |
Oddometer: 108
What should the tension be for the chain? I've read i need to be able to fit 2/3 fingers between the lifted chain and the rear axle, correct? |
10-18-2011, 03:27 PM
#41 |
Is still learning
Oddometer: 268
That thing about the chain tension is more like a feeling than something that can be measured in my case but..
This is what my service manual say.. ![]() Jan, remember that if you grease your chain with what I use (SAE 90 oil) or with any kind of grease/oil that could finish in the rear wheel rim, you should let the grease/oil to dry or squeeze itself for some time (at least some hours) so as to have a lubricated chain and a clean wheel, je! (Sorry if I missed some words) As regards chain lubrication... Could you tell me what do you use to clean the chain before greasing/oiling it? I use a piece of cloth with diesel fuel ("gasoil" here in Argentina) Bronco, I haven't answered you.. je! I hope the same, this will surely be allright, we'll se, but I hope it will be a good fix...
2010 Honda XR 250 Tornado Leo.G screwed with this post 10-18-2011 at 08:24 PM |
10-19-2011, 12:22 AM
#42 |
Oddometer: 108
I've cleaned the chain of my mountainbike a lot (and repllaced it a lot).
I used this kind of device: ![]() You put it on the chain (while still mounted), fill it up with some degreasing liquid for example white spirit, and you turn the chain slowly so the brushes in the device + white spirit clean the chain. I don't know whether this exists for motor cycle sized chains... |
10-19-2011, 09:32 AM
#43 | |
Is still learning
Oddometer: 268
A piece of metal that could cover the chain would be better (like the ones that the C90's and also most of the Czech and Russian bikes had) but in spite of that, just cleaning it every 500Km can keep your chain good enough to last a lot of Km's more, jeje! Personally I clean it the way I do just because it is the most practical way of doing it for me, and it doesn't matter (to me) getting my hands dirty doing manteinance to my bike je! Today, after doing some maths excercises for the university I cleaned the device that goes from the front wheel to the speedo, it had about 20 years of muddy things inside, but the gears were beautiful after a little cleaning with gas, je!
2010 Honda XR 250 Tornado Leo.G screwed with this post 10-19-2011 at 10:02 AM |
10-19-2011, 12:13 PM
#44 |
Nobody Home
jan: you can use this link, to the chain adjusting procedure, in the Maintenance PDF I posted to my blog: link
Also, here's a link to my chain cleaning procedure: link I've used turpentine in the past. It works well but is not enviro-friendly. I switched to Simple Green because it's biodegradable. If you have a way to safely dispose of kerosene or turpentine, then they're OK to use. I also really like Liquid Wrench's chain lube. I also read (here) that DuPont makes a chain wax that works well, too. I prefer something like this over oils because of the "mess" factor.
10-19-2011, 12:38 PM
#45 |
Nobody Home
Leo, by any chance, do you have a wiring diagram for your NX? I just noticed that my shop manual lists a "Chapter 18 Wiring Diagram" in the table of contents but there isn't anything between Chapters 17 & 19.
Thanks.
