Old 03-02-2013, 11:44 AM   #406
danedg
Horizontally Opposed
Oddometer: 6,666
The closer you look
...the better it gets!
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic
danedg is offline   Reply With Quote
Old 03-03-2013, 12:55 PM   #407
danedg
Oddometer: 6,666
Thumb
Old 03-03-2013, 02:51 PM   #408
England-Kev
Oddometer: 3,635
Dan your rear light is from an 850-T3 california, this is what you should have...
you are doing a great job, looking forward to some ride reports this summer.
England-Kev is offline   Reply With Quote
Old 03-03-2013, 05:09 PM   #409
danedg
Oddometer: 6,666
I Dunno
If I remember correctly,
All vehicles registered for US highways after 1972 were required to have "directionals". Including motos.
They musta slapped anything they had on there.
Old 03-09-2013, 02:23 PM   #410
danedg
Oddometer: 6,666
Somebody's Got A Lot of Splainin' to do
Followed the instructions.
Loosen the top bolt a coupla turns and give it a huge whack with a dead blow hammer.
Remove top bolt and extract fork... Check.EZ
Worked great on the left fork.
Four hours later I finally released the top bolt from the confines of the ??? nut on the right fork involving many tools and primitive methods and swear words...TOTAL PAIN IN THE ASS!!
Upon further review, I can't even find the threaded sleeve on the fiche that the 36mm nut fits in to...
The fork on the left seems normal, what going on with the right?
Old 03-09-2013, 02:56 PM   #411
England-Kev
Oddometer: 3,635
I think the one on the right is correct, except for the fact the smaller thread should not have seperated from the finer larger thread? if that makes sense? so in reality you need to unscrew both the inserts that you have left in the fork stanchions. They should have come out with the top nuts.
Old 03-09-2013, 03:07 PM   #412
danedg
Oddometer: 6,666
The tavola shows the top nut going into fork. Nothing intermediary.
The top nut was bound up and pulled the fork top piece? out with it.
Of course everything was now free to spin. It was a bear to separate the top nut from the unidentified fork top receiver thingamabob...
Old 03-09-2013, 03:56 PM   #413
England-Kev
Oddometer: 3,635
Dan I am sure the fork top nut should not have seperated from the other section, they should both have come out as one piece...
Old 03-09-2013, 07:05 PM   #414
MZRider
Neo-Luddite
Oddometer: 720
On discs Eldos, there is the "cap, front fork" (#2 on Plate 2 here: http://thisoldtractor.com/gtbender/m...supplement.pdf ) which has the 36mm hex top and the "sleeve, front fork" (#3 on Plate 2) which it threads into. To disassemble the forks, the "cap" is first removed, then the M8 socket-head cap screw (#4 on Plate 2) down in the top of the "sleeve" is removed. The slider, damper cartridge and spring unit will then slide down and off of the tube. The "sleeve" can be removed with a homemade tool or one like this: http://www.pacificcustoms.com/AC000139.html
Lots of information on Greg Bender's website about the disc forks, just click on "D" in the general index. Here's just a sample:
http://thisoldtractor.com/gtbender/m...nd_tube_sleeve
Charlie
http://www.AntietamClassicCycle.com
'69 Guzzi Ambassador,'77 Yamaha XT500,
'88 Ducati Paso, '91 ATK 604
'94 MZ Silver Star, '96 CCM 350
MZRider is offline   Reply With Quote
Old 03-09-2013, 11:28 PM   #415
England-Kev
Oddometer: 3,635
well done Charlie, that explains it all.
Old 03-10-2013, 06:30 AM   #416
danedg
Oddometer: 6,666
AH HAH!
Silly me
I was looking under F for forks, not D for discs.
It still wouldn't have helped much as the sleeve was seized on the top nut.
Old 03-10-2013, 06:55 PM   #417
MZRider
Neo-Luddite
Oddometer: 720
Originally Posted by danedg View Post
AH HAH!
That's not unusal, doesn't absolutely have to come out. When I find them stuck, I leave them in place and just submerge the whole tube in my parts washer. Unless the tube needs to be replaced, then the fun starts...
Charlie
Old 03-11-2013, 09:02 AM   #418
danedg
Oddometer: 6,666
Rusty crusty
This was the whole reason dismantling the front forks to begin with. Turning the handlebars was like turning the handle on one of them old fashioned meat grinders. Both bearing were rusted to death. I ordered replacements before I had it apart.
Now that I see water entry problems I'm wondering if I shouldn't have replaced the old with new [U]sealed[U] bearings. There isn't any seal to prevent water from getting in there. Just grease?
Thoughts?
Old 03-11-2013, 10:04 AM   #419
F_Sahms
mostly paved
F_Sahms's Avatar
Oddometer: 360
They make sealed tapered roller bearings?
Water shouldn't be getting in there if the bike is stored upright. Fresh grease and that little chrome cap should keep water out.
Life's too short.
F_Sahms is offline   Reply With Quote
Old 03-11-2013, 10:27 AM   #420
danedg
Oddometer: 6,666
It sat unused for 11 years, in a barn, upstate NY.
I'd guess that was enough...
Times are GMT -7.   It's 07:47 AM.
