03-19-2012, 08:59 AM
#76 |
Oddometer: 409
You know they say: Big feet, more fuel.
2011 Kawasaki KLR650 2009 Triumph Rocket III Touring Iron Butt LDR guy |
03-19-2012, 09:36 AM
#77 | |
Once you go Triple...
Oddometer: 20,409
In normal riding conditions, I'm sure they're just fine. The problem is when you crash - they have leg- breaker written all over them. I shudder just thinking of the consequences.
'12 Tiger 800XC '07 TE510 '02 Sprint ST '99 XR650L '99 Speed Triple |
03-19-2012, 10:37 AM
#78 |
Freak!
Oddometer: 454
Maybe a stupid question...but... is it bad to try to run your bike on 'white gas', the type used for cooking. I was told its the same as regular gasoline, just is more refined. I have a MSR bottle with cooking fuel (white gas) and would like to know if I can use it should my bike run out of gas.
My stove is multi-fuel, so worst case is I would just fill my MSR with gasoline (I would just prefer not to cook with gasoline). |
03-19-2012, 10:50 AM
#79 | |
Oddometer: 1,841
Ride 365 LLC Braaaap! |
03-19-2012, 10:56 AM
#80 |
Oddometer: 1,841
I did about 30 seconds of research and here is what I learned. White fuel can be used in motors but the octane rating is much lower. White Fuel is around 55 octane. Because most all motorcycles are high compression this could be bad. Also you will not have the additives that Gasoline has in it. For short distances I guess you could...
03-19-2012, 10:59 AM
#81 |
Oddometer: 1,841
I dont think it burns hotter, scratch that.
03-19-2012, 11:44 AM
#82 | |
Freak!
Oddometer: 454
03-19-2012, 12:18 PM
#83 | |
Oddometer: 20,409
03-20-2012, 06:28 AM
#84 |
Oddometer: 342
Kerosene in your bike
If your bike had a diesel engine it would not be an issue to run white gas / Kerosene in it. It is more refined than diesel fuel and has less parafins in it. Having less parafins helps its long term stability and has been used in emergency power generators for years. The less parafins and impurities keeps the biomass from growing and gooping up injectors and filter banks.
Diesel, kerosene/whit gas has more BTUs because it is a heavier fraction distillate than gasoline. That means it has more oil in it and less solvent. The heavier fuels burn and are therefore typically known as "combustibles." The lighter fuels such as gasoline are called "flammables" because they explode. It all has to do with Vapor pressure and density. Diesel engines are compression ignition and gas are spark ignition.
President and Founder of Superhero Proving Grounds "Where dreams are made and egos are checked" |
03-20-2012, 08:00 AM
#85 |
Freak!
Oddometer: 454
From what I have been told (which does not make it fact), white gas is further refined to remove impurities. That would mean it burns cleaner. Gasoline, has additives for engines and more impurities and therefore burns 'dirtier' and more carcinogenic.
I'm nervous because I dont want to look back and think how stupid i was cooking food over gasoline flame - similar to people who use to play in asbestos back in the day. My fears may be completely unfounded, but I'm not informed enough to know, and cant seem to get a straight answer on safety. |
03-20-2012, 10:56 AM
#86 | |
Oddometer: 20,409
Interesting perspective. Not sure I share your concerns but that's not to say the risk does not exist. Like you, I am no expert in this field.
03-20-2012, 11:23 AM
#87 |
Freak!
Oddometer: 454
I did grow up eating steaks cooked 1 inch away from smoking charcoal briquettes, so I'm sure ive had my fair share of exposure ;)
03-20-2012, 11:35 AM
#88 | |
Oddometer: 1,841
03-20-2012, 01:20 PM
#89 |
has become "FERAL"
Oddometer: 1,638
< spell cheqeur is bustimicated > |
03-20-2012, 02:37 PM
#90 |
Oddometer: 618
Weestroms don't need extra gas. They run on fumes
09 DL 650,08 WR250R 09 KLX250S(gone), 03 R6 (gone) 04 WR 450(gone), 01 EX 250(gone), 06 DL 650(gone) , 89 KLR 650(gone) |
