Old 12-28-2011, 03:14 AM   #46
Droptarotter
Oddometer: 1,222
Glad to see the racks fit ok.
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 12-28-2011, 05:49 AM   #47
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,413
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 12-28-2011, 06:15 AM   #48
dlh62c
Oddometer: 1,603
If your thinking of repainting the tank and plastics. I'd go for the Zebra stripe Daktari paint scheme.
daryl
Old 12-29-2011, 12:50 PM   #49
funrider
funrider's Avatar
Oddometer: 53
640 project
Just got back on sight this morn. great progress Dave, looking pretty sweet, Paul did a nice job on that tank. Will stop by for a closer look.
funrider is offline   Reply With Quote
Old 01-05-2012, 09:37 AM   #50
overlandr
Dystopist
Oddometer: 5,849
Hey GB, just for the record, found this linky to a set of Sebrings in .de that look similiar to yours - but only similiar!
overlandr is offline   Reply With Quote
Old 01-05-2012, 07:16 PM   #51
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,114
Those mufflers look identical to what I had, the head pipes look like they are less refined, possibly an earlier version... So that mystery is solved, thanks...
640 A x 2
BC RIDING 2014
gunnerbuck screwed with this post 01-05-2012 at 07:46 PM
gunnerbuck is online now   Reply With Quote
Old 01-07-2012, 08:22 PM   #52
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,114
A little more progress...
The photos may go down for a few days as I'm close to my bandwidth limit..
I decided to replace the rear disk with a fresh one...
I noticed the passenger foot peg bracket was bent... Must of took a pretty big hit as those brackets are strong...
Lucky that I have a spare kicking around...
The battery that came with the bike was too big so I ordered a cheap Gel to replace it...
I added some padded tape to the hold down bracket..
And on she goes, no battery bounce here...
The low fuel sender had a broken wire so I ground the base plate down enough to expose some end for soldering and then coated it with aquaseal for extra support..
I popped the top off the carb and noticed some needle wear so I figured the guides were also worn...
Popped the main jet out to release the guide and noticed it was way overkill, 172.5, way rich... I replaced it with a 155, the bike comes stock with a 152.5...
The slide and guide are well worn {right} past the marks so I replaced those...Also the needle and needle jet{emulsion tube}are replaced...
And a new crossover line and some blue foam to support and stop from chafing...
Next is to fire it up and see how it sounds, stay tuned....
f
640 A x 2
BC RIDING 2014
gunnerbuck screwed with this post 01-07-2012 at 09:29 PM
Old 01-08-2012, 12:20 AM   #53
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,114
Test Run
Here is a bit of Video:
640 A x 2
BC RIDING 2014
Old 01-08-2012, 12:26 AM   #54
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,055
Sounds great. Nice work on the jetting.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 01-08-2012, 01:48 AM   #55
makazica
makazica's Avatar
Oddometer: 746
Great work, glad you have it runnin'!!
M.
makazica is offline   Reply With Quote
Old 02-05-2012, 03:15 PM   #56
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,114
Picture Time
OK, I'm pretty much finished this project other than a bit of saddle time tuning... There will be a few things I'll be replacing in the next bit but the bike wont really look any different than it does now.... So before I get it dirty here are the pictures:
I'm happy with the results...
Black does give it a different look....
My 152,000 KM bike vs My 28,000 KM unit...
I almost like the black look better...
In a ride comparison my project 640s engine is noticeably smoother than my prime bike, this could be partly due to a tighter piston fit in the bore.... Another thing I notice is how the project bikes front end has the pogo stick effect, especially when braking... I'll solve this with some heavier springs up front, my prime bike has 950 springs in it....
640 A x 2
BC RIDING 2014
Old 02-05-2012, 07:49 PM   #57
shevthump914
Oddometer: 11
Wowsers, bike looks AWESOME!!!!!!!!!!!. I will look into some nice white KTM decals for it.....
Paul.S
shevthump914 is offline   Reply With Quote
Old 02-05-2012, 07:58 PM   #58
slackmeyer
slackmeyer's Avatar
Oddometer: 3,055
I guess the project bike has 43mm forks, and thus different springs, right? I've got the stock springs from my 950 hanging around the garage, if they would fit, they're yours.
Zak
ktm
old bmw
others
Old 02-05-2012, 08:04 PM   #59
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
I'd say that since both are '03s, both are 48mm. That being said, the 950 springs should work (and if GB fails to need them, I could put them to use...)
Chris
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 02-05-2012, 08:13 PM   #60
slackmeyer
slackmeyer's Avatar
Oddometer: 3,055
Chris
Oh, ok, I didn't reread to find the year. I thought the adventures with 48's had double discs on front, like the 950 ADVs.
Anyway, the springs are from an 06 950, which means they'd need a 20mm spacer to be the correct length for a 640. If GB doesn't want them, I'll send them your way.
Zak
ktm
old bmw
others
Times are GMT -7.   It's 05:41 PM.
