Old 04-06-2012, 03:40 PM   #166
danedg
Horizontally Opposed
Oddometer: 6,532
Thanks VS,
I'm watchin' your rebuild. You Go!...
The PDF has been filed, but it still doesn't illustrate the front disk hub bearing arrangement.
Just a reminder, ride every chance you get. You just don't know how soon it can be taken from you. T.Low
danedg is offline   Reply With Quote
Old 04-06-2012, 03:43 PM   #167
vacantstare
vacantstare's Avatar
Oddometer: 294
that .pdf sucked...
maybe you'll find something better here:
http://thisoldtractor.com/gtbender/m...ervice_manuals
vacantstare is offline   Reply With Quote
Old 04-06-2012, 05:12 PM   #168
maquette
maquette's Avatar
Oddometer: 214
Try this?
http://tinyurl.com/d4msf9v
'09 KLX250S
'02 Honda ST1100
'00 Kawasaki 250 Super Sherpa (Hers)
'79 Moto Guzzi 1000SP/ Velorex 562 sidecar
'72 Moto Guzzi Eldorado
maquette is offline   Reply With Quote
Old 04-06-2012, 05:18 PM   #169
danedg
Oddometer: 6,532
Old 04-06-2012, 05:28 PM   #170
danedg
Oddometer: 6,532
So I pulled the greasy axle outta this after 11? years, and condensation dripped out...?
Not a lot, but some.
The unit looks fine. Should I be concerned about the inner bearing assembly?
Old 04-06-2012, 05:29 PM   #171
danedg
Oddometer: 6,532
Old 04-06-2012, 08:07 PM   #172
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,114
condensation? I would look at them, and shoot them full of waterproof grease. After 11 years, how can you say "hey, that grease is as good as the day it went in.."
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 04-06-2012, 08:10 PM   #173
Chad M
Custom User Title
Oddometer: 771
Dan, you could just remove those 6 bolts and split that hub. Then you could be sure of what is going on in there. (edit: you already know this I'm sure).
Chad M is offline   Reply With Quote
Old 04-06-2012, 08:36 PM   #174
MZRider
Neo-Luddite
Oddometer: 696
Replace the sealed ball bearings, they're cheap and readily available. If you don't now, you likely will have to later.
Charlie
http://www.AntietamClassicCycle.com
'69 Guzzi Ambassador,'77 Yamaha XT500,
'88 Ducati Paso, '91 ATK 604
'94 MZ Silver Star, '96 CCM 350
MZRider is offline   Reply With Quote
Old 04-06-2012, 08:39 PM   #175
MZRider
Neo-Luddite
Oddometer: 696
Originally Posted by danedg View Post
Just a clamp-on cover over the real nut! Loosen up the pinch bolt, remove the cover from the nut. The cover is supposed to lock into the fins of the head - if you've removed it complete, then something is damaged.
Charlie
Old 04-06-2012, 08:48 PM   #176
Bloodweiser
honestly
Bloodweiser's Avatar
Oddometer: 2,586
Seriously, take a minute.
Borani's are hot.
That's a nice wheel there.
Bloodweiser is offline   Reply With Quote
Old 04-07-2012, 02:29 PM   #177
danedg
Oddometer: 6,532
Eldo Elbo
There.... that's better!
Old 04-07-2012, 02:41 PM   #178
danedg
Oddometer: 6,532
Yup!
Originally Posted by maquette View Post
That's it. Thanks much!
Old 04-07-2012, 03:09 PM   #179
danedg
Oddometer: 6,532
This cleaned up pretty good
Old 04-07-2012, 05:28 PM   #180
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,114
pretty well, you english major
Times are GMT -7.   It's 02:26 AM.
