Old 01-05-2014, 09:21 PM   #91
CosentinoEngineering OP
Oddometer: 183
>>Could sufficient "still" air be supplied by a smaller air box with positive pressure ?
Positive pressure like a turbo, yes! There is not much pressure to be had by even a very efficient airbox system so going down on its volume is hard to compensate for. That said, will it make a lot of difference? Are you racing? If not, then not much.
>>My starting point sv650 carbed ,has seemingly a very small exhaust cam , -2mm lift ,-24 deg less than intake
Exhaust cams are usually smaller then intakes, just like the valves. The intake has to suck air from the atmosphere which is hard to do and you can only pull 14.7psi of vacuum so if your intake is not efficient your cylinder does not fill fully which has a horrible effect on power. Exhaust gas can be pushed out by the piston so can have a lot more than the intake's 14.7psi max pressure differential to drive its flow. You can lose some power by having a compromised exhaust cam profile but if it is in the interest of making the intake work better then in the end you have a more powerful engine. This pdf has a lot of technical information but there is a section discussing each phase of the cam profile and how short changing one can help another. If you can find an online PDF copy of 'Empiricism and Simulation in the Design of the High Performance Four-Stroke-Engine' by Blair he goes a lot more into the design tradeoffs of intake and exhaust cam profile design.
>>I am looking to move power curve down +/- 2000 rpm
That's a lot! Why?
>>I have in mind 650 thumper lunge with v twin balance
Gearing can't accomplish this? A lot of times a 650 single is geared for a much lower top speed than a 650 twin would be and that is what accounts for the seemingly better acceleration. Same reason Harleys are great stoplight machines compared to a GSXR1000. The Harley will top out at 120, the GSXR at 180. Changing the gearing so they both top out at 120 (or 180) and the GSXR would win.
Changing from a CV to a non-CV carb would greatly increase your lungability. The CV carb only opens as fast as vacuum allows. There are mods to be don to CV carbs to increase their throttle response and usually involve increasing the vacuum port hole size.
I'd start by playing with the carbs and cams and gearing before you buy stuff and see how much of an improvement you can make.
Chris
moto2-usa.blogspot.com
Check out my products 10% off for ADV rider members
CosentinoEngineering is offline   Reply With Quote
Old 01-06-2014, 06:57 PM   #92
joexr
Oddometer: 3,773
Old 01-07-2014, 06:13 PM   #93
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,544
Igonore this troll.
And welcome back , Chris !
Old 01-08-2014, 04:42 AM   #94
lord_oblivion
lord_oblivion's Avatar
Oddometer: 125
Found info about porting slide vacuum holes. But nothing about cutting slide springs...
Better dead than lose momentum ...
www.jawaklubsrbije.org
lord_oblivion screwed with this post 01-08-2014 at 05:49 AM
lord_oblivion is offline   Reply With Quote
Old 01-08-2014, 08:45 AM   #95
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,234
I never messed with the slide holes on my carbs. I removed 10mm from each slide spring and the throttle response was crazy.I never realized how much lag was in them until that mod.I got the mod idea from PeteGS over on Do The Ton forum.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 01-08-2014, 09:07 AM   #96
lord_oblivion
Oddometer: 125
Thank You for sharing expirience.
Had any problem with mid-range mixture goes richer/leaner after shortening springs?
Old 01-08-2014, 10:38 AM   #97
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,234
I experienced no side effects,just faster throttle response because the slides rise faster.
Times are GMT -7.   It's 05:55 AM.
