Old 01-16-2013, 01:11 PM   #316
F_Sahms
mostly paved
F_Sahms's Avatar
Oddometer: 338
Originally Posted by danedg View Post
I got the rear swingarm off today. The swingarm bolts were frozen and there was a 1/4" layer of greasy roadmung over everything, but with the proper amount of carefully chosen profanity it finally let loose. I of course had to remove all the levers and rods for the rear brake as well.
Without all the crap in place I can now see on the left rear "loop" the remains of a sawed off bracket...
Would that be the remains of a siren bracket?
There a rubber bumper that mounts to one little bracket that keeps the centerstand from rattling. That may have been it.
You can see it here:
Life's too short.
F_Sahms screwed with this post 01-16-2013 at 02:00 PM
F_Sahms is offline   Reply With Quote
Old 01-16-2013, 03:16 PM   #317
danedg
Horizontally Opposed
Oddometer: 6,533
Yup
Greg B has a nifty writeup of the siren bracket. It's on the top of the loop, these remnants are on the bottom. Oh well...
The good news is the cam and crank all checked out nicely. The bearings are worn and did their job. They'll now be residing in the big trashbin in the sky... bearings and seals were always on the list.
I'm ALMOST to the point where I can start putting stuff back together.
Just a reminder, ride every chance you get. You just don't know how soon it can be taken from you. T.Low
danedg is offline   Reply With Quote
Old 01-28-2013, 04:05 PM   #318
danedg
Oddometer: 6,533
The Assembly may now commence!
Old 01-29-2013, 06:40 PM   #319
danedg
Oddometer: 6,533
Mystery Switch
Located just forward of the throttle, down below where you would REALLY have to look for it is this momentary.
Not very accessible. Two wires Blk/Blu & Br. that jump back into the harness. I thought it must be the horn but it doesn't go there. What could it be? It doesn't show up anywhere. Police thing?
Old 01-29-2013, 06:51 PM   #320
nick949eldo
Oddometer: 925
Starter button. Or at least it is on my 74 Cali.
Nick
nick949eldo is offline   Reply With Quote
Old 01-29-2013, 07:30 PM   #321
danedg
Oddometer: 6,533
It doesn't seem beefy enough. It's like 18-16 gauge wire. I thought it must be the horn....
I'm not aware of a relay anywhere?
There, underneath the master cylinder.
danedg screwed with this post 01-29-2013 at 07:49 PM
Old 01-29-2013, 08:45 PM   #322
danedg
Oddometer: 6,533
My favorite description
Moto Guzzi Riding Position
the large "police" or California handlebar for Eldorado, Ambassador. Positions your hands for a riding position similar to that of a roto-tiller.
MGCycle
Old 01-29-2013, 09:12 PM   #323
MZRider
Neo-Luddite
Oddometer: 696
Nick is correct. Starter button wiring. Blue/blk - power from fuse block, brown - power to the relay. It doesn't need to be any "beefier" since there is a relay mounted back under the voltage regulator.
Charlie
http://www.AntietamClassicCycle.com
'69 Guzzi Ambassador,'77 Yamaha XT500,
'88 Ducati Paso, '91 ATK 604
'94 MZ Silver Star, '96 CCM 350
MZRider is offline   Reply With Quote
Old 01-29-2013, 09:24 PM   #324
danedg
Oddometer: 6,533
I appreciate your input.
The button doesn't show on any of the parts dios that I have.
I've been debating replacing the wire harness but it seems rather specific to the bike.
Old 01-29-2013, 09:46 PM   #325
MZRider
Neo-Luddite
Oddometer: 696
The starter button is shown with other electrical equpment, not with the handlebars and controls where you'd expect it. It's #55 on Tavola/Plate 17 of the spare parts catalog:
http://thisoldtractor.com/gtbender/m...og_850_1ed.pdf
Greg Bender sells excellent replacement harnesses - every single piece to replicate the original harness.
http://thisoldtractor.com/gtbender/f...ng_harness.htm
He also offers a harness to add headlight relays as well, something Guzzi never had.
Charlie
Old 01-30-2013, 07:21 AM   #326
sjc56
Oddometer: 1,309
Thumbs up on Greg Benders harness, I replaced a lot of wire with his on my 74, they are first class and he has installation instructions on his web site that are top notch.
Steve
sjc56 is online now   Reply With Quote
Old 01-30-2013, 10:39 AM   #327
England-Kev
Oddometer: 3,544
Ah the old starter button, now I notice that this is not all it seems in Guzzi world, when I got my 70 Ambo I noticed when researching on the web etc, that my bike never had one, I mentioned it over on my thread here... http://www.advrider.com/forums/showthread.php?t=841764
So I found and bought one from ebayland, and had intended to fit it at a later date. But, it would seem I had made a basic error, most of the info on the WWW, is from American sources, but my bike is an Italian home market bike, and as such has a few subtle differences, probably because they wanted to use up parts from older models.
My bike has a starter ignition switch, just like a car, turn it over and it starts no push button needed, if you look closely you will also see other things, rear light, seat pattern, carb clamps.
England-Kev is offline   Reply With Quote
Old 01-30-2013, 11:38 AM   #328
danedg
Oddometer: 6,533
Wanna sell it? Mine is REALLY crusty and it looks like I'm going to have to cut it off the bars. The Allen head is stripped.
Old 01-30-2013, 12:20 PM   #329
England-Kev
Oddometer: 3,544
You would really be better off getting a new one from here...
http://www.mgcycle.com/product_info.php?products_id=959
Cheaper than me posting to the US, and you know it will work Ok when you fit it.
Old 01-30-2013, 03:12 PM   #330
F_Sahms
mostly paved
F_Sahms's Avatar
Oddometer: 338
The switch on V7 Sports can also start like a car, by turning past the "run" setting, but it has a starter button as well. I am not sure if my Eldo does it too.
Life's too short.
Times are GMT -7.   It's 06:30 PM.
