Old 10-09-2011, 02:40 PM   #1
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,296
Picked up a 640 Project....
I picked this up over the weekend....
I had in mind to use it for a parts bike but after running the engine I think it will be a worthwhile fixer up project... Little by little over the winter I'll see what I can do with this to make it into a reliable ride...
It has a monster thick disk/caliper up front which probably came from a supermotard...
The bike has serious electrical/ wiring issues which will take some time to sort out...
The engine runs well but looks to have a few oil leaks to deal with...
I dont reconize these twin stacks from anything current,they also are probably supermotard...I'll clean them up a bit and see if anyone want's to swap a single pipe setup for them on the flea market...
The pipes actually tuck in quite tight so it wont be a big deal for adding luggage frames if I end up keeping them...
f
gunnerbuck is offline   Reply With Quote
Old 10-09-2011, 03:15 PM   #2
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,752
Looks like a worthwhile project. Obviously this bike was thoroughly enjoyed by the PO. (and I though mine was in rough shape...)
I dont recognize the exhaust either. If its lighter than stock, keep it. If not, ditch it. Stock SS muffler is friggin heavy.
Have fun.
990SMT, 640A, TXC450, TE510, ATC350X, ATC200ES, 550MXC, BW200. Need more space in garage.
dirtydeeds is offline   Reply With Quote
Old 10-09-2011, 08:03 PM   #3
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,296
Putting a magnet on the pipe I find that the headers and midpipe sections are a form of stainless showing a very light magnetic pull... The silencer bodies are aluminum with stainless end caps so they are likely lighter in combined weight than the stock muffler...
Old 10-09-2011, 10:18 PM   #4
Tseta
Lost
Tseta's Avatar
Oddometer: 674
-T
Tseta is online now   Reply With Quote
Old 10-10-2011, 05:30 AM   #5
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
That is without a doubt the ugliest exhaust system ever for a 640A. With that being said, it looks to be a great candidate for a rehab...
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 10-10-2011, 07:41 AM   #6
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,296
Yep, for sure an eyesore with the way they are now, maybe with side panels in place it wont look so bad...
Old 10-10-2011, 07:54 AM   #7
bumblebee1
All bikes are dirt bikes
bumblebee1's Avatar
Oddometer: 1,431
I wonder how little money invested you can get away with on this bike.
It looks almost ready to go now.
And what are you planning to do with your one and only life?
bumblebee1 is offline   Reply With Quote
Old 10-10-2011, 08:42 AM   #8
overlandr
Dystopist
Oddometer: 5,908
I think its the Remus Twinfire. Maybe.
http://www.advrider.com/forums/showthread.php?t=66711
overlandr is offline   Reply With Quote
Old 10-10-2011, 10:18 PM   #9
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,296
[QUOTE=bumblebee1;17041338]I wonder how little money invested you can get away with on this
Over the last 7+ years of 640 ownership I've managed to scrounge up a bit of inventory of spare parts, so I hope to have most needs covered... After test riding the mechanics of the engine appear sound so the starting point will be replacing the ignition switch as it was bypassed when the P.O. lost the key...The tach is not registering as is the speedo and brake lamps... And it seems there has been some frame ground outs in the wiring clusters... The oil leaks are simple, gaskets or goop for a fix...Sort out the exhaust system.. Carb cleanout and rejet as needed... A check and grease repack of all the suspension link and steering bearings... I have ordered a longer front brake line as the existing one is way too short and does not move properly through the guides as the forks compress... Then there will be the cleanup of corrosion and touch up paint on the frame as required...Replacement of some plastics and a tank/fairing paint touch up... After all this is done I'll try to scrounge up a set of luggage racks and make her travel ready...
Old 10-10-2011, 10:23 PM   #10
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,296
Remus Twinfire sounds expensive, maybe I shouldn't give up on the twin stacks so soon...
Old 10-11-2011, 02:21 AM   #11
Aivasovsky
Aivasovsky's Avatar
Oddometer: 155
Hi Gunnerbuck!
I'm sure this will be a great project.
Can't wait to follow it.
Please take as many pics as possible.
I will take my gray KTM 640 LC4e to my house for a thorough service for this winter as well.
See you around soon
2003 KTM 640 LC4e 18000km (High Flow top)
1993 Yamaha XT350 40000km
Rebuilding XT350 project pics:
http://s263.photobucket.com/albums/i...350/?start=all
Aivasovsky is offline   Reply With Quote
Old 10-11-2011, 02:55 AM   #12
Skippii
Hookers, my lad.
Skippii's Avatar
Oddometer: 6,508
f
Is a part missing, or do those endcaps really not even remotely match each other? Looks like some kind of homemade project, not dissimilar to a better version of something I'd make.
"Umm be careful what you say, this is Skippii....
You may get it delivered in the form of a shake or some interperative dance routine that involves nakedness, pizza and a stuffed raccoon..." -DCrider
Skippii is offline   Reply With Quote
Old 10-11-2011, 07:19 AM   #13
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,296
Nope, the one end cap has a washer welded in place in an attempt to restrict the opening and cut back some DBs...
Up close the pipes do look like factory units and it looks as if they'll come apart for repacking... I'll know more when I get some time to take them apart...
Old 10-11-2011, 07:38 AM   #14
Tseta
Lost
Tseta's Avatar
Oddometer: 674
What's your long(er) term plan with this bike, Gunner, if you don't mind me asking?
The overlap with your current LC4 is basically 1:1, so will you be selling one or the other later on? Or just riding these two on alternate days? Won't the yearly insurance and registration cost be prohibitive for that?
Cheers,
Tseta
Old 10-11-2011, 09:35 AM   #15
bmwktmbill
Traveler
Oddometer: 5,218
Gunner,
Really nice.
I'd stick with the minimalist look.
The pipes are cool cause you can get the luggage real close to the centerline of the machine, especially hard luggage.
I cut the number plates off my side plates long ago.
Makes access so much easier.
This may become your 'go to' machine.
Nice Touratech luggage rack on the rear rack
Ah but...no kickstand!!!
bill
Cut down side plates, KTM adventure
Touratech rack
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill screwed with this post 10-11-2011 at 09:59 AM
bmwktmbill is offline   Reply With Quote
Times are GMT -7.   It's 09:01 PM.
