Old 09-02-2009, 04:53 AM   #1
Gimme 2 OP
wheels , with nobs
Gimme 2's Avatar
Oddometer: 2,169
Laugh 990 Stock Pipe Metamorphasis .
The object is to remove all the crap (cat baffel and second wall) shorten the pipe , fit a stainless perforated inner tube wrapped in appropriate wool and make it servicable useing rivets.
I hope to lose half the weight , plus help the big twin breath easier in mid and top revs, the sound will be good the cost should be meagre and i'll have some fun doing the work and bringing the results to fellow 990 owners.
The bike, you've maybe seen one.
The weight and height of 1 original pipe.
Tools for first stage- dissection.
The first cut.
1
2 Meow!
3 Cat cut from flange and weighed.
4 Cut end cap .
5 and take a looksie.
6 impressive build.
7 slip the outer from the inner.
8
9 baffel me cat diet perhaps?
Gimme 2 is offline   Reply With Quote
Old 09-02-2009, 07:04 AM   #2
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,171
Good efforts going in there.
I am myself in the process of converting to a 2-into-1 setup using an HT-Racing Y pipe with FMF can. I initially had this idea of doing a de-catting & 2-into-1 conversion using the stock cans.
The stock exhaust & H-pipe setup weighs 10Kgs and the HT-R 2-into-1 setup weighs 3Kgs !!! So it was much better than my earlier idea and bcos i am keeping the rear luggage carrier frame on the bike, i don't need the additional crash protection of the stock cans (very strongly built - but i don't know how much it will be compromised by removing the innards).
cheers
Building a KTM 690Exc - the ultimate dirt tourer
2007 KTM Adv990S - Sold, 2010 KTM530Exc-Rally, 2012 KTM Adv990
Vicks is offline   Reply With Quote
Old 09-02-2009, 04:05 PM   #3
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,071
I like the way you have the timer running in the pics, so we know you aren't cheating.
Good so far, keep going!
viola-tor is offline   Reply With Quote
Old 09-02-2009, 04:29 PM   #4
tac650
Nomad
tac650's Avatar
Oddometer: 521
I like where this is heading, keep it up....
The greatest rewards come with the greatest risks.
2011 Husqvarna SMS630, 1998 Triumph Sprint, 1983 Suzuki GS1100E and retired.
tac650 is offline   Reply With Quote
Old 09-02-2009, 10:58 PM   #5
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,840
There's a continuity error in pic- 3 cat cut and weighed. The clock shows zero! That's it, weld it up and start over!
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 09-03-2009, 01:14 AM   #6
Gimme 2 OP
wheels , with nobs
Gimme 2's Avatar
Oddometer: 2,169
yes , i am aware of this . but to be honest the whole deal took about 100 minutes of leisurely time. That's both pipes .
Old 09-03-2009, 01:18 AM   #7
Gimme 2 OP
wheels , with nobs
Gimme 2's Avatar
Oddometer: 2,169
Thumb
I had a chance to drop the pipes off at the tig welder today. And let me say i have a good feeling about his skills, clean workshop , just him there on his own , and he loves racing.
Stay tuned!
Old 09-03-2009, 04:44 AM   #8
charlie264
charlie264's Avatar
Oddometer: 8,370
Stay tuned!
OK Gimme so what have you left in the can's? Baffels or just the centre pipe or both?
Old 09-03-2009, 04:54 AM   #9
Gimme 2 OP
wheels , with nobs
Gimme 2's Avatar
Oddometer: 2,169
There is only a hollow tube at the moment. Like the one in pic 8, lying down.
the stuff in pic 9 is going in my recycle bin.
I am going to $ buy an exhaust grade stainless steel perforated 1and half inch tube, then wrap it in glass wool.
It's friday tomoz, so maybe have something then ,but only if i'm lucky.
Old 09-03-2009, 05:24 AM   #10
riceless
Let's Ride!
riceless's Avatar
Oddometer: 3,267
Great Idea! Do you plan on incorporating a spark arrestor?
riceless is offline   Reply With Quote
Old 09-03-2009, 05:53 AM   #11
charlie264
charlie264's Avatar
Oddometer: 8,370
Sorry mate. Let me get this right, you're scrapping the inner sleave and baffels seen in pic 5 and keeping the centre tube resting on your left hand in pic 5 and then your going to put a another perforated tube inside the centre pipe with wodding on it?
Old 09-03-2009, 06:14 AM   #12
Gimme 2 OP
wheels , with nobs
Gimme 2's Avatar
Oddometer: 2,169
I'll spell it out ...........
I've kept , the end cap and thats the skin only of the end cap. No tubes perforated steel or glass wool.
Right... ive also kept the flange end , SKIN ONLY.
And the tube lying down in pic # 8 which is the external skin only that is visible to the eye.
NOW, the skin of the original can (minus the end cap and the bolt on flange) has been shortened, by about 50 mm.
This piece (the 50 mm piece )is going to be used as a insert, which is being welded to both the flange and end cap.
Ive had to cut a piece out of the radius of this 50 mm piece in order for it to fit inside the original can skin.
On top of this above foundation i am adding.............a 1 and half inch in dia perforated ss tube.
This tube will connect the bolt on flange to the end cap creating a straight thru pipe...yes!!
The perf pipe will be wrapped in exhaust glass wool wadding or apropriate material.
There...... clear as mud!
Be patient pics will explain more.
Gimme 2 screwed with this post 09-03-2009 at 06:32 AM
Old 09-03-2009, 06:18 AM   #13
Gimme 2 OP
wheels , with nobs
Gimme 2's Avatar
Oddometer: 2,169
I think i should. Bushfires and all.
a DB killer for certain.
Termimesh should work for the Spark police.
Old 09-03-2009, 06:33 AM   #14
charlie264
charlie264's Avatar
Oddometer: 8,370
I'll spell it out then...........
There clear as mud!
Nope. wish you had taken a photo.
So the can you've sent to the weld shop has zilch in it. Its just an empty can? Its going to run like shit, zero back preasure.
Old 09-03-2009, 06:40 AM   #15
Gimme 2 OP
wheels , with nobs
Gimme 2's Avatar
Oddometer: 2,169
Oh Charlie Charlie Charlie bloody go for a ride or something and get some fresh air outside your head!
Times are GMT -7.   It's 05:41 AM.
