Old 11-07-2005, 04:45 AM   #61
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,874
Good stuff! Welcome to the asylum.
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 11-07-2005, 07:59 AM   #62
markjenn OP
Oddometer: 10,473
Very nice. The trick of leaving the bearing retainer on is a good idea too - that's how KTM says your supposed to do it if you're pressing the bearing in from the other side (obviously, with the cases split).
- Mark
Old 04-17-2006, 11:01 PM   #63
mtrcycllvr
Nerdly pseudo adventurer.
mtrcycllvr's Avatar
Oddometer: 185
Got it out! I must be one of the lucky "easy" ones..
Well, I'm usually all excited about getting INTO things, but I just managed to get OUT of something, or rather I just got my older (perhaps or perhaps not) ready to fail tranny main shaft bearing out.
http://mtrcycllvr.smugmug.com/gallery/1378050
To bad I didn't have the foresight to actually have the replacement bearing at hand! But you have to admit, getting the original bearing out is the real challenge here..
Thanks VERY much to everyone who contributed advice via this thread! Absolutely INVALUABLE!
Rock on!
-ET-
mtrcycllvr is offline   Reply With Quote
Old 04-18-2006, 12:10 PM   #64
ktmnate
ktmnate's Avatar
Oddometer: 3,082
Rock on!
-ET-
Very nice. What says you about me riding my bike up and having you fix it
Great pix. I'm probably going to do my bearing prety soon.
Nate
ktmnate is offline   Reply With Quote
Old 04-18-2006, 01:03 PM   #65
mtrcycllvr
mtrcycllvr's Avatar
Oddometer: 185
Nate
Well, the advantage there would be the motor would be good and hot! I would have taken that step, but the forks are up at moto-pro suspension up Seattle way..
I can believe some folks have trouble, but it would seem that if the motor was hot and some freeze spray was handy, this can't be too difficult for anyone.
Want me to send you my "hooks"? ;-) I'm sure not going to be doing this again anytime soon!
-ET-
Old 05-08-2006, 07:41 AM   #66
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,976
I got around to doing this mod finally. Everything went great. I did it Fri. night and was done in about 3.5 hrs. My bike has 21,150 miles on it and the bearing that was in there still looked great. Oh well, now I know it will be fine for a long time to come. Everything looked very nice inside except the clutch, I will be replacing that soon. It feels good yet, but some of the plates have turned purple.
Zigman came over Sat. morning and we pulled his bearing out also, a 2000 640 Adv w/ about 800 miles on it (very nice clean, bike), why not we had the puller? That one went great also, done in about 2.5 hours. I'm getting good at this.
BTW, No heat was used and I did have the bearing in the freezer for 24 hrs. Can't say that it really helped, but it couldn't hurt. Good Luck everyone.
Thanks Advrider members and Markjenn for the great write up.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 08-13-2006, 02:44 PM   #67
Red J
C'mon, spring!
Red J's Avatar
Oddometer: 784
Instructions in hand, trivial bearing pull on my 02 w/9500mi. Took a few hours mainly because of the Bee double E double Are You En.
Thanks, markjenn.
Red J is offline   Reply With Quote
Old 08-14-2006, 03:32 PM   #68
ktmnate
ktmnate's Avatar
Oddometer: 3,082
Thanks, markjenn.
ahh, a Grath Brooks fan
Nate
Old 08-28-2006, 08:04 PM   #69
Pezz_gs
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,835
Bearing ID Numbers
As I am about to rebuild 2 of these suckers, 660 and 640 Adv R , I have been pricing a complete set of bearings twice
I have located the Crank bearings via a SKF reseller and have saved about $240.00 on the 2 sets. Exactly the same bearing . . . NJ207 ECP C3
Question is, deos anyone have the bearing sizes for the Roller bearing?
I have asked for the BC1-0076A but it appears to be a KTM bearing number.
Any assistance would be appreciated
Pezz :)
Airhead Tragic
I'm not a complete idiot -- Some parts are missing
XR460/4 - http://www.advrider.com/forums/showthread.php?t=497905
Pezz_gs is offline   Reply With Quote
Old 08-30-2006, 05:21 PM   #70
Pezz_gs
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,835
Airhead Tragic
Old 11-12-2006, 04:50 PM   #71
getagripgreg
Oddometer: 409
Bumpage indeed.
Well, my '01 Duke II started making a squeaking noise from the clutch recently, at about 7K miles. Tried to ignore it, but when I started feeling vibration in the left peg, I parked it. Finally pulled the clutch cover off today, and found a huge amount of slop at the end of the mainshaft.
Looks like I'm off to order a new bearing. Damn.
Thanks for the great thread tho! At least I know what I'm getting into.
getagripgreg is offline   Reply With Quote
Old 02-08-2007, 11:23 PM   #72
JP4
Thumper Geek
JP4's Avatar
Oddometer: 178
Posted this also on Ktmtalk.
Okay, just got the bearing and since I don't have the tool yet I'm going to make one.
Big question: I haven't found any agreement in my search of this or the Ktmtalk thread as to the order of assembly for the bearing. Is it: inner race, then bearing, then the washer or the other way around?
Thanks.
Jeff
'01 LC4 640E 18L
'93 XT225
JP4 is offline   Reply With Quote
Old 02-09-2007, 02:02 AM   #73
markjenn OP
Oddometer: 10,473
Thanks.
It's discussed in the instructions. My take is that it doesn't matter mechanically, but if you do washer first, you have the ability to pull the race from the outside in the future which might be a big help if you ever (heaven forbid) have to do the repair again.
- Mark
Old 02-09-2007, 09:00 AM   #74
JP4
Thumper Geek
JP4's Avatar
Oddometer: 178
Thanks Mark
Just wanted to double check before I committed.
Jeff
Jeff
'01 LC4 640E 18L
'93 XT225
Old 02-09-2007, 10:02 AM   #75
markjenn OP
Oddometer: 10,473
Thanks Mark
Jeff
Just make sure you double-check (no triple-check and have you wive/GF check too) that you have that washer on the shaft before you start driving the bearing. Man, that would be a total bummer to drive the bearing in there and see the washer laying on one's workbench.
- Mark
Times are GMT -7.   It's 04:10 PM.
