Old 10-13-2011, 05:23 PM   #1
newellbc OP
Oddometer: 55
Suzuki 1250 Bandit car tire.
Hi there. I'm going to be putting a Hannigan Sprint, on 1250 Suzuki Bandit. So, I lowered the gearing, and installed a 205/50-17 car tire on the back. I'll be installing a fork brace when it arrives. The tire mounted normally. No surprises. But, not a lot of clearance. The tire clears the chain and chain guard by only 1/8th inch. But, nothing rubs. It's raining today, so no test ride.
newellbc is offline   Reply With Quote
Old 10-13-2011, 05:25 PM   #2
newellbc OP
Oddometer: 55
Here's a side view.
Old 10-13-2011, 05:28 PM   #3
newellbc OP
Oddometer: 55
The stock tire had a circumference of 77.5 inches. The car tire was 79 inches. So, a little bit larger in diameter. But not much. I changed the front sprocket from a 18 tooth to a 16 tooth. The rear is a stock 43 tooth. Once I get the sidecar mounted. I'll see how I like the gearing. I may go up on the front, to 17 . The Bandit has massive amounts of torque. We'll see. Now I have to installed my speedometer calibrated and adjust it. Blaine
Old 10-13-2011, 10:42 PM   #4
Qwik
Adrenaline Addict
Oddometer: 6,539
You can gain a little clearance by shimming the rear chainring and front sprocket out with washers.Not a lot but it may make the difference.
Speed bumps never seem to make me go any faster
Qwik is offline   Reply With Quote
Old 10-14-2011, 01:09 PM   #5
newellbc OP
Oddometer: 55
Hi there. I had it out for a test ride today. No problems. Nothing rubbed and it handeled pretty good. Hannigan will be mounting a sidecar on it, in about a month.
Old 10-14-2011, 03:31 PM   #6
oldxrider
Oddometer: 28
what kind of ( brand/type ) tire did you use. Thinking about going darkside on my recently hacked HD.
oldxrider is offline   Reply With Quote
Old 10-14-2011, 05:20 PM   #7
shultzy09
3 wheeler
shultzy09's Avatar
Oddometer: 22
Thanks for the info and pics now i know a 195/45/R17 will fit I run a 1250 Bandit/Terraplane rig with no gear change and I'm very happy with the bike as a tug at any speed. Thanks again. Bill {CSM back room}
shultzy09 is offline   Reply With Quote
Old 10-14-2011, 10:13 PM   #8
newellbc OP
Oddometer: 55
Hi there. About car tires on motorcycle rims. The 15 inch car tire and motorcycle tire, inside diameter is different. But the 16 and 17 inch rims seem to work fine. When buying a car tire for your rim, check to see what recommened rim widths are. I'm not at home now. So, I can't say what brand and style of tire I used. I'm bad with names. I'm one of those guys that has forgotten the names of ladies I was on a date with.
Old 10-14-2011, 10:28 PM   #9
newellbc OP
Oddometer: 55
Another thing about car tires on motorcycle rims. A lot of dealers will refuse to mount them for you. I have my own tools, and mounted and balanced my tire. Be ready to explain that it's going on a sidecar rig. And even then, some will just say no. Blaine
Old 10-16-2011, 12:20 PM   #10
NortwestRider
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 3,802
I would take off your chain guard,my car tire ate my chain guard on my Vstrom at 70mph and locked up the rear tire !!!.I also had about 1/8 inch of clearence.
2012 Honda NC700XAR
1990 XT350 Overlander
GS500ADV..THE PURPLE EXPLORE
Facebook..PNW Adventure Riders..Facebook
MY BUILD http://www.advrider.com/forums/showthread.php?t=938440
NortwestRider is offline   Reply With Quote
Old 10-16-2011, 07:21 PM   #11
newellbc OP
Oddometer: 55
Hi there. Instead of taking it off. I'm going to cut off a little more clearance for the tire. Give it about 3/8 of an inch clearance. Blaine
Old 10-17-2011, 01:05 PM   #12
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,415
How about two 3/8" spacers?
Vince @ SWFL or WNC
2001 Kawasaki W650
2012 Dong Fang DF250RTB
2013 Ice Bear PBZ110-1P sidecar
2015 Ural cT
Bar None is offline   Reply With Quote
Old 10-17-2011, 08:42 PM   #13
newellbc OP
Oddometer: 55
2 spacers about 1/4 inch would give me 3/8 inch. Thanks. I did't think of that. Blaine
Old 09-02-2012, 09:07 PM   #14
cmaridersa
cmaridersa's Avatar
Oddometer: 39
Bandit 1250 Rig Followup
Anything to follow up about the rig? Just got an '08 with 3K miles to hack yesterday and just found your thread today.
Earl
1999 Honda NightHawk 750
2000 r1150GS
'04 Ural Patrol - MollyTov
2008 Suzuki Bandit 1250S w/Texas Sidecar
cmaridersa is offline   Reply With Quote
Old 09-02-2012, 10:53 PM   #15
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,654
Well I can tell ya that the tire he pictured there is a Multi-Mile Matrix Tour RS. linky
But it's a pretty common size. Tires By Web lists 32 tires in that size and the Tire Rack lists 87!
WUMPA
Sidecardogs.com
DRONE is online now   Reply With Quote
Times are GMT -7.   It's 10:20 PM.
